Toymods » Tech & Conversions » MA61 / RA6X spring rates?
wilbo666
MA61 / RA6X spring rates? Sat, 15 November 2003 06:15 Go to next message
Just wondering how similar MA61 Front springs are to RA6X springs (spring rates would be great if anyone has them Rolling Eyes )
I would imagine that the supra with its heavier front would also have a higher spring rate? Also are the captive heights the same?
Trying to work out how well some SA63 (same as RA65 I believe) struts will fit into a MX62 cressida (has a 5M-E so would imagine what works well for the MA61 would be similar to what will work well to me). I'll prbly put the struts in and see how much the height changes by and the effect on camber (if its no good I can just swap the hubs / caliper onto my struts I believe looking at it quickly, actually I might just end up doing this anyway, what do you think is the better option?).
ed_ma61
Lost in the K hole
Re: MA61 / RA6X spring rates? Sat, 15 November 2003 13:19 Go to previous messageGo to next message
fwiw:
kings 'low' ma61 spring rates are:
front: 185-210 rising
rear 225/230 linear
from memory Smile
i should really write these things down
ed
wilbo666
Re: MA61 / RA6X spring rates? Sat, 15 November 2003 15:12 Go to previous messageGo to next message
Thats quite low isn't it Rolling Eyes I would have expected a bit firmer?
Any idea what the RA6X's rate is (ie to compare to the MA61 value)
ed_ma61
Lost in the K hole
Re: MA61 / RA6X spring rates? Sun, 16 November 2003 00:59 Go to previous messageGo to next message
may be 'low' in absolute terms, but when you tak into acount the lever ratio of the suspension design, trust me its quite firm Nod
for full circuit use only, the supra would run about 300lbs rear, and 230 front
[Updated on: Sun, 16 November 2003 00:59]
wilbo666
Re: MA61 / RA6X spring rates? Sun, 16 November 2003 02:24 Go to previous messageGo to next message
Ok, where did you get the spring rates from? Any idea what the spring rates for RA6X celica's are Confused
I'm guessing the spring rate will be lower (due to the lesser weight) and hence not suit my car real well Rolling Eyes
Also do RA / MA struts share the same spring installed height?
Any chance that you know the stock rates for RA6X or can find them? (Or point me in the right direction).
What would you suggest as a good spring rate to remove most of the boatness out of a MX62 Cressida (stabs in dark lol)
ed_ma61
Lost in the K hole
Re: MA61 / RA6X spring rates? Sun, 16 November 2003 07:18 Go to previous messageGo to next message
wilbo, i have no idea what you might need Sad
BUT - if you call kings springs in QLD (main office, tech guy) and ask them, they can tell you anything you want to know about any of their springs
ed
wilbo666
Re: MA61 / RA6X spring rates? Sun, 16 November 2003 08:36 Go to previous message
Good stuff, no doubt they will be receiving a call!
Previous Topic:haltech 3tgte fuel map
Next Topic:Who Does Bilstein shocks ?
Current Time: Thu Nov 26 09:19:36 UTC 2026
Total time taken to generate the page: 0.0050179958343506 seconds
