Toymods » Tech & Conversions » Bosch Fuel Pump Stupid Question
ra23celica
icon5.gif  Bosch Fuel Pump Stupid Question Sun, 09 November 2003 11:59 Go to next message
Embarassed
Was trying to find a good place to mount a Bosch (ex-Camira) EFI fuel pump on my RA23 this weekend, when I got myself confused.
Can someone please confirm for me that the inlet side of the Bosch fuel pump in the side with the power connections (pos/negative) and that the outlet is the single pipe on the other end ?
Or do I have it @rse about ?
Mitch.
gabe
Re: Bosch Fuel Pump Stupid Question Sun, 09 November 2003 12:14 Go to previous messageGo to next message
Mitch,
The inlet is the side that requires hoseclamps and the outlet is the threaded end.
So yes the electrical terminals are on the outlet side of the pump.
Gabe
pro_ke
adelaide
Re: Bosch Fuel Pump Stupid Question Sun, 09 November 2003 12:34 Go to previous messageGo to next message
afaik a camira pump is the same as a VL one
fuel flow goes IN the end with the + and - terminals and OUT the other end
check it with a bit of fuel in a bucket...
ab
CLG
Perth, Western Australia
Re: Bosch Fuel Pump Stupid Question Sun, 09 November 2003 14:00 Go to previous messageGo to next message
The inlet side has the 1/2" pipe outlet for the feed pipe from the surge or fuel tank. The outlet side has the electrical connections, with a 5/16 outlet heading towards the fuel rail.
gabe
Re: Bosch Fuel Pump Stupid Question Sun, 09 November 2003 14:59 Go to previous messageGo to next message
on a side note the threaded end has either 12x1.5mm thread for the '044' pump or 10x1.5mm thread for the 'vl turbo' pump.
Gabe
ps. The suction side for most pumps (not just fuel) will have a smaller discharge pipe diameter.
Skip
Re: Bosch Fuel Pump Stupid Question Sun, 09 November 2003 23:29 Go to previous messageGo to next message
Both ends of a Bosch 044 are threaded. The inlet side of my Bosch 044 was M18x1.5, not to sure of the outlet because I never removed it.
ra23celica
Re: Bosch Fuel Pump Stupid Question Sun, 09 November 2003 23:49 Go to previous messageGo to next message
Thank you for the help guys.
I'm pretty sure that the pump I have uses hose clamps
on both sides, ie. neither end is threaded.
I will have a look again tonight.
Either way, 1/2 inch pipe on inlet side, no connectors;
5/16 inch pipe on outlet side, with connectors.
Mitch.
shag
christchurch nz
Re: Bosch Fuel Pump Stupid Question Wed, 12 November 2003 08:27 Go to previous messageGo to next message
mate, i would just hook up some spare pipes and fill both sides with gas and give it a quick run on the battery, it will be easy to see, so long as you dont get the gas in your eyes or blow yourself up!
ra23celica
Re: Bosch Fuel Pump Stupid Question Wed, 12 November 2003 23:17 Go to previous message
Thanks Shaq, I will give that a go !
Mitch.
Previous Topic:clutch 3tgte/w55
Next Topic:question on sprinter
Current Time: Sat Oct 24 22:21:41 UTC 2026
Total time taken to generate the page: 0.0053591728210449 seconds
