Toymods » Tech & Conversions » Broken 4AGZE pistons part 3, side by side view of cross sections
Broken 4AGZE pistons part 3, side by side view of cross sections Fri, 14 November 2003 14:19 Go to next message
Hey all,
installment 3 (i think). here are some pics comparing the cross-sections of Feral4mr2's piston on the left (deep dish), and MrShins piston on the right (shallower dish). the valve cuts on both pistons are the same depth from the flat edges of the piston crown.
the skirts of the pistons look to be almost identical, as does the amount of meat around the bottom edge of the oil control ring. the oil holes also appear to be placed in the same way on both. the gudgeon pin area seems to be identical.
what is different, apart from the obvious difference in dish, is the ribbed bit underneath the piston on the left. minimum crown thickness between the ribs is 6.8mm.
the piston on the right has no ribbing, and the minimum crown thickness is 7.4mm
what was left of MrShins piston weighed 298.12g, and the gudgeon pin weighed 97.68g. i did not have a chance to weigh Feral4mr2's piston before cutting.
the pic on the left is at a slight angle, so it looks like the skirt tapers.. but it doesn't really.. just a shitty pic Wink
http://www.materials.unsw.edu.au/~sford/pics/feral-shin1.jpg
[Updated on: Fri, 14 November 2003 14:22]
CLG
Perth, Western Australia
Re: Broken 4AGZE pistons part 3, side by side view of cross sections Sat, 15 November 2003 03:52 Go to previous messageGo to next message
Stew,
Can you specify the exact model of both piston's when referencing for easier infomation gathering please?
Re: Broken 4AGZE pistons part 3, side by side view of cross sections Sat, 15 November 2003 06:00 Go to previous messageGo to next message
Piston on left = AFM type GZE (early model, 8.0:1 AW11 type)
Piston on right = later MAP tuype GZE (8.9:1 type)
Re: Broken 4AGZE pistons part 3, side by side view of cross sections Sat, 15 November 2003 07:47 Go to previous messageGo to next message
I love that I can still see the conrod chew marks on the bottom of my piston Evil or Very Mad
Dabbid
Yowie Bay, Sydney
Re: Broken 4AGZE pistons part 3, side by side view of cross sections Sun, 16 November 2003 07:45 Go to previous messageGo to next message
would u do a 1g-gte piston? i'm guna have 6 floating around soon...
Re: Broken 4AGZE pistons part 3, side by side view of cross sections Sun, 16 November 2003 07:56 Go to previous messageGo to next message
mrshin wrote on Sat, 15 November 2003 18:47
it did a pretty good job man, lovely crank profiled pistons!
Dabbid: sure why not Very Happy will be interesting to have a bit of a collection. email me at stewie@unsw.edu.au
TE72_Turbo
Re: Broken 4AGZE pistons part 3, side by side view of cross sections Sun, 16 November 2003 10:07 Go to previous messageGo to next message
Thats a cool picture! I've always been interested in seeing a cross section like this between the two.
Thanks!
Phil
Sprinta
Re: Broken 4AGZE pistons part 3, side by side view of cross sections Sun, 16 November 2003 13:23 Go to previous messageGo to next message
Again, good work dude Smile
Re: Broken 4AGZE pistons part 3, side by side view of cross sections Mon, 17 November 2003 11:10 Go to previous messageGo to next message
Maybe I should take some shots of the REST of the engine, ey?
Re: Broken 4AGZE pistons part 3, side by side view of cross sections Mon, 17 November 2003 11:11 Go to previous messageGo to next message
yes!
always amusing to see pics of chewed engines Smile
Re: Broken 4AGZE pistons part 3, side by side view of cross sections Tue, 18 November 2003 01:59 Go to previous message
definitely!! under the gudgeon pins was made pretty flat by the conter weights!! lucky they didn't catch!
Previous Topic:car over heating but not????
Next Topic:Remote oil filter with cooler
Current Time: Wed Oct 21 02:55:25 UTC 2026
Total time taken to generate the page: 0.0057580471038818 seconds
