Toymods » Tech & Conversions » Surge tank fittings leaking - thread tape?
Surge tank fittings leaking - thread tape? Sun, 09 November 2003 08:56 Go to next message
Ok i have heard two different stories about this, and having no experience helps me in no way at all.
Basically a couple of the threaded fittings in my surge tank are dribbling a little bit of fuel. I had thought that being tapered threads this wouldnt be a problem - but obviously it is.
What do people usually use for this?
I have included a pic of the setup so you can get an idea of how things are working here.
The parts circled in green is where fuel is dribbling. The blue fitting on the bosch pump i think is leaking due to the hose clamp biting into the rubber too much (whoops). Of course everything is hose clamped nicely and connected up properly since that picture, havent taken a newer one yet Smile
Damn it sux when shit goes wrong.
http://groups.msn.com/_Secure/0VgDPAqkafqEHKSb1E1!gH2SV34cI4eQ6QB0FSwbjUAkcpP7NshK0zRUyQcApx4U8CBUxH25!DAmh7e!NofZPUWe9UwdUzLiBkyQvaYCqVi9m4tytyb!VEGC1ZHQ2zLi5/Problems%20with%20surge%20tank.jpg?dc=4675446427865441558
Re: Surge tank fittings leaking - thread tape? Sun, 09 November 2003 08:58 Go to previous messageGo to next message
another thought - might this also be due to the use of barbed fittings? I hope not cos then two different guys, one from a reputable shop with experience in this work and another from Speedflow fittings, have recommended barbed fittings....
Mr DOHC
Re: Surge tank fittings leaking - thread tape? Sun, 09 November 2003 09:34 Go to previous messageGo to next message
r u using proper EFI hose clamps, they resist pinching much better
TE72_Turbo
Re: Surge tank fittings leaking - thread tape? Sun, 09 November 2003 10:29 Go to previous messageGo to next message
Definately use thread tape on the barbed fittings.. Tapered thread isnt quite good enough to seal on its own in all cases.
Phil
Re: Surge tank fittings leaking - thread tape? Sun, 09 November 2003 11:05 Go to previous messageGo to next message
cheers Phil(s). I'll grab myself some thread tape while im getting the exhaust done tomorrow morning. Hopefully then i can drive it around and HEAR whats happening.
I dunno what kind of hose clamps i got - i just asked the dude for a shitload of hose clamps, and he knew exactly what i was doing with the whole EFI fuel thingy.
pro_ke
adelaide
Re: Surge tank fittings leaking - thread tape? Sun, 09 November 2003 12:02 Go to previous messageGo to next message
efi clamps cost a bit more than normal ones, they also have a little tab that covers the thread on the clamp so it wont pinch the rubber. if these dont work you could get the clamps with the bolt that tightens them but they are about $5 a pop
also i am pretty sure on my carter pre pump it says to never use thread tape on the fittings...
ab
clubagreenie
1st street on the right
Re: Surge tank fittings leaking - thread tape? Sun, 09 November 2003 12:09 Go to previous messageGo to next message
I have speedpro fittings and don't have thread tape or leaks. Have to be sure the fuel won't affect it maybe?
Stupid question but have you got tapered fittings going into paralell?
[Updated on: Sun, 09 November 2003 12:11]
pro_ke
adelaide
Re: Surge tank fittings leaking - thread tape? Sun, 09 November 2003 12:20 Go to previous messageGo to next message
ps witzl i should have mentioned get in touch with dale at www.braidedlines.com - he is in castle hill too and can supply you with speedflow fittings which wont leak at a very good price (per the above post!)
Re: Surge tank fittings leaking - thread tape? Sun, 09 November 2003 15:01 Go to previous messageGo to next message
if they are NPT tapered threads, they are not designed to seal without tape. you might be able to get away with threadlocker if it is fuel resistant, but teflon tape would be a good way to start.... there are at least two types of thread tape too.. water and gas. the gas is thicker and usually yellow (or pink?) and water is white... maybe go the gas tape so you can stuff it in there....
as for clamps, get the ones with bolts, not the ones with slots, as the slots cut the rubber...
i can bring some out for ya and give you a hand soonish.. gotta pick up that piston and other things from you, and drop off bits to Michael....
Grega
melbourne.victoria.austra...
Re: Surge tank fittings leaking - thread tape? Sun, 09 November 2003 19:22 Go to previous messageGo to next message
dunno about tape sealing up this stuff. the petrol if leaking will eat thru it, and, well leak again.
threebond make anaerobic "goo/paste" which you use when you do LPG installs - i know meridian motorsport down here in vic have it, but, all my fittings are sealed with this stuff (fuel and oil) and they do not leak at all. this stuff reacts when in contact with air and hardens.
i'd look for a small tube of that.
ps: witz what you doing with the surge tank in the engine bay of all places? whats wrong with under the diff or in the boot?
[Updated on: Sun, 09 November 2003 19:22]
Re: Surge tank fittings leaking - thread tape? Sun, 09 November 2003 21:44 Go to previous messageGo to next message
In boot - too difficult and hoses all over the shop.
Under diff - Not enough room (diff comes too close for comfort.
This is just easier for me. If i want to change i can always do that later.
Re. Speedflow fittings - on the outlet of the HP pump you'll notice the anodised blue fittings, these are the speedflow type. But like i said that one is leaking due to the clamp pinching the hose. I'm going down the industrial centre today to get my exhaust done, i'll pay a visit to the mentioned place cos the Speedflow supplier i used is in Seven Hills.
I'll let you know how i go today after i get the exhaust done. Thats the major concern right now.
coronamark2
Re: Surge tank fittings leaking - thread tape? Mon, 10 November 2003 01:23 Go to previous messageGo to next message
isnt it silly to have a surge tank in the engine bay?
if one of them hoses does spring a leak when your fangin it i hope you have a fire extinguisher Very Happy
Re: Surge tank fittings leaking - thread tape? Mon, 10 November 2003 03:39 Go to previous messageGo to next message
it would be the same anywhere in the car buddy, only the engine bay has higher temperatures. Plus there are new ADR's disallowing the use of fuel cells (surge tanks) in the boot unless completely sealed off.
twas also a turd trying to get all the stuff in the boot to begin with.
Now i have answers!!
Thread tape is bad. Fuel dissolves it apparently. I bought what both Stewart and the Speedflow guys at Seven Hills recommended, which is a Teflon type of "lock tight". It is unaffected by fuel and seals threads good, and is designed for what i need.
I also got a pair of the EFI type hose clamps which have bevelled edges to avoid pinching the hose, and were only $2- each.
P.S. The www.braidedlines.com guy works at Castle Hill Exhaust centre... Very Happy Which is where my exhaust was done today!
coronamark2
Re: Surge tank fittings leaking - thread tape? Mon, 10 November 2003 03:57 Go to previous messageGo to next message
cool i was just wondering dont want a flame grilled witzl now do we
Grega
Re: Surge tank fittings leaking - thread tape? Mon, 10 November 2003 08:30 Go to previous messageGo to next message
witz, is it a tape or a paste?
TE72_Turbo
Re: Surge tank fittings leaking - thread tape? Mon, 10 November 2003 10:45 Go to previous messageGo to next message
What's the difference between a hose to a surge tank, and a hose direct to the fuel rail? Either one is capable of spraying large amounts of fuel all over the engine if it leaks.
Re: Surge tank fittings leaking - thread tape? Mon, 10 November 2003 12:16 Go to previous message
My point exactly!
Grega - its a paste. The EXACT name is "Loctite 567 - Thread Sealant"
They call it a master pipe sealant, with teflon. Part no. 56747.
The shit was expensive at like $25 a 50mL tube, but worth it i spose.
Previous Topic:How much boost on standard 7MGTE?
Next Topic:Identifying TRD LSD hemisphere
Current Time: Thu Oct 22 06:56:26 UTC 2026
Total time taken to generate the page: 0.0056531429290771 seconds
