Classifieds » Miscellaneous » W57 5-speed transmission
W57 5-speed transmission Mon, 10 November 2003 06:09 Go to next message
Hi all,
I recently discovered that the transmission I pulled out of an MA61 Supra is not a W58 as you would expect, but a W57. Weird! Anyway it's of no use to me, so I'm selling it. It has no bellhousing or shifter, but apart from that it's all good. Make an offer. Smile
GTStar
W.A.
Re: W57 5-speed transmission Mon, 10 November 2003 06:41 Go to previous messageGo to next message
what are g/boxes like these worth? incld. bellhousing etc etc
crazyracer
Re: W57 5-speed transmission Mon, 10 November 2003 07:20 Go to previous messageGo to next message
If you go to a regular wrecker they'll want between $400-600.
If you luck upon one at a pick-a-part DIY wrecker (and I have seen them there) you get it for $150-250.
Steve-AE86
Ademelaide, SA
Re: W57 5-speed transmission Mon, 10 November 2003 08:39 Go to previous messageGo to next message
norbie...how much are you after?
GTStar
W.A.
Re: W57 5-speed transmission Mon, 10 November 2003 10:49 Go to previous messageGo to next message
whats the big difference between the w58 and w57? also can u tell the difference between both by just looking at it?
anyone know what the w57 came from?
V8_MA61
Re: W57 5-speed transmission Mon, 10 November 2003 10:57 Go to previous messageGo to next message
the w58 has a steel sandwich plate (plate between the 2 box castings) and the w57 has an alloy one.
The w57's came out in ra65 celicas, and some supras.
If you can pick the sound of alloy vs steel when you hit it with a screwdriver, you can tell if its a w57/58. ANyway yes its noticeable if you know what to look for!
Re: W57 5-speed transmission Mon, 10 November 2003 11:17 Go to previous messageGo to next message
The most obvious way is to look at the sandwich plate which looks really different than the W58 one.
I'm interested to see what this goes for, I've got one with a G-series bellhousing just lying around...
[Updated on: Mon, 10 November 2003 11:18]
wilbo666
Re: W57 5-speed transmission Mon, 10 November 2003 11:20 Go to previous messageGo to next message
Yeah the steel sandwich plate is the difference from the outside. The steel sandwich plate is darker compared to the alloy one.
Inside the difference is a more overdriven 5th gear (1st -> 4th and reverse are the same).
http://members.iinet.net.au/~tigerbeer/zeRo/Toyota_Supra_5spd_Shifter.jpg
Notice in the above pic that the far left Gbox has a lighter sandwich plate than the one just on the right? W55 / W57 (not sure which could be either?) is on the left and the one over to the right is a W58.
JAZE
cronulla
Re: W57 5-speed transmission Mon, 10 November 2003 12:46 Go to previous messageGo to next message
Toyota made the W58 with a steel sandwich plate and also with an alloy sandwich plate, my celica ahs a alloy plate and the firewall reads: W58, the last time i saw a W57 on the ID plate was on a 1GGTE soarer cut and it had a steel sandwich plate.
V8_MA61
Re: W57 5-speed transmission Mon, 10 November 2003 13:01 Go to previous messageGo to next message
interesting jaze..because my box is the same..alloy plate and reads w58 on engine plate !
Muzzytt
Re: W57 5-speed transmission Mon, 10 November 2003 13:37 Go to previous messageGo to next message
i think its gotto do with actual gear ratios,
w57 and w58 1st gear is same- 3.28
2nd w57 = 2.06:1
2nd w58= 1.89
3rd w57= 1.27
3rd w58 = 1.27
4th w57 = 1.00
4th w58 = 1.00
5th w57 = .86
5th w58 = .78
Muzzytt
Re: W57 5-speed transmission Mon, 10 November 2003 13:39 Go to previous messageGo to next message
it would seem w57 is more closer ratios than w58....
what about the w55 and w59 anyone know about these?
wilbo666
Re: W57 5-speed transmission Mon, 10 November 2003 23:01 Go to previous messageGo to next message
Goto this link ..here.. add you will find that the only difference is 5th gear (not second as well). It also has the ratios for W55 / W5 and others.
Sorry for the hijack norbie....
sprinterboy4agze
Re: W57 5-speed transmission Mon, 10 November 2003 23:24 Go to previous messageGo to next message
so whats the differ between w55 and w57, which would be the best gearbox for using in a sprinter with a 4agte setup?
sorry for posting this question up here norbie just thought while the discusiion on w gearboxes are goin on i could get this question out Smile
wilbo666
Re: W57 5-speed transmission Tue, 11 November 2003 01:49 Go to previous messageGo to next message
type reverse I II III IV V
T50 -3.484 3.587 2.022 1.384 1 0.861
W55 -4.091 3.566 2.056 1.384 1 0.850
W57 -3.768 3.285 1.894 1.275 1 0.861
W58 -3.768 3.285 1.894 1.275 1 0.783
Aside from the ratios I believe W55's and W57's to be the same? (They both have alloy cases and alloy sandwich plates, so they look the same from the outside (Pretty sure that they are externally the same anyway), I'll take some pictures comparing a W55 to a W57 at some stage....).
The W55 ratios are very similar to the T50 ratios so expect it to be close to the same, just stronger.
(Poor norbie Confused) Is it possible to get all the tech stuff in this thread moved into the tech section?? (admin guys Razz)
[Updated on: Tue, 11 November 2003 01:50]
Re: W57 5-speed transmission Tue, 11 November 2003 05:52 Go to previous messageGo to next message
Screw you guys, I'm going home!! Razz
But before I do, someone asked about the price: I was thinking around the $250 mark.
Steve-AE86
Ademelaide, SA
Re: W57 5-speed transmission Tue, 11 November 2003 08:35 Go to previous messageGo to next message
how's $200 sound?
pm me..
steve
Cyber-punk
Brisbane, QLD
Re: W57 5-speed transmission Thu, 13 November 2003 02:40 Go to previous messageGo to next message
argh!!!
i would of jumped at this....if i didnt have to fork out $600 yesturday on a BHG Sad
stupid poopra, soooo gonna rip into the dickhead who did my rebuild(and my dad for "making" me get a rebuild)
Steve-AE86
Ademelaide, SA
Re: W57 5-speed transmission Thu, 13 November 2003 07:05 Go to previous messageGo to next message
offer is still on the table...all you thread hi-jackers... Laughing Laughing Laughing
Re: W57 5-speed transmission Thu, 13 November 2003 12:27 Go to previous messageGo to next message
Box has been sold for $250. Thanks anyway.
GTStar
W.A.
Re: W57 5-speed transmission Thu, 13 November 2003 15:35 Go to previous messageGo to next message
so which one's stronger? the w57 or w58 ?
SupraPete
Re: W57 5-speed transmission Thu, 13 November 2003 22:39 Go to previous messageGo to next message
Norbie: How do you know its a W57, and not a W58? What did it say on the plate in the engine bay?
Jaze: I actually used a 22RE engine from a celica, the plate in the engine bay said it had a W58, but also it looked like a W57.
Re: W57 5-speed transmission Thu, 13 November 2003 23:57 Go to previous messageGo to next message
In theory the W58 should be stronger dude.
Re: W57 5-speed transmission Fri, 14 November 2003 00:32 Go to previous messageGo to next message
Pete: I'm assuming it's a W57 since it has an alloy sandwich plate, but I never saw the build plate on the donor car so I don't know what the code was.
Dabbid
Yowie Bay, Sydney
Re: W57 5-speed transmission Sun, 16 November 2003 04:09 Go to previous message
well it was i who had the gz20 soarer cut that jaze mentioned
with my g'box sitting next to 2 other w58's, there was no difference to be seen
i cant see how a w58 could be stronger, since i'f got a quote to change 5th gear ratio and make it 'exactly' the same...
Previous Topic:Woodgrain MOMO steerer
Next Topic:1GGTE FOR SALE $550
Current Time: Wed Oct 21 02:56:44 UTC 2026
Total time taken to generate the page: 0.0071620941162109 seconds
