Toymods » Tech & Conversions » Want to Know AIRCON FOR AE86
siggy
Want to Know AIRCON FOR AE86 Tue, 11 November 2003 12:20 Go to next message
Hi everyone ...
supposely I'm currently finding an air con for my AE86...
But I'm not so sure what I need for air con and fan, since I do not have both in my ae86.
MY ENGINE IS 4AGE
Can anybody help me out with this ... maybe list out the parts I need to get an aircon and fan for my ae86.
Every reply is very helpful of you
Regards
Sig
[Updated on: Wed, 12 November 2003 08:07]
CLG
Perth, Western Australia
Re: Want to Know AIRCON FOR AE86 Tue, 11 November 2003 16:16 Go to previous messageGo to next message
The fan and aircon units "join together" under the dash. to install, you need to mount the fan and the aircon, to the captive nuts already in your firewall, then connect the vent controls and aircon switches both to and from the units and dash control area. you'll also need an auto electrician to run power to your aircon switch as the wires are impossible to trace (they go to the junction box by the steering column). If you are lucky and have an aircon unit originally in your car, you may have plugs to simply connect to, for both the fan and aircon.
In the engine bay, you need to mount the condenser (radiator) in the front, and run the lines to and from both the air con unit and the compressor (which you will have to mount to the engine). You'll also need to replace the Dryer (by the condenser), as these items are rendered inoperative by atmosphere once exposed. Then install the belt and tensioner, and finally have the system checked and gassed by an auto electrician.
So the list stand at:
under dash aircon unit
electrical connections and switches for aircon unit
fan unit
electrical connections and switches for fan unit
hoses and pipes for compressor and condensor
condensor (radiator)
dryer (new)
compressor
belt and tensioner
electrician to gas system!
shinybluesteel
melbourne
Re: Want to Know AIRCON FOR AE86 Tue, 11 November 2003 22:44 Go to previous messageGo to next message
if you are in melbourne (and you are runnign a 4ac) you can have my old aircon bits if you want, i took it out ages ago.
siggy
Re: Want to Know AIRCON FOR AE86 4AGE Wed, 12 November 2003 08:05 Go to previous messageGo to next message
Hello Clinton
According to the list, these are the parts I need. Do you have these parts avaliable ? My engine is a 4age
fan unit
dryer (new)
compressor
belt and tensioner
CLG
Re: Want to Know AIRCON FOR AE86 4AGE Thu, 13 November 2003 03:12 Go to previous messageGo to next message
under dash aircon unit: YES
electrical connections and switches for aircon unit: YES
fan unit: YES
electrical connections and switches for fan unit: YES, i HAVE ALSO SENT YOU THE FAN CONTROLS PREVIOUSLY, BUT YOU MAY NEED THE ACTUATING RODS?
hoses and pipes for compressor and condensor: I HAVE ALL ALUMINIUM PIPES, AND FLEXIBLE PIPES TO SUIT A 4AC COMPRESSOR
condensor (radiator): YES
dryer (new): NO, THE ELECTRICIAN THAT GASSES THE SYSTEM CAN SUPPLY ONE WHEN HE COMPLETES THE GASSING
compressor: CURRENTLY ONLY HAVE 4AC, AND 4AGZE COMPRESSORS, THEY WILL NEED TO BE MODIFIED TO SUIT YOUR 4AGE (BELT PULLEYS ARE DIFFERENT)
belt and tensioner: YES, BUT AGAIN WILL NEED MODIFYING TO SUIT THE BELT
electrician to gas system!: YES, BUT I DON'T THINK HE'D LIKE BEING WRAPPED UP AND POSTED?!!!
Satoshi
Re: Want to Know AIRCON FOR AE86 Fri, 14 November 2003 12:03 Go to previous messageGo to next message
what about ae86 with 4ac??
i want aircond but i might be doing my conversion engine conversion after summer...so can i still use the one on the 4ac unto the 4ag or its totally different?
siggy
Re: Want to Know AIRCON FOR AE86 Wed, 19 November 2003 07:49 Go to previous message
bump ... clinton sorry about all the waiting .... I 'll get back to you asap!
Previous Topic:Structural Optimisation of an Automotive Wheel
Next Topic:20v t/b onto 100kw 4age running 100kw ecu?!
Current Time: Sat Oct 17 18:45:17 UTC 2026
Total time taken to generate the page: 0.0053858757019043 seconds
