Classifieds » Parts Wanted » 18R-G high comp pistons wanted - 9.7:1 or higer
18R-G high comp pistons wanted - 9.7:1 or higer Sun, 16 November 2003 09:29 Go to next message
rebuilding time... i want some higher compression pistons than the wussy 8.7:1's that are found in my 18R-GU.
Forged, cast, whatever you have let me know!
clubagreenie
1st street on the right
Re: 18R-G high comp pistons wanted - 9.7:1 or higer Sun, 16 November 2003 11:13 Go to previous messageGo to next message
Only source I've found has been JP's in Adelaide. Steve M on here set me the following and can organise as he lives nearby (something I'm yet to do)
Yes, the 9.7:1 dome i slightly over size should give you a CR of a little over 9.7:1.
I have the Hastings part number for the 89mm bore (0.5 OS)
(Hastings premium RS1294020CR4H) is for 89 bore (.020" OS)
I think rings are available for upto 1.5mm over size in .5mm increments, but can not remember for sure. The part number is pretty easy to understand and I could make that one up for you if you want.
IF you went for the 89 bore then the the 9.7:1 dome would give you comprtession readings between 188psi and 184psi ish. That is what we got with the same set up at least, and the cams that you are running will make a difference too. Ours were 88251 cams, which would account for the readings being slightly higher than the book's 179psi ish figure.
THe best way to go is to get the pistons and then get the block bored to suit, as there are bound to be very small differences between them.
SOMETHING TO NOTE:
Do not follow the .08 - .1mm end gap figure that the book gives. The end gap should be around .356mm minumum
(our end gap was .39 after the boring and new pistons and new rings, the guy who did the work on the engine said that about right)
Justin
PS if you are thinking of ordering let me know as I need same and they need to be made anyway, should be just under $600 without rings (they supply but aren;t that great)
Re: 18R-G high comp pistons wanted - 9.7:1 or higer Sun, 16 November 2003 21:17 Go to previous messageGo to next message
well in comparison to buying a set of 10.5:1 forged pistons with 92mm bore from Toysport in USA for $US500.... i think i might know where my money is going!
Also makes life a LOT easier considering i'll be going to their shop in less than 3 weeks Very Happy
Jason
Re: 18R-G high comp pistons wanted - 9.7:1 or higer Mon, 17 November 2003 01:15 Go to previous messageGo to next message
I just bougth a genuine 1MM oversized from toyota. Give it a go you never know your luck in the big city.
Re: 18R-G high comp pistons wanted - 9.7:1 or higer Mon, 17 November 2003 06:49 Go to previous messageGo to next message
i did.... $160 per piston for the 8.7:1
Steve M
Re: 18R-G high comp pistons wanted - 9.7:1 or higer Tue, 18 November 2003 03:50 Go to previous messageGo to next message
$160 each, geez that's high.
My brother paid $344 for an entire set of 9.7:1 pistons in .5 oversize, genuine parts.
There were two sets of these pistons left in Sydeny a few months ago.
I can find them if you want, I don't know where they are, but I do know who can get them for around that price.
Let me know if you are interested.
CelicaRA45
nth ringwood, Victoria
Re: 18R-G high comp pistons wanted - 9.7:1 or higer Tue, 18 November 2003 10:56 Go to previous message
might have some 11to 1 forgys by this week end remind me am picking up heaps of stuff in the rg department
Previous Topic:Celica XX Rims
Next Topic:XT130 struts - to suit pug/hilux upgrade - brisbane?
Current Time: Sun Sep 13 11:13:46 UTC 2026
Total time taken to generate the page: 0.010453939437866 seconds
