Toymods » Tech & Conversions » KE30 front strut + shock upgrade
_555_
SOR, Perth
KE30 front strut + shock upgrade Thu, 13 November 2003 03:47 Go to next message
I want to upgrade my old KE30 front strut with
gas shockies and bigger discs, as I am wanting to rally it.
What sort of options do I have?
Will the AE86 struts fit without too much trouble
and if so can they be upgraded to gas shocks?
Thanks.
CLG
Perth, Western Australia
Re: KE30 front strut + shock upgrade Thu, 13 November 2003 05:54 Go to previous messageGo to next message
Grab some Celica struts and use them I've used RA40 stuff regularly, but you could use anything after mid 1973). While you have the struts out, reinforce the chamber, and triangulate the stub axle area, as you will bend these on the first stage! The AE86 struts are smaller and therefore weaker than the Celica items.
_555_
SOR, Perth
Re: KE30 front strut + shock upgrade Thu, 13 November 2003 09:05 Go to previous messageGo to next message
Thanks for the info!
BTW, I may sound dumb but what do you mean by "triangulate the stub axle area"?
CLG
Re: KE30 front strut + shock upgrade Thu, 13 November 2003 14:49 Go to previous messageGo to next message
Cut and weld Triangular pieces of steel into the stub axle to strut area (a Triangle is the strongest shape you can make). you'll also need to weld Corolla sized spring mounts onto the strut as the Celica one's will be too big for the strut tower.
_555_
SOR, Perth
Re: KE30 front strut + shock upgrade Thu, 13 November 2003 15:05 Go to previous messageGo to next message
OK you lost me, were exactly is the stub axle?
Do you mean weld triangle pieces from the strut tower to the chassis or on top of the tower?
CLG
Re: KE30 front strut + shock upgrade Thu, 13 November 2003 15:09 Go to previous messageGo to next message
You need to buy a workshop manual and start reading. The stub axle is at the bottom of the strut and is the spindle that the wheel bearings run on. You'll need to take the rotating parts of the assembly into account when adding the gussets, or pay someone to do it for you (hint nudge wink!).
_555_
SOR, Perth
Re: KE30 front strut + shock upgrade Thu, 13 November 2003 17:30 Go to previous messageGo to next message
Now I understand, But were exactly would the triangular pieces fit on the stub axle?
CLG
Re: KE30 front strut + shock upgrade Fri, 14 November 2003 00:59 Go to previous messageGo to next message
Best option for you would be to rock up to one of the local rallies and start asking questions, the downside to this step being the lack of rallies at this time of year?! Plenty of guys here in Perth are running Corollas in many different classes, and a multitude of budgets. Call CAMS for rally details, and dates.
rotorace
Re: KE30 front strut + shock upgrade Fri, 14 November 2003 01:13 Go to previous messageGo to next message
Sorry for stealing the thread, but clintgodde, would you know which celica struts can be fitted to a ke20? and 555 i have a magazine with a ke30 which uses ra60 front struts and brakes, but you will have to do the strut top and spring seat switch.
_555_
SOR, Perth
Re: KE30 front strut + shock upgrade Fri, 14 November 2003 02:04 Go to previous messageGo to next message
"i have a magazine with a ke30 which uses ra60 front struts and brakes, but you will have to do the strut top and spring seat switch."
is the strut top and spring seat switch difficult?
BTW thanks for the info clintgodde and rotorrace!
_555_
SOR, Perth
Re: KE30 front strut + shock upgrade Fri, 14 November 2003 05:00 Go to previous messageGo to next message
I think checking out other peopes rally cars is a good idea
I might do that the next chance I get.
CLG
Re: KE30 front strut + shock upgrade Fri, 14 November 2003 06:02 Go to previous messageGo to next message
RA40 struts go into a KE20 without too much drama, and checking out other people's cars and seeing how they perform is a good free way to work out what works, and what doesn't.
_555_
SOR, Perth
Re: KE30 front strut + shock upgrade Fri, 14 November 2003 09:04 Go to previous messageGo to next message
Are the RA60 front shocks gas or able to be gas?
as this is why I need the change my current front struts.
EMP-2TG
Carlingford, Sydney
Re: KE30 front strut + shock upgrade Sat, 15 November 2003 00:00 Go to previous messageGo to next message
u could always do the corona strut, pug disk and hilux caliper if u want abit more stoping power
this is my setup in my KE30
http://www.geocities.com/emp_emp2000/coilovers.txt
Steve-AE86
Ademelaide, SA
Re: KE30 front strut + shock upgrade Sat, 15 November 2003 07:08 Go to previous messageGo to next message
hey...just looking through this thread...
i've come to realise...clintgodde seams to be a pretty switched on kinda fella...
why dont _555_ go and see clintgodde...and clintgodde could explain to him, and show him, exactly what he's talking about.
i mean... you both live in Perth, and Perth aint that big of a place...(i used to live near Midland Cool and Kelmscott Cool )
maybe even clintgodde could make _555_ some struts up, for a fee, of course..???
dont mean to put you in the shit, clintgodde... Very Happy Very Happy Very Happy
if _555_ wants to pay for postage, i could go and buy some struts, and modify them...etc...
_555_
SOR, Perth
Re: KE30 front strut + shock upgrade Sun, 16 November 2003 06:09 Go to previous messageGo to next message
Thanks for the advice guys, for now since I'm just starting out in rallying I will probably just get some gas inserts for the front struts. Then later on think about investing in some more appropriate gear. BTW what gas inserts do you guys recommend for the front?
At the moment I am running standard leaf springs with KYB gas shocks in the back, what would be a good cheapish set up for the front shock/spring wise? (I have heard that KYB are good and not too expensive for starters.)
[Updated on: Sun, 16 November 2003 06:15]
CLG
Re: KE30 front strut + shock upgrade Mon, 17 November 2003 03:02 Go to previous messageGo to next message
toyotaboy wrote on Sat, 15 November 2003 15:08
Yep, I could do all that, however you seem to forget that Perth is full of people who say one thing and fail to do it, or do something else after organising it. At the end of the day, I don't care about those type of people - I'm busy with toys of my own!
mark-ke30
Eindhoven
Re: KE30 front strut + shock upgrade Tue, 15 March 2005 16:27 Go to previous messageGo to next message
I'v got a ke30 myself and I can get struts of a ma60 (Celica Supra) Will these fit right into my corolla, or are they too long (total of 77cm/30.3 inch)??
Thnx
Mark
Steve-AE86
Ademelaide, SA
Re: KE30 front strut + shock upgrade Thu, 17 March 2005 07:37 Go to previous messageGo to next message
ma60 struts would also require ma60 steering arms/ackerman arms.
the bolt spacing on the bottom of the strut to bolt to the steering arms is different, about 5mm more on the ma60 than ke30.
mark-ke30
Eindhoven
Re: KE30 front strut + shock upgrade Thu, 17 March 2005 13:25 Go to previous messageGo to next message
So if I get the steering arms/ackerman arms with, I can put the struts under the ke30.
And is the ma60 strut longer than the ke30 one, or shorter???
Because I want a cheap unograde to lower my ke30, i hope the ma60 struts will lower it by far.
Mark
EMP-2TG
Carlingford, Sydney
Re: KE30 front strut + shock upgrade Thu, 17 March 2005 13:52 Go to previous messageGo to next message
it will raise it, and the fact the springs wont fit in the strut tower may cause some issues
mark-ke30
Eindhoven
Re: KE30 front strut + shock upgrade Thu, 17 March 2005 14:45 Go to previous messageGo to next message
allright than, I wont buy these things..
And ta22 and ae86 struts, will also raise???
Mark
Johnny
Sydney, OZ
Re: KE30 front strut + shock upgrade Fri, 18 March 2005 00:24 Go to previous message
555, if you want to rally it, Ring Andrew Vibert (CVAP-. forum sponsor) as he did run one of these and won the Vic state championship P3 class in '03, it was a real animal of a car. So I would base the car on his setup as it's been proven even though it ran a 2TG.
Personally, The Hilux-pug-corona brake set would be my choice, though any of the celica setups do work well, done a couple of streeter using TA22's which were a big improvement over the stockers... Guy's which was the celica with vented front brakes... RA60 or 65? which ever ones they are, this would be second choice for this application.
Also if you are going to run full on rally's adjustable coil overs should also be a must as many times you'll need to raise and lower the car that extra few inches to get better ground clearance... over here 2GO is renowned for being rough as buggery, so we raise it, while bega being really smooth, we lower it.
really good shocks, ie Koni yellow, Bilstien are usually a minimum, but these need to be order with the correct valving to suit spring rates etc for the application on hand. Generally the more bound and rebound control, the better.
Also, being a pre-86 model, the rules are have many more freedoms to the car we run.
Previous Topic:need info or specs on 7MGTE
Next Topic:1jz in a corona
Current Time: Sat Oct 24 03:58:53 UTC 2026
Total time taken to generate the page: 0.0088939666748047 seconds
