Toymods » Tech & Conversions » Clutch fans and removing them.
ViNcEnXo
Clutch fans and removing them. Sun, 16 November 2003 07:39 Go to next message
Is it possible to remove these things coz they sound like an EA falcon... Can they be replaced with an electronic thermo?
Paul
wilbo666
Re: Clutch fans and removing them. Sun, 16 November 2003 08:35 Go to previous messageGo to next message
Yes you can remove them (its only 4 bolts usually) and replace them with thermos.
Also you will get a few hp. (is it worth the cost / effort tho?)
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: Clutch fans and removing them. Sun, 16 November 2003 09:07 Go to previous messageGo to next message
its generally a better idea to run clutch fans then thermo's as they do a better job. But if you absolutly have to remove them.. you can get kits and so forth
Re: Clutch fans and removing them. Sun, 16 November 2003 10:12 Go to previous messageGo to next message
kits inlcude:
# one 10mm spanner
# instructions to use said spanner
# one thermofan
# four bolts
# wires and relays
# intructions on how to use previously used 10mm spanner with thermofan and bolts
# pictoral instructions of above for those literally challenged
# wiring diagram with pretty colours
# one mallet
# instructions on how to use mallet when it all goes horribly wrong.
sorry, im in a silly mood.
ViNcEnXo
Re: Clutch fans and removing them. Sun, 16 November 2003 11:00 Go to previous messageGo to next message
I just cannot stand the sound of them...
I know how tempermental the cooling system on a 7M is, so would it be a step backwards going to a thermo?
Paul
wilbo666
Re: Clutch fans and removing them. Sun, 16 November 2003 13:15 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=23383&rid=36&S=1e83a9e502f58b7468e630bd5 6792397&pl_view=&start=0#msg_195964
Might help
Re: Clutch fans and removing them. Sun, 16 November 2003 13:27 Go to previous messageGo to next message
7M clutch fans are big and move LOTS of air. You simply can't move that volume of air with an electric fan so yes, it would be a step backwards to install one.
ViNcEnXo
Re: Clutch fans and removing them. Sun, 16 November 2003 23:09 Go to previous messageGo to next message
Well it looks like I'll keep it then.
Thanks guys
Allan
Re: Clutch fans and removing them. Mon, 17 November 2003 00:02 Go to previous messageGo to next message
Norbie wrote on Mon, 17 November 2003 00:27
Yes but the problem is the fan spins at the same speed as the engine, thus at idle in traffic not much air moves where as thermos spin at full speed when needed
On the ma70 the temp used to go one bar above operating temp with the clutch fan now with the thermos it never go's above half it actualy drops a bar below before the fans switch off!
Not to mention the grunt it sucks out of the engine, i once tryed a 7m-gte fan on an M-EU damn near stalled the engine when it clutched in!
Allan
ViNcEnXo
Re: Clutch fans and removing them. Mon, 17 November 2003 00:50 Go to previous messageGo to next message
Ok, so it's a good idea??
Re: Clutch fans and removing them. Mon, 17 November 2003 01:48 Go to previous messageGo to next message
Everyone seems to have their own opinion on this, but I've had nothing but positive experience with clutch fans. The only reason I'm running electric fans now is because I can't find a JZ clutch fan second-hand, and they're way too expensive new. Sad
If my car was overheating while idling, I'd add a small electric fan as a backup (not a replacement) for the clutch fan.
wilbo666
Re: Clutch fans and removing them. Mon, 17 November 2003 01:49 Go to previous messageGo to next message
Depends, do you actually have an overheating prob / something wrong with current clutch fan?
If its not broken why fix it?
[Updated on: Mon, 17 November 2003 01:49]
ViNcEnXo
Re: Clutch fans and removing them. Mon, 17 November 2003 02:12 Go to previous message
Point taken. I'll fix it when and if it breaks.
Previous Topic:Urgently need help: Ball joints for MZ21
Next Topic:rx7 turbo on a 4agte question
Current Time: Wed Oct 28 06:12:58 UTC 2026
Total time taken to generate the page: 0.0051770210266113 seconds
