Classifieds » Miscellaneous » EOI : Haltech F10 EMS (SOLD)
bootheman
in a box
icon10.gif  EOI : Haltech F10 EMS (SOLD) Mon, 17 November 2003 01:19
this is NEW in box with everything loom,cables,comp the lot all new never used, i have recently had some finacail probs so i need to sell it Sad
600ono
http://www.haltech.com.au/Products/ECUs/F10/f10ecu1.jpghttp://www.haltech.com.au/Products/ECUs/F10/f10-kit.jpg
http://www.haltech.com.au/Products/ECUs/F10/F10.pd f
The F10 Series
The HALTECH F10 is a powerful “realtime” programmable fuel injection system computer designed for those seeking optimum performance.
No other system in the same class is as adaptable, easy to install or program.
The F10 System has up to 22 adjustable fuel maps each with 32 individual bars. The F10 will run up to 16000 rpm with better resolution and greater accuracy than ever before.
The F10 is available in 2 configurations: F10 and F10-8. The standard configuration is the 4 injector driver F10, capable of controlling 4 low impedance or 8 high impedance injectors. The F10-8 has 8 injector drivers capable of controlling 8 low impedance or 16 high impedance injectors. If necessary an additional driver box can be added for more injector outputs.
Injectors can be controlled directly, fired all together, in batches, or can be staged when running high boost turbo or superchargers.
[Updated on: Mon, 17 November 2003 13:06]
Previous Topic:ae86 disk brake rear end (melb)
Next Topic:FS: SET of AUS SPEC tail lights for ae86
Current Time: Mon Oct 19 17:51:01 UTC 2026
Total time taken to generate the page: 0.0051608085632324 seconds
