Toymods » Tech & Conversions » AE86 Clutch Cylinder
NickAE86
Brisvegas
icon4.gif  AE86 Clutch Cylinder Wed, 12 November 2003 07:48 Go to next message
Hey guys
I've got a mate with an aus spec sprinter which has shat its clutch master cylinder.
What can you guys recommend in the way of a replacement. Would it be cheaper to recondition it?
If its to be replaced is there anything that it can be swapped for with minimal fuss....i've heard you can use the AE82/AE71 and possibly some old celicas ie:ra23 but i dont know how reliabe this info is
Whats involved in the changeover process?
Any help would be greatly appreciated
Cheers Very Happy
Nick
Re: AE86 Clutch Cylinder Wed, 12 November 2003 23:34 Go to previous messageGo to next message
I recently brought one from Auto Pro.. $70 I think it was. No need to hunt for ones from different cars. The Sprinter one is readily avaliable.
But mind you I brought a RA28 one recently and I think its identical.
Easy enough to change. 2 bolts/nuts hold it to the firewall and a split pin setup through the clutch peddle.
Worst part is bleeding it after changing it Razz
NickAE86
Brisvegas
Re: AE86 Clutch Cylinder Thu, 13 November 2003 01:35 Go to previous messageGo to next message
thanks mate
Youngy
Eskilstuna, Sweden
Re: AE86 Clutch Cylinder Thu, 13 November 2003 02:36 Go to previous messageGo to next message
Yeah I got a new master cylinder for the clutch from PBR. Easy thing to do - just remember to use the old plunger (bit that connects to the clutch pedal and pushes in the master cylinder piston) as it is already set to the right length.
I think this master cylinder was used by Toyota in a whole lot of models!
Re: AE86 Clutch Cylinder Thu, 13 November 2003 10:19 Go to previous message
Yeah, it's a pretty standard part the 5/8 master cylinder, I pulled mine out today and noticed it's been leaking heaps.
Previous Topic:interccooler q
Next Topic:rust removal
Current Time: Mon Oct 26 01:51:55 UTC 2026
Total time taken to generate the page: 0.0040140151977539 seconds
