Toymods » Tech & Conversions » Gutting TVIS : whats done and benifits/downsides ?
Classique71
Colac, Victoria
Gutting TVIS : whats done and benifits/downsides ? Fri, 14 November 2003 07:28 Go to next message
heys - Ive heard of a few guys " gutting " their Tvis ..
i think dannygt4 has done this on his gt4 as well
Anyone able ot explain the benifits or downsides of doing this - and is it worth it .
My new Ecu is supposedly able to control or disable this funtion also - as a side note
spectral
Re: Gutting TVIS : whats done and benifits/downsides ? Fri, 14 November 2003 09:25 Go to previous messageGo to next message
Its a hotly contested issue.
Some say they have removed it and found no less of low RPM torque, some say that it has suffered.
I'm of the opinion that Toyota aren't idiots, and they stuck it there for a reason.
I'm rebuilding my 3SGTE at the moment and I'll be leaving the TVIS in. Partly because my engine won't be extreme (only around 280-290HP) and I will be running standard ECU and turbo.
The GT4 is a heavy car, so in my view, for a road car, you need every bit of low end torque you can get to retain good driveability.
If I was aiming for 400HP+, with aftermarket ECU and turbo and maximum flow capacity was my goal, then I'd gut it. Probably cause it wouldn't be a daily driver so its behaviour at less than <4000rpm wouldn't concern me.
Classique71
Colac, Victoria
Re: Gutting TVIS : whats done and benifits/downsides ? Fri, 14 November 2003 09:51 Go to previous messageGo to next message
im aiming in the vicinity of 185 - 200 KW at the wheels with my machine ..
Dunno if ill need to or nto - probably not though it would be an interesting topic to cover - not only gor the 3s crew but the 4a's as well
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Gutting TVIS : whats done and benifits/downsides ? Fri, 14 November 2003 12:57 Go to previous messageGo to next message
It's a bit different between the 4AGE & 3SGTE, on being turbo & the other N/A, it's generally accepted to ditch it when turboing the 4A. It would prolly still funtion relatively well on a low boost setup, but not many people bother with those these days.
The main problem with trying to figure out the best setup is the costs of the research, it's not quite something most people can do in the backyard, & your intake developement budget will prolly be a bit less than toyotas.
I would say keep it until you're pushing out say 25-30% more power than standard, otherwise it would be an interesting thing to look into.
Puffy
Re: Gutting TVIS : whats done and benifits/downsides ? Fri, 14 November 2003 13:23 Go to previous message
"I'm of the opinion that Toyota aren't idiots, and they stuck it there for a reason. "
But they did remove it from the Gen III design.
I experimented with the tvis on the dyno and it made no difference to power levels on a stock CT26 (18psi) as even pin pointing when tvis was activated in the rev range was difficult to see. With the GT turbo however it was a different story. The power output still remained the same but came on boost 400rpm earlier when tvis was disactivated. To me the runners on the 185 manifold is where the bottle neck is and the tvis has trouble activating in time with laggy units that come on boost suddenly.
Dont go out of your way to remove it but if your doing a rebuild then go for it.
Has anyone removed TVIS from a 4age. I wonder if that makes a big difference?
Anhar Khamas
GT4 Group A
Previous Topic:what can i do with a 22re
Next Topic:Help: What colour is my car!?
Current Time: Wed Oct 28 03:52:27 UTC 2026
Total time taken to generate the page: 0.028211832046509 seconds
