Toymods » Tech & Conversions » MAP GZE ECU on early AFM GZE block
dorikin ichiban
Auckland, New Zealand
MAP GZE ECU on early AFM GZE block Thu, 25 July 2002 02:38 Go to next message
Does anyone know if the MAP GZE ECU and loom would work on the early AFM GZE block?
TE72_Turbo
Re: MAP GZE ECU on early AFM GZE block Thu, 25 July 2002 11:07 Go to previous messageGo to next message
I havn't done it to disprove it for sure, but i would say that it would not be ideal as the AFM has 8:1 compression ratio, and map 8.9:1, so the settings for ignition & fuel in the computer should be different to reflect the charateristics of the different 2 engines.
may work ok in practice though??
Grega
melbourne.victoria.austra...
Re: MAP GZE ECU on early AFM GZE block Thu, 25 July 2002 18:18 Go to previous message
um, the levin i had the replacement motor that was put in was the 8:1 variety and was running a MAP sensor setup, that went fine.
Previous Topic:ae86 disks on ae71
Next Topic:3tgte bearings???
Current Time: Thu Nov 19 23:19:43 UTC 2026
Total time taken to generate the page: 0.0063819885253906 seconds
