Toymods » Tech & Conversions » 1JZ Cooling Fan
Skip
1JZ Cooling Fan Fri, 14 November 2003 07:46 Go to next message
Im having clearance issues with my conversion, the large 17" diameter standard cooling fan is fouling. I need a fan with dimension less than 14". Is there any other Toyota OEM fan/fan clutch that will suit? The flange is 92mm diameter, 4 holes on 74mm PCD, spigot dia. 15.9mm and spigot length 8.8mm. Maybe I will just find one with similar spigot size and redrill PCD on pulley to suit.
Danish
Re: 1JZ Cooling Fan Fri, 14 November 2003 09:54 Go to previous messageGo to next message
Why not go with Thermo fans?
Skip
Re: 1JZ Cooling Fan Fri, 14 November 2003 13:02 Go to previous messageGo to next message
Just went and had a look at the pulley again and realised I cant redrill it to a smaller diameter. The holes are on the inner edge as it is.
Danish: Thermo fans are cr@p compared to clutch fans, I have had bad experiences with them in the past with copper radiators, this time I have an aluminium one so i may not be on the cooling borderline as much. In the end they may be my only choice, I suppose this time an advantage is that my Haltech will control them. Will go to a few wreckers next week and see if i can find a clutch fan setup to suit.
Has anyone ever cut the blades down on a standard plastic fan? If so what were the results? I will need to take at least 40mm off each blade.
Danish
Re: 1JZ Cooling Fan Fri, 14 November 2003 13:09 Go to previous messageGo to next message
My electric fans are working great! Smile
Re: 1JZ Cooling Fan Fri, 14 November 2003 14:29 Go to previous messageGo to next message
I have electric fans as well, and they're doing a great job keeping my 2JZ cool. I was towing a dual-axle trailer full of crap the other day and had no worries with overheating. Having a good radiator makes all the difference. Smile
Skip
Re: 1JZ Cooling Fan Sat, 15 November 2003 12:21 Go to previous messageGo to next message
Ive got a 60mm thick 530x430 (overall) 2 row crossflowing aluminium unit, cost an arm and a leg Sad. Looks like ill go for thermos then, I will completely shroud the rear in with aluminium and mount the thermo(s) on the shroud drawing the air through. To be honest the standard 1JZ fan is in a ridiculous position anyway, it's no where near the centre of the radiator. If all goes well ill be up and running next weekend Smile
Re: 1JZ Cooling Fan Sat, 15 November 2003 16:02 Go to previous messageGo to next message
Skip wrote on Fri, 14 November 2003 23:02
<snip>Will go to a few wreckers next week and see if i can find a clutch fan setup to suit.
fwiw, the clutch/viscous hub for my RA40 started to fail (had plenty of drag to shift fan but rotated easily with engine off at high temps) - resulting in overheating under any load (and this is with a copper radiator - just 12months out from a proper flush). Replaced the hub and is now holding temps in brisbane heat.
i think that the fan performance is so closely linked to hub performance (e.g. if either begins to fail, cooling performance suffers significantly), that if you removed so much blade length, you wont shift enough air - and temps under load or low-road-speed will rise significantly. You might also not have enough drag on the hub for it to lockup properely,
i think a bunch of thermos would suit you better - several small 10-12" blowing thru, and the larger 14" inside mounted in a custom shroud. Can you take a few pics of the shroud before/after mounting?
mx83toy
Re: 1JZ Cooling Fan Sun, 16 November 2003 13:22 Go to previous messageGo to next message
i ditched my 1j hydrolic set up and put 2 v6 magna thermo's i put em sideways (shrouded) they are great... only take up a very small amount of space to...
Re: 1JZ Cooling Fan Sun, 16 November 2003 20:30 Go to previous messageGo to next message
AU falcon shroud & fans (complete unit) will cost you around $250 (expensive I know), but it is nearly a direct bolt up & perfect fit
edit: better for the ma61 rad, as it has the side mounts for the shroud in almost the same place
[Updated on: Sun, 16 November 2003 20:31]
Skip
Re: 1JZ Cooling Fan Sun, 16 November 2003 23:41 Go to previous messageGo to next message
It is much better to fit a big single than 2 smaller fans. Youll find a single 16" will move a fair bit more air than 2 12". Does anyone know of any good brands besides Davies Craig? A 16" davies craig is about $350 Shocked
BTW what are the overall dimensions of the AU fans and shroud, and do you buy them new from Ford spare parts? If someone has a pic please post it.
Re: 1JZ Cooling Fan Mon, 17 November 2003 05:55 Go to previous messageGo to next message
I bought it from a late model ford & holden wreckers, brand new in the box with warantee - ford wanted $300+
I'll get a pic if I can - at a guess I'd say it's twin 13s
V8_MA61
Re: 1JZ Cooling Fan Mon, 17 November 2003 06:31 Go to previous messageGo to next message
Just go thermos mate! Im using them on my car. I wouldnt spend 10k + on an engine to then go tight on something as important as cooling. I upgraded from the ma61 radiator and 16' clutch fan to:
660w x 520h x 80mm thick 4-core chev radiator with HUGE tanks. ($250 like new)
one 14" GT4 Fan
one 13" GT4 Fan. (gt4 fans $100 from shane)
and a 12" davies craig a/c fan. (Free from auto elec i know)
So all up max my cooling system would cost anyone on here about $500...well worth it to be certain you have the best keeping your engine cool.
I cant see a clutch fan keeping my car anywhere near as cool as these on a hot summer day in traffic with aircon on.
Blake.
Skip
Re: 1JZ Cooling Fan Mon, 17 November 2003 07:57 Go to previous messageGo to next message
Yeah pity I cant get a radiator in that big, thats the problem when putting a 6 cylinder in where a 4 cylinder used to live. It's overall dimensions are 530x430x57, being all aluminium it will be pretty efficient though. Im not going tight on anything on the conversion, tis the reason I have an aluminium radiator and wanted to get the system right. There is nothing worse than a car with cooling problems, I used to own one Sad
Thats one mighty radiator you have, have you got any shrouding? Shrouding is very important to cooling performance.
V8_MA61
Re: 1JZ Cooling Fan Mon, 17 November 2003 11:00 Go to previous messageGo to next message
I dont need any shrouding, as my fans are shrouded themselves (have their own steel shrouds) and ill be mounting them flush to the radiator on brackets im making. I personally think its just lazy to bolt them straight through the radiator. take the time, or spend the money to do it properly. My old fans weren't shrouded, but were mounted literally flush to the radiator on brackets i made so there was no need for a shroud..
Shrouding is only of importance for fans spinning free-air.. Like clutch fans/ plastic. Or thermo fans like a late model commodore runs...one big ass one, but has its own shroud to make it highly efficient.
[Updated on: Mon, 17 November 2003 11:01]
mx83toy
Re: 1JZ Cooling Fan Mon, 17 November 2003 12:51 Go to previous messageGo to next message
got my set for $50
wiring, switch, relay and conectors ohh and thermofan mounts aprox $30
me ripping a massive hole in my new radiator when putting it together....Pricless Shocked Sad Embarassed
well actually cost me another $400 (the guy felt sorry for me Razz )
mx83toy
Re: 1JZ Cooling Fan Mon, 17 November 2003 12:53 Go to previous messageGo to next message
ps this turned out to be a really good setup perfect fit over the cressi radiator i'll post a pic in a few days...
Re: 1JZ Cooling Fan Mon, 17 November 2003 13:04 Go to previous messageGo to next message
how did you manage that?
I feel your pain Sad Im going to take extra special care when putting mine together now Razz
Skip
Re: 1JZ Cooling Fan Tue, 18 November 2003 00:07 Go to previous messageGo to next message
V8_MA61: You dont need shrouding cause your radiator is so f#*king big Laughing.
Remember if a fan is just bolted on it will only pull air through that area of the radiator. Also if there is a gap between the radiator and thermo shroud alot of air will go through the gap and hence not get sucked through the radiator core. Air will always try and find the easiest path to move!!!! BTW im talking pulling air from the back, not pushing it from the front. Ideally you should totally shroud the rear of the radiator, like box it all in then put the thermo on the shroud which covers the entire core, therefore pulling air through every section of the radiator. However if this box doesnt stand far enough out, usually 1.5 times the thickness of the core is enough, you will create bad pressure differences or dead spots and it will not work properly.
When my setup is finished ill put some piccies up, im looking at aluminium at the moment, but if i get real trick ill make a carbon fibre one. Cool
V8_MA61
Re: 1JZ Cooling Fan Tue, 18 November 2003 07:52 Go to previous message
have you ever seen gt4 fans? They are shrouded properly. Both of mine cover the full radiator.
Previous Topic:Clear Tail Lights
Next Topic:removing Ackerman Steering
Current Time: Thu Oct 22 23:06:04 UTC 2026
Total time taken to generate the page: 0.034482955932617 seconds
