Toymods » Tech & Conversions » Knock sensors.
ViNcEnXo
Knock sensors. Sat, 15 November 2003 12:59 Go to next message
How do they work? And does a 7MGTE have one?
Regards
Paul
Re: Knock sensors. Sat, 15 November 2003 13:08 Go to previous messageGo to next message
"knock" in a motor generates specific vibrations in the block.
a "knock sensor" is a piezo-electric sensor which is a cermaic that generates an electricla current when it is compressed. this means that it can generate an electrical sugnal that has many of the frequencies in a motor.
what you need to do is to filter out all the frequencies that are NOT associated with knock, in order to detect it.
7MGTE? no idea, sorry.
ed_ma61
Lost in the K hole
Re: Knock sensors. Sat, 15 November 2003 13:21 Go to previous messageGo to next message
7mgte has two
and oldcorollas is correct in outlining their function. i should add though, that the sensor is 'tuned' to the harmonic frequency of the 'knock' for each specific engine. which i believe was either 24ooHz - 27ooHz ... i think (i shouldve written that down when i found it out Razz )
Re: Knock sensors. Sat, 15 November 2003 13:30 Go to previous messageGo to next message
heya Ed,
does the frequency change much with RPM? i know it is mostly based on the cylinder and chamber dimensions, but i imagine that it would change slightly based on the temperature and pressure of gases in the chamber (changing the speed of sound etc)...
any more ideas you wanna share??? have you had any luck setting one up??
i have a couple of piezo sensors, but have not had access to a CRO to look at waveforms (and probably shouldn't be doing that just yet Wink )
ed_ma61
Lost in the K hole
Re: Knock sensors. Sat, 15 November 2003 13:49 Go to previous messageGo to next message
oldcorollas wrote on Sun, 16 November 2003 00:30
didnt work at all... totally insensitive (even to a ballpein hammer pounding the deck block) Shocked
ive resolved to drill out a spare knock sensor, and mount a samll piezzo microphone in it. then run the lead into the cabin to an Aux audio input on my amp... tune by ear, a much more sensitive device than that shitty circuit!
ed
ed_ma61
Lost in the K hole
Re: Knock sensors. Sat, 15 November 2003 13:54 Go to previous messageGo to next message
i agree it may wander a bit, but id imagine the resonant harmonic is governed mainly by the radius of the cyl, and the material... thus id say you could expect it to occur in a relatively narrow band despite changing conditions
IRA11Y
Club Member
Re: Knock sensors. Sat, 15 November 2003 20:40 Go to previous messageGo to next message
Quote:
i have a couple of piezo sensors, but have not had access to a CRO to look at waveforms (and probably shouldn't be doing that just yet )
you can come and borrow my cro if you want Stu
ViNcEnXo
Re: Knock sensors. Sun, 16 November 2003 00:42 Go to previous messageGo to next message
So what does the car do when it detects a 'knock'? Retard the timing, richen up?
'knocking' is pinging is it not?
Re: Knock sensors. Sun, 16 November 2003 01:49 Go to previous messageGo to next message
retard timing (usually in predefined steps) until pinging goes away.
a smart engine mngt system may even go and modify fuel/timing maps to attempt to prevent further pinging - but this behaviour tends to 'detune' cars into safe running modes as opposed to efficient or power modes of operation.
charles.
Re: Knock sensors. Sun, 16 November 2003 02:12 Go to previous messageGo to next message
IRA11Y wrote on Sun, 16 November 2003 07:40
cool thanks Very Happy will do!!
anyone else want to donate a pinging engine Wink
ed_ma61
Lost in the K hole
Re: Knock sensors. Sun, 16 November 2003 07:19 Go to previous message
oldcorollas wrote on Sun, 16 November 2003 13:12
you have aaprx 3.5weeks of 5M pinging goodness left if you want it Nod
Previous Topic:2tg/3t hybrid owners, have you had this problem
Next Topic:MA70 Clutch Lines
Current Time: Tue Oct 27 00:45:20 UTC 2026
Total time taken to generate the page: 0.006505012512207 seconds
