Toymods » Tech & Conversions » ta22 diff ratios??? are there any
ta2272
ta22 diff ratios??? are there any Wed, 12 November 2003 07:31 Go to next message
hey wanting to get some different ratios for my stadard ta22 diff are there any other centers which will fit.
jason
ra23celica
Re: ta22 diff ratios??? are there any Wed, 12 November 2003 07:46 Go to previous messageGo to next message
I think you are stuck with the std 3.9 and 4.1 ratio T series centes. You might be able to get a D series diff, but its smaller that a T series and the ratio's are the same anyway.
Go and build up a nice strong F series or G series Hilux axle and that will open up a whole lot of ratio's choices.
Mitch.
ta2272
Re: ta22 diff ratios??? are there any Wed, 12 November 2003 07:51 Go to previous messageGo to next message
which one of these is faster acceleration and how do i tell which one i got..
JAson
ra23celica
Re: ta22 diff ratios??? are there any Wed, 12 November 2003 07:57 Go to previous messageGo to next message
4.1 and above gives you greater acceleration at the expence of top end, while 3.9 and below are slow off the line but give a higher top speed. General rule of thumb is that you want a 3.7 or 3.9 for your Turbo car, and 4.1 or 4.3 for your Atmo car.
You can check by telling us what's on your car's build plate (all the numbers and letters) or by jacking up the rear of the car and counting how many times the tailshaft turns for one turn of the wheels.
Mitch.
ta2272
Re: ta22 diff ratios??? are there any Wed, 12 November 2003 08:02 Go to previous messageGo to next message
the reason why i want it is because im going up a hill climb? next year at the moment im only using 2nd and just touching third so i would like to be using more gears what ratio would be better for this.
Jason
in other words i want to be going the same speed but be in third touching 4th
ra23celica
Re: ta22 diff ratios??? are there any Wed, 12 November 2003 08:05 Go to previous messageGo to next message
Then you want 4.1 as a minimum, and 4.3 to 4.5 would be best, or a 4.9 (Hilux) ratio would be extreme and you will be doing 5000rpm with 100km/h on the clock in 5th gear.
(Exaggerated but you get my meaning).
Mitch.
ta2272
Re: ta22 diff ratios??? are there any Wed, 12 November 2003 08:08 Go to previous messageGo to next message
alright then well were would i find a 4.3 or a 4.5 would a 4.3 make much difference.
JAson
i need it to fit the ta22 diff i just need a center
ra23celica
Re: ta22 diff ratios??? are there any Wed, 12 November 2003 08:10 Go to previous message
You won't find any alternative ratio's to fit a T series diff, you are limited to 3.9 or 4.1. That's why you have to swap in a complete Hilux axle before you can start looking at alternative diff ratio's.
Mitch.
Previous Topic:question on sprinter
Next Topic:AE86 Drift setup?
Current Time: Sun Oct 25 08:05:20 UTC 2026
Total time taken to generate the page: 0.070565223693848 seconds
