Toymods » Tech & Conversions » RA40 Struts Vrs AE86
Simon-AE86
Banned user
ADELAIDE - The Drift City
RA40 Struts Vrs AE86 Mon, 10 November 2003 14:14 Go to next message
Can someone who KNOWS please tell me exactally what are the differences between the two struts? Is the RA40 stub axle angle the same as the AE86? Does putting the RA40 struts in change the steering geometry in ANY way? If so what does it do?
I have RA40 struts atm and i have a handling problem that for the life of me i cant put my finger on as to what it is....
Im well aware of the fact that RA60 struts have the camber problems and so forth... and they are different to RA40 items.
So... fire away.
gold28
Madrid - Spain
Re: RA40 Struts Vrs AE86 Mon, 10 November 2003 23:34 Go to previous messageGo to next message
How much lower than standard is it. You may find that you have bump steer combined with crazy roll centre movements. Well thats my problem anyway.
Simon-AE86
Banned user
Re: RA40 Struts Vrs AE86 Tue, 11 November 2003 01:20 Go to previous messageGo to next message
I have roll center adjusters, bump steer and roll center isnt what im talking about... those issues are solved.
so does anyone know about the struts?
Re: RA40 Struts Vrs AE86 Tue, 11 November 2003 01:28 Go to previous messageGo to next message
Long as you haven't done what I was once guilty of, fitted one power steering arm and one manual arm - certainly never quite felt right, and did amazing things to one front tyre.... Twisted Evil
Simon-AE86
Banned user
Re: RA40 Struts Vrs AE86 Tue, 11 November 2003 01:39 Go to previous messageGo to next message
haha nah i havent done that,
do you know what its like with both power steer arms tho?
Simon-AE86
Banned user
Re: RA40 Struts Vrs AE86 Tue, 11 November 2003 03:53 Go to previous messageGo to next message
someone must know the answer
gold28
Madrid - Spain
Re: RA40 Struts Vrs AE86 Tue, 11 November 2003 03:59 Go to previous messageGo to next message
A little more help with the problem might make it easier.
Do you know what your camber angle is???
Simon-AE86
Banned user
my prob Tue, 11 November 2003 04:49 Go to previous messageGo to next message
ok my ae86 suffers a lack of ae86 turn in feel!
Ive driven a few other modded ones and mine lacks the turn in feel that they all have. I have RA40 struts with ra65 control arms (longer) camber is about 2 degrees neg, maybe slightly under.
coilovers with 6kg/mm springs, 80mm lowered and 40mm roll center adjusters
Re: RA40 Struts Vrs AE86 Tue, 11 November 2003 06:18 Go to previous messageGo to next message
Aukerman - sorry spelt wrong i know.. But doesn't this effect turn in?
Necros
Re: RA40 Struts Vrs AE86 Tue, 11 November 2003 10:38 Go to previous messageGo to next message
Im running RA60 struts/lower arms with the power steering nuckle arms...
The steering is heavier and noticibly sharper.... Much easier and quicker to apply opposite lock on my favorite hairpin Smile
Oh forgot to mention, the drive to the suspension shop for a wheel alignment will be a little on the darty side eheheh
[Updated on: Tue, 11 November 2003 10:44]
Re: RA40 Struts Vrs AE86 Tue, 11 November 2003 10:43 Go to previous messageGo to next message
I'm 99% sure the RA40 has larger stub axles Rolling Eyes
Necros
Re: RA40 Struts Vrs AE86 Tue, 11 November 2003 10:45 Go to previous messageGo to next message
The RA40/RA60/MA61 etc all have the same larger (compared to the AE86) axles...
gold28
Madrid - Spain
Re: RA40 Struts Vrs AE86 Wed, 12 November 2003 00:01 Go to previous messageGo to next message
Ackerman angle will only make a difference if the wheel base to wheel track is significantly different between the sprinter and the celica. Obvoiusly yout front track will be different to a normal sprinter because you are using different lower control arms.
You seem to be using a lot of camber for a road car, maybe that has something to do with it.
Re: RA40 Struts Vrs AE86 Wed, 12 November 2003 00:19 Go to previous messageGo to next message
What sort of caster you running?
And power steering arms sure do help out with the steering, a must for any car Evil or Very Mad
drifter4ag
Auckland
Re: RA40 Struts Vrs AE86 Wed, 12 November 2003 03:21 Go to previous messageGo to next message
Yo
not sure if they are the same but i am using Ta63 Corona struts and vented discs etc
spacing for it to bolt onto steering arm is 90mm as opposed to ae86 85mm or there abouts. As soon as installed camber went to shit and i had to run a 140mm (hole to hole) steering arm ..this setup felt sloppy and uninspiring ..but i managed to get my hands on some 120mm steering arms which are only 5mm longer than the GTV ae86 ones.
And to correct the camber problems i welded 1.5inches of box section into my ae86 lower arms which gave me about 2.5deg NEG and the same amount of track either side .i am running no roll center adjuster
Re: RA40 Struts Vrs AE86 Wed, 12 November 2003 04:26 Go to previous messageGo to next message
How hard is it to find these power steering arms?
Youngy
Eskilstuna, Sweden
Re: RA40 Struts Vrs AE86 Thu, 13 November 2003 02:46 Go to previous messageGo to next message
Hi Simon,
Lack of turn in response does sound like a problem with the amount of castor you are running. I myself run 2 degress front neg camber (IMHO not too much for a street car, hard on tires maybe - but something has to sacrifice itself to the Gods of handling) and in order to get good turn in feel I am running as much castor as I can.
Which on the 86 can be dialled in easily as the factory castor rods are adjustable (on some vehicles they are not).
Hope you find that helpful
3sglevin
Re: RA40 Struts Vrs AE86 Thu, 13 November 2003 03:07 Go to previous messageGo to next message
Hi Simon,
I race a sprinter in Improved production and run RA40 struts, as far as I could tell once they where fitted there was not affect on the wheel alignment whatso ever, the main reason I did it was hoping for some more neg which didnt happen and secondly for a stronger stub axle, and bigger wheel bearings!
what shocks are you using and how old are they?
Jayem
Finland
Re: RA40 Struts Vrs AE86 Sun, 16 November 2003 19:28 Go to previous message
Im not going to comment to that 80mm part but if I understand right it sounds like your scrub radius is out.
I think that your wheel track is wider than lenght between right and left srub radius points. Factors that affect to scrub radius are wheel offset, tire diameter, kingpin inclination, lenght of lower control arm, eccentric bushes and adjustable strut tops(last two if you have those!?).
BTW. If your wheel track is narrower than lenght between right and left srub radius points, your car will be sooo scary to drive.
Previous Topic:Few 18R-C Questions
Next Topic:Convertible RA40
Current Time: Sat Oct 31 09:27:49 UTC 2026
Total time taken to generate the page: 0.010458946228027 seconds
