Toymods » Tech & Conversions » How to pick a Blown Head Gasket 7M
ViNcEnXo
How to pick a Blown Head Gasket 7M Sun, 09 November 2003 10:00 Go to next message
Are there any tell-tale signs that a 7M-GTE is about the blow its HG or does it just happen?
Any pointers before I shell over the rest of the money for the Soarer?
Paul
V8_MA61
Re: How to pick a Blown Head Gasket 7M Sun, 09 November 2003 10:37 Go to previous messageGo to next message
When its running, does it
Blow white smoke?
Is there:
Oil in the water - look inside the radiator cap
Water in the oil - look in the oil filler cap
I doubt the owner will let you, but if he does, get yourself a bhg test kit, it tests for exhaust fumes into the cooling system.
That should help a little...
Blake.
ViNcEnXo
Re: How to pick a Blown Head Gasket 7M Sun, 09 November 2003 10:56 Go to previous messageGo to next message
Can you elaborate into the BHG test kit?
Where can I get one, how much, and can I do it myself?
V8_MA61
Re: How to pick a Blown Head Gasket 7M Sun, 09 November 2003 11:01 Go to previous messageGo to next message
do you know a mechanic? Or someone with a workshop should have one you can borrow. Otherwise they're available at repco from memory!
It is very similar to a pump style.
You fill up the canister on the pump with water, and this liquid ( i forget its name sorry!)
And it turns a specific colour to show exhaust gases are present in the cooling system (mine turned yellow).
V8_MA61
Re: How to pick a Blown Head Gasket 7M Sun, 09 November 2003 11:02 Go to previous messageGo to next message
so yeah you can do it yourself Smile
If you're not sure, do it twice.
Allan
Re: How to pick a Blown Head Gasket 7M Sun, 09 November 2003 11:03 Go to previous messageGo to next message
look for bubbles in the coolent bottle after a hard drive and watery/white under the oil filler cap
Allan
ViNcEnXo
Re: How to pick a Blown Head Gasket 7M Sun, 09 November 2003 11:06 Go to previous messageGo to next message
The car blew its head gasket 10,000 k's ago and was fixed under a dealer warranty. I doubt they would have used a metal headgasket or known to re-torque the head.
What do you suggest I do?
V8_MA61
Re: How to pick a Blown Head Gasket 7M Sun, 09 November 2003 11:08 Go to previous messageGo to next message
take it to someone who you can trust, get them to pull down the bolts. Its worth the effort.
ViNcEnXo
Re: How to pick a Blown Head Gasket 7M Sun, 09 November 2003 11:10 Go to previous messageGo to next message
Should I do that after I buy it, or before?
V8_MA61
Re: How to pick a Blown Head Gasket 7M Sun, 09 November 2003 11:15 Go to previous messageGo to next message
i doubt the people will let you take it to someone, who has to pull most of the intake apart to tighten up the bolts! Just do the tests/ diagnosis we have told you about...if it clears them, then buy it and have the head re-torqued then Smile
ViNcEnXo
Re: How to pick a Blown Head Gasket 7M Sun, 09 November 2003 11:18 Go to previous messageGo to next message
Lovely...
Thanks a million...
BTW, are there any MkIII/MZ/GZ20/21 forums around?
Paul
rvrolla
Central Coast
Re: How to pick a Blown Head Gasket 7M Sun, 09 November 2003 12:17 Go to previous messageGo to next message
Don't know if its still up, but try:
Gary's website
Supra Forums are a wealth of 7M knowledge !
A xZ2x Soarer mailing list:
toyota_soarer@yahoogroups.com
http://autos.groups.yahoo.com/group/toyota_soarer/
7M-Brisbane
Re: How to pick a Blown Head Gasket 7M Sun, 09 November 2003 12:19 Go to previous messageGo to next message
Once you open the bonnet, there are two things to look for.
Look on the build plate or on the front of the timing belt cover. If either of these say "7MGTE" then I'm afraid you have a blown head gasket.
Seriously, though - gunge under the oil cap (white spots/goo), a gunky looking radiator, bubbles in the coolant, gurgling/gushing sounds when starting/stopping the car, car blowing steam out the exhaust, car using coolant, car misfiring, car making less power.
Also if you pull out spark plugs if one is really clean that may be a sign.. also if you can lean waaay over and look in the spark plug holes with the aid of a torch... you will see that the pistons are black/charcoal. If one (or more) is brownish or cleaner than the others then it's probably a BHG.
If you ask someone who's been there before - retorque the head bolts NOW and start saving for a new head gasket.
1ndecent
Re: How to pick a Blown Head Gasket 7M Mon, 10 November 2003 03:51 Go to previous messageGo to next message
Headgaskets don't always blow between the cylinder and coolant jacket, I have had several fail between adjacent cylinders. The best test for a BHG is to do a leakdown test, it will tell you if the the gasket is blown and where the leak is going.
CrAiGzEE
south of the big smoke
Re: How to pick a Blown Head Gasket 7M Tue, 06 January 2004 04:01 Go to previous messageGo to next message
7M-Brisbane wrote on Sun, 09 November 2003 23:19
i dont appear to have any off them, my car seems to be warmer than usual. actually its using a bit of coolant but it aint in the oil
what they usually charge to test it? i dont wanna folk out $110 for a head gasket if it aint needed
Chris Davey
sunny coast, qld
Re: How to pick a Blown Head Gasket 7M Tue, 06 January 2004 04:35 Go to previous messageGo to next message
my 1JZ has a bit of gunge in the oil cap,makes a little girgle sound when you turn it off, has a misfire (always has) and makes less power than it should. It also is very laggy, I thought this was because of it running on 5 cylinders. I don't think it is using coolant and it doesn't blow steam out the exhuast.
I was told that it was running on 5 because of either dirty injectors or a sticky lifter as the compression and spark is good.
Any one have any advice?
Re: How to pick a Blown Head Gasket 7M Tue, 06 January 2004 04:36 Go to previous messageGo to next message
To test for CO2 in cooling system? a few bucks, if that
All they do is put a device over the radiator cap (open) and do a chemical test to see if CO2 is coming out
Chris Davey
sunny coast, qld
Re: How to pick a Blown Head Gasket 7M Tue, 06 January 2004 04:46 Go to previous messageGo to next message
Doesn't the car usually overheat if you have a BHG?
mine runs at middle temp.
Re: How to pick a Blown Head Gasket 7M Tue, 06 January 2004 04:58 Go to previous messageGo to next message
Not ness.
If it blows from cyl to cyl, temp wont change, but power will disappear
If it blows from oil to cyl, temp wont change, but oil will be everywhere out the back
Chris Davey
sunny coast, qld
Re: How to pick a Blown Head Gasket 7M Tue, 06 January 2004 05:12 Go to previous messageGo to next message
so would a cylinder to cylinder blow make the symptoms that i said just before?
Re: How to pick a Blown Head Gasket 7M Tue, 06 January 2004 05:17 Go to previous messageGo to next message
Do a compression test
Pull out all of the spark plugs, take off the coil->dizzy lead, and do a compression test on all cylinders (warm engine, not cold)
If 1 or 2 are heaps down on others, you have BHG (or a hole in a piston/valve!)
cyl-cyl blow will look something like this
170-168-50-47-172-165, or something along those lines
GL
Chris Davey
sunny coast, qld
Re: How to pick a Blown Head Gasket 7M Tue, 06 January 2004 05:27 Go to previous messageGo to next message
i have had the compression tested and it was 180-190 in all cylinders.
I don't have oil leaking out the back
The car doesn't over heat.
Does that mean that i don't have a BGH?
I hope so!
Re: How to pick a Blown Head Gasket 7M Tue, 06 January 2004 05:30 Go to previous messageGo to next message
Very unlikely you have a BHG then.
Re: How to pick a Blown Head Gasket 7M Tue, 06 January 2004 05:38 Go to previous messageGo to next message
I agree Norbie. I'd be looking somewhere else
New plugs/leads/injector cleaner.
check the check engine light, my TPS was incorrectly set causing heaps of idling issues
New Oil/filter
take off one hose at a time and clean it out thoroughly, you may find one is blocked
Chris Davey
sunny coast, qld
Re: How to pick a Blown Head Gasket 7M Tue, 06 January 2004 05:40 Go to previous messageGo to next message
I am glad to hear some reassurance! Smile
After all that is why I chose the 1jz over the 7m Razz
Don't the 1jz's have metal head gaskets standard?
Re: How to pick a Blown Head Gasket 7M Tue, 06 January 2004 05:42 Go to previous message
Yes, all JZ engines have steel headgaskets and much more sensible bore spacing, which means BHG's are quite uncommon.
Previous Topic:Car audio questions.
Next Topic:4A-GZE pistons specs?
Current Time: Fri Nov 20 06:50:38 UTC 2026
Total time taken to generate the page: 0.0079300403594971 seconds
