Toymods » Tech & Conversions » Spark Plugs for 100kw 4AGE
Julz
Spark Plugs for 100kw 4AGE Sun, 16 November 2003 09:49 Go to next message
I went to Repco today to get some new Bosch Super 4 spark plugs. I gave the assistant my car/engine details and 2 different part numbers came up for AE92 and AE93.
The Super 4's I've had it there for nearly 3 years were completely fine So I would thoroughly recommend them. Anyway, the plugs I ended up getting were for the '4AGEL' What does the L mean and are these plugs ok for my engine? To make matters more confusing, the part number of my last set of plugs was different again. The new plugs appear identical to the old ones
I hope I have the right ones in there. Sad
Previous Set : Bosch Super 4 - FR56 (didn't register on Repco's computer)
New Set : Bosch Super 4 - FR78X
Option 2 : Bosch Super 4 - FR78
Option 3 : Bosch Super 4 - FR60 (None in stock)
They wanted $20 EACH for the NKG's! I got the Bosch ones $40 for a boxed set of 4.
Anyone with a 100kw SX Corolla use Super 4's? which part number do you have?
waynewatson
Re: Spark Plugs for 100kw 4AGE Mon, 17 November 2003 03:45 Go to previous messageGo to next message
What month/year is your car? IE is it an ae92 or ae93?
Get the one that matches your car.
Having said that, either set should be fine (should be the same).
redlineGTi
syd- green valley
Re: Spark Plugs for 100kw 4AGE Mon, 17 November 2003 23:24 Go to previous message
as long as the lenght of the spark plug (the screw part/ that goes in to the head) is the same it will be fine.
my self, using NGK iridium p no:? BKR6EIX (from memory/ not made for the 4age butimprovised wif washers) they seem fine but next service going to go NGK platnums (what toyota recommended)
Previous Topic:KONI ON MR2
Next Topic:Size of clutch plate for 4age 20v
Current Time: Fri Oct 23 21:39:02 UTC 2026
Total time taken to generate the page: 0.0044519901275635 seconds
