Toymods » Tech & Conversions » Clutch for 4agze
AE82TwinCam
Canberra, ACT
Clutch for 4agze Wed, 12 November 2003 05:00 Go to next message
Hey guys, my current clutch's days are numbered and I am wanting to upgrade when I have to chuck a new one in (its oem atm) so I'm just looking for some guidence.. its a 3rd gen 4agze mated to a 20valve gearbox.
Any opinions? I'm not really strapped for cash but I also don't want to waste money on smoething that I don't need. I don't plan on modding it any further past what it is (stock boost with exhaust and filter)
Some phone numbers would be appreciated, I'm in canberra so that is preferable but sydney is ok as well.
-Andrew
[Updated on: Wed, 12 November 2003 05:02]
NickAE86
Brisvegas
Re: Clutch for 4agze Wed, 12 November 2003 05:31 Go to previous messageGo to next message
what clutch have you got atm...standard organic?
my old gze had a 3 puck button clutch...a little annoying to get used to at 1st as you'll find the clutch is either engaged or it isnt Smile button clutch is a little harder to ride when it comes to the around town stuff but the advantage is when you wanna give it some it will bite...no slip whatsoever...& depending how you drive it will last around 6-12 months
button wont be as "heavy" as a heavy duty clutch with a large sized pressure plate
AE82TwinCam
Canberra, ACT
Re: Clutch for 4agze Thu, 13 November 2003 01:50 Go to previous messageGo to next message
hmm I'm not sure I want to go as hardcore as a 3 puck clutch Smile what clutch types are there these days? and the 20valve box uses the exact dimensions a regular 4age does right? As in flywheel and clutch sizes... I'm not shy of going custom either
-Andrew
[Updated on: Thu, 13 November 2003 01:55]
feral4mr2
Bundaberg, Qld.
Re: Clutch for 4agze Thu, 13 November 2003 08:11 Go to previous messageGo to next message
Freak i am having a really good run with a Daikin organic clutch plate. and i had the fulcrum points moved on my old pressure plate to give it more clamp pressure.
this is on a 4agte running a low 7psi.
NickAE86
Brisvegas
Re: Clutch for 4agze Thu, 13 November 2003 08:25 Go to previous messageGo to next message
if you go organic wont you find that you'll need a larger pressure plate (1tonne+) otherwise you'll be changing the clutch every 2 months?
you've gotta weigh up the pro's and cons.
standard disc/HD pressure plate too heavy, not really suited to prolonged abuse...wears out quicker
3 puck brass button solid centre too grabby, no good for a daily driver but you will get used to it...good for 4k launches Evil or Very Mad
im not sure but i think you can get some sort of a hybrid 5puck brass/ceramic clutch disk and slightly larger pressure plate and get the best of both worlds...cant you???
FLYNSX
    flyn
Re: Clutch for 4agze Thu, 13 November 2003 10:40 Go to previous messageGo to next message
cardures clutch east maitland i got mine, semi ceramic $475 with machining flywheel and 4 new douls in the flywheel iam running a 20v lsd gear box as well best clutch i have had grips hard but easy on the foot when changing gears.
AE82TwinCam
Canberra, ACT
Re: Clutch for 4agze Thu, 13 November 2003 13:48 Go to previous message
Thanks peeps, I'll have a chat to cardures about my options tomorrow Smile
-Andrew
Previous Topic:TA23 Head Lights
Next Topic:interccooler q
Current Time: Mon Oct 26 17:03:08 UTC 2026
Total time taken to generate the page: 0.0050680637359619 seconds
