Toymods » Tech & Conversions » 2tg cam chain tensioner
ta2272
2tg cam chain tensioner Wed, 12 November 2003 08:20 Go to next message
hey im putting my 2tg in my car this weeknd just a few thing i need to finish off, i havnt tigtened up the cam chain tensioner how tihgt do i do this any othere things i need to know thanks.
Jason
blackRA28
adelaide
Re: 2tg cam chain tensioner Thu, 13 November 2003 00:23 Go to previous messageGo to next message
Is it a new chain/timing guides?? if so, it should be mighty tight already with the tensioner all the way out...
If you are using older/pre-used ones justr tighten the tensioner i guess until there is no slack at all in the chain, and its not going to move off the gears whatsoever.
sorry could not be more precise...
ta2272
Re: 2tg cam chain tensioner Thu, 13 November 2003 03:01 Go to previous messageGo to next message
what about going to tight
hemi twofifteen turbo
Re: 2tg cam chain tensioner Sat, 15 November 2003 01:26 Go to previous messageGo to next message
too tight puts extra/excessive pressure on the cam idler shaft bearings and the cam shaft sprocket bearings in the head.
Won't do anything though, except your chain would stretch.
Just make it tight, but not too tight!!
juzzo84
Hornsby, N.S.W
Re: 2tg cam chain tensioner Sat, 15 November 2003 02:14 Go to previous message
heya jas, you have to be careful with these, they are easy to overtighten and the tread in the tensioner will snap!!! i learned from experiance!!! so please be carefull when you do it, and dont forget, that extra tension is put onto the chain through the tensioner when the engine is running due to engine oil pressure active in the tensioner!!!
Justin
Previous Topic:conversions
Next Topic:Hilux engine
Current Time: Mon Oct 26 01:51:49 UTC 2026
Total time taken to generate the page: 0.0041079521179199 seconds
