Toymods » Tech & Conversions » Soarer rear tail lights? How do you get at them?
viagra_cressida
Balranald
Soarer rear tail lights? How do you get at them? Sun, 09 November 2003 06:28 Go to next message
G'day
I have blown a globe in the rear tail light of my car and I can't seem to work out how to get to it? I've pulled all the carpet off inside and doesn't seem to be much there. Just one plug that I can't get off. What do I need to do??
Thanks in advance
Steve
Soarer
Wollongong
Re: Soarer rear tail lights? How do you get at them? Sun, 09 November 2003 06:37 Go to previous messageGo to next message
You need to pull out those little plastic covers on the carpet behind the tail light. Then you'll need a 10mm socket, cos the whole tail light has to come out to replace a globe. I've had to do it once already.
viagra_cressida
Balranald
Re: Soarer rear tail lights? How do you get at them? Sun, 09 November 2003 11:46 Go to previous messageGo to next message
Thanks mate.
But what screws do I undo? The ones that are brass with a nut and about 1cm of thread showing?
So if I undo them the glass will fall out the back? Is this right?
viagra_cressida
Balranald
Re: Soarer rear tail lights? How do you get at them? Sat, 15 November 2003 08:03 Go to previous messageGo to next message
Hello??
Soarer
Wollongong
Re: Soarer rear tail lights? How do you get at them? Sat, 15 November 2003 12:49 Go to previous messageGo to next message
I can have a look at mine in the morning, but I know you need to remove 4 nuts from behind the carpet then the entire tail light comes out the back of the car. Then it's easy to change the bulbs. I don't think there's any other way to do it.
viagra_cressida
Balranald
Re: Soarer rear tail lights? How do you get at them? Thu, 04 December 2003 11:48 Go to previous message
All done.....took a pit of pulling though....my 4 bolts didn't line up to the holes very well Confused
Well the bulb was fine and I put it back in and worked well....then after 2 days....began not working again....oh well I can't understand cars
Previous Topic:Diff question
Next Topic:Pitted block surface
Current Time: Fri Nov 20 06:51:15 UTC 2026
Total time taken to generate the page: 0.0059030055999756 seconds
