Toymods » Tech & Conversions » Next project...
biased99
Next project... Mon, 10 November 2003 22:28 Go to next message
I'm thinking of putting one of these http://www.bath.ac.uk/~ccsshb/12cyl/ into a KE10...
Are there likely to be any "technical difficulties"? Laughing
Danners
Central Coast, NSW
Re: Next project... Mon, 10 November 2003 22:32 Go to previous messageGo to next message
hahaha
thats biggest engine i've ever seen
Dan
Re: Next project... Mon, 10 November 2003 22:36 Go to previous messageGo to next message
Just imagine the power you'd make with that torque if you put a cam in it and made it rev out to 500rpm Evil or Very Mad
Re: Next project... Mon, 10 November 2003 22:38 Go to previous messageGo to next message
Actually, I just worked it out - if you made the same torque at 500rpm, you'd have 533921 horsies. And at 1000rpm there'd be 1067843 of phar lap - you might want to look at a diff/gearbox upgrade, and some reasonable tyres to help traction. What did the engineer say? Twisted Evil
Re: Next project... Mon, 10 November 2003 22:42 Go to previous messageGo to next message
you would definitely need to upgrade to the KE55 borg warner, and you might need to put some "wynns gearbox saver" into your K40 box.
You might also need to upgrade your fronts to AE71 brakes, and you will definitely need a sticker of some sort.
Other than that.. no worries mate.
Lambolica
Northwestern Sydney
Re: Next project... Mon, 10 November 2003 22:56 Go to previous messageGo to next message
You may also need a bigger fuel tank as the standard one may not get you to any servos greater than say 3km apart.
Go to a BP wrecker and pick up one of those big cylindrical style "tow" tanks with extra wheels. Very Happy
Skip
Re: Next project... Mon, 10 November 2003 23:26 Go to previous messageGo to next message
I notice the flywheel (i think it is anyway) has a ring gear attached. Id like to see the starter motor Shocked. I thought engines like these are air started?
Lambolica
Northwestern Sydney
Re: Next project... Mon, 10 November 2003 23:31 Go to previous messageGo to next message
I beleive the starter is in fact a Chev 454 Razz
ChaserJZX100
melbourne
      wtf is a jabber handle
icon6.gif  Re: Next project... Mon, 10 November 2003 23:36 Go to previous messageGo to next message
i've already done this conversion into a AE86 it was a tight fit but worked out great, im think of forced induction now Laughing Laughing Laughing Laughing Laughing Laughing
Re: Next project... Tue, 11 November 2003 01:29 Go to previous messageGo to next message
Wait'll you see the size of his intercooler...
biased99
Re: Next project... Tue, 11 November 2003 02:23 Go to previous messageGo to next message
Thanks for the replies.
In all honesty, I was a bit worried initially, as I thought it "may" be a bit high for the engine bay of the 'Rolla. That, and the fact that it could mildly affect the handling...But having read the post about the AE86 conversion (and I take this at proper "face value"), I am reassured that it is a good conversion to do.
Karl, re: the upgrade comments you made, I'm a little confused as to the most important point you raised:
Exactly what type of sticker should I get to make the project work? Should I get more than one? Is it O.K to mix and match brands, such as Greddy, TRD, Mugen, Type R etc? (It's really important that it passes engineering first time 'round!)
As for tyres, I was planning on upgrading to a set of 175/65R14s all-round. Will they provide the required traction? Or is this overkill, and should I perhaps go for something "saner"?
Re: Next project... Tue, 11 November 2003 02:31 Go to previous messageGo to next message
some say that one is enough, but thats only if you get an engineer from penrith, im which case you will definitely need a ford/holden/mopar/"ute" type of sticker.
Anywhere else and the more the merrier, only being sure to avoid previously mentioned names. TRD mixed with MUGEN is good, maybe with the odd HKS here and there to create special "structural points", like across the bonnet to the front guard.
Tyres - for this conversion, the 14" are waaaay too big. Sick with the TRD 12" "Steelies", and some 145 rubber to really lay some phat treads.
Don't forget fixed reclined seats - they are a MUST with any conversion.
ChaserJZX100
melbourne
Re: Next project... Tue, 11 November 2003 02:43 Go to previous messageGo to next message
well if you need it engineered i'll be able to do it for $5, just wait a year until my course is finished! Cool
oh and for stickers the TRD added 50kw but the mugen and type-R only added .05kw together
biased99
Re: Next project... Tue, 11 November 2003 03:40 Go to previous messageGo to next message
O.K.
Project is now "taking shape"
I know I need the following items.
1 x KE10 Corolla
2 x permanently reclined bucket seats (Can you get these pre-done at different "lean angles" - I'm trying for a really cool, laid-back look; say 75 degrees?)
4 x 12" steel wheels (great cost-saving here, as these are OEM fitment, allowing retention of OEM brakes...Engineer should have no worries there).
4 x 145 tyres (pref cross-ply) for the ultimate in all-round performance - ie. street/strip.
A number of stickers (TRD predominantly, as these apparently add more power than most others combined! Shocked )
A sticker for the back window which reads "Get in, sit Down, shut up, and hold on" (Much like the many Excel performance cars one sees around).
Now, am I right in thinking the standard drive-line components will be up to the job? ie. K40 gearbox, borg warner rear end etc? Or should I go all out and source some top-quality, unbreakable parts, such as those fitted to, for example, VN Commodores or EA falcons?
(Damn, this thing is so close to being done I can almost taste it!)
ChaserJZX100
melbourne
Re: Next project... Tue, 11 November 2003 05:22 Go to previous messageGo to next message
Shocked well from hear say ive heard that the 03excel GLi gear box is pretty strong, ive seen an excel with a BIG drift wing 4inch tip and covered in stickers, so it must be able to hold its own in power! try to source one of these im cruntly using a 5spd from a hyundai accent! Laughing Laughing
Jason
Re: Next project... Tue, 11 November 2003 07:19 Go to previous messageGo to next message
To help with the weight distribution i propose that you relocate the battery to the boot im sure that Karl can help you out with the electrics and some new speaker wire for the leads to the engine.
Re: Next project... Tue, 11 November 2003 08:34 Go to previous messageGo to next message
ChaserJZX100 wrote on Tue, 11 November 2003 10:36
heh heh, it's alreay turbocharged, but you could twin charge it Very Happy
hmm, regarding those 4.5" rims, do you think that the increase in weight from 0.7 tons to ..... 2300.7 tons would allow you to go bigger than 6" wide rims?? Cool
ypu might need a small 'power bugle' on the bonnet also....
Re: Next project... Tue, 11 November 2003 22:10 Go to previous messageGo to next message
What sized exhaust tip are you gonna run on it?
And you might want to upgrade the alternator, you're gonna have a fair bit of power draw with the necessary neons
Re: Next project... Tue, 11 November 2003 23:14 Go to previous messageGo to next message
Weight distribution shouldn't be an issue, so long as you mount The Most Fuli Sik Aww Mah Gawd sound system in the boost, I mean boot..
Jag7799
Re: Next project... Tue, 11 November 2003 23:22 Go to previous message
seen that page like 50 times now
Previous Topic:R33 Insurance
Next Topic:what next for the 7mgte?
Current Time: Thu Oct 22 03:56:36 UTC 2026
Total time taken to generate the page: 0.0059258937835693 seconds
