Toymods » Tech & Conversions » Shimming 4AG oil pump
Shimming 4AG oil pump Sat, 15 November 2003 08:15 Go to next message
I want to increase the oil pressure slightly (about 10psi) on my 4AG. Seeing as I am pulling the sump, water pump and timing belt off anyway to fit other parts (not to mention taking the engine out of the car...), I just wanted to hear from anybody with any experience in playing with the oil pump both suggestions of shim thickness, and if there's anything to watch when putting it in - I don't want to find out I got it wrong the hard way! (I realise it's a relatively straightforward thing, but they say the only stupid question is one not asked... maybe... now may I please have another cookie?) Smile
[Updated on: Sat, 15 November 2003 08:23]
._T_.
Re: Shimming 4AG oil pump Sun, 16 November 2003 00:53 Go to previous messageGo to next message
we did this on the racecar. one washer (~1mm thick) should do the trick.
of course they are a pain to pull down, and even worse to put back together.
T
TE72_Turbo
Re: Shimming 4AG oil pump Sun, 16 November 2003 10:24 Go to previous messageGo to next message
This sounds interesting! What will be the benefit from an extra 10psi? Will it yield much increase in oil flow?
What is the 'normal' relief spring pressure for the 4AG?
Phil
ed_ma61
Lost in the K hole
Re: Shimming 4AG oil pump Sun, 16 November 2003 10:47 Go to previous messageGo to next message
sure there arent any other pressure relief valves that will thwart your efforts?
jase
Re: Shimming 4AG oil pump Sun, 16 November 2003 12:45 Go to previous messageGo to next message
Also check there's no pressure release/bypass nearby the oil filter. (done in case the filter gets blocked)
Re: Shimming 4AG oil pump Sun, 16 November 2003 22:59 Go to previous messageGo to next message
Thats kind of why I was asking, just wanted to know if anyone's played with this stuff before to save me pulling the engine out 30 times Evil or Very Mad
._T_.
Re: Shimming 4AG oil pump Sun, 16 November 2003 23:23 Go to previous message
what can happen is that the reliefe valve will cock over and jam - typically closed - lots of oil pressure! (better than the alternative i guess) check the bore on the pump for wear before shimming - and sign of wear, find a new pump!
T
Previous Topic:AE86 Arm
Next Topic:3s 5s transmissions
Current Time: Sun Nov 1 03:55:15 UTC 2026
Total time taken to generate the page: 0.0055949687957764 seconds
