Toymods » Tech & Conversions » Airflow meter problems.
Caledwvech
Airflow meter problems. Mon, 17 November 2003 04:56 Go to next message
I have airflow meter problems (I think).
The engine light keeps coming on, and my car likes to vary it's revs quite a bit. The idle revs vary from 1100 to 600. Also sometimes when I put the clutch in the revs will just drop, and keep dropping until the car stalls. Is this an airflow meter problem??? Any help would be much appreciated.
Oh, and for those of you who dont know, it's a 7mgte.
Re: Airflow meter problems. Mon, 17 November 2003 05:32 Go to previous messageGo to next message
i thought that AFM's just have a switch for idle and it doesn't actually deflect? (not much air going in)
varying idle speed can often be an air leak, either from cracked pipes, vacuum lines, or from manifold gaskets... check your spark plugs, if one cylinder looks lean, ti could be a manifold leak (i had this recently.. 2 leaks, 0.5mm by 10mm where manifold gasket got blown out)
good luck searchin,
RobST162
Re: Airflow meter problems. Mon, 17 November 2003 05:53 Go to previous messageGo to next message
Don't SAY such thing Stewart! Pleeeeeze not manifold issues!!!! yes, I DON'T care if is a 7MGTE... Razz
Lambolica
Northwestern Sydney
Re: Airflow meter problems. Mon, 17 November 2003 06:36 Go to previous messageGo to next message
A leak in the intake pipe (after the AFM) gave me similar problems till I found it.
Gaffer tape solved it Very Happy
Caledwvech
Re: Airflow meter problems. Mon, 17 November 2003 22:17 Go to previous messageGo to next message
Ah! Very Happy Good old tape. Fixes anything. Very Happy Will check it out tonight thanks. Smile
Caledwvech
Re: Airflow meter problems. Tue, 18 November 2003 03:05 Go to previous messageGo to next message
Ok, I have another dumb question. How were you able to find the leak??? Could you feel it when you revved the car in neutral?
Re: Airflow meter problems. Tue, 18 November 2003 03:17 Go to previous messageGo to next message
carefully dribble soapy water over the plastic pipes (but not onto the spankin' hot turbo housings and other ow-thats-goddam-hot metal castings) and look for bubbles.
or make simply stethascope out of plastic hose (stuff one end in your ear, prevent helpers from yelling in other end) and mnove end around varisous engine bits until hissing sound found.
charles.
Caledwvech
Re: Airflow meter problems. Tue, 18 November 2003 03:21 Go to previous message
Ah. Good thoughts. Thanks for that. Will try the soapy water trick tonight (or tomorrow depending on when I get a chance).
Previous Topic:blitz racing meter DC 2 & live unit 2 installation..?
Next Topic:car over heating but not????
Current Time: Mon Oct 19 13:45:47 UTC 2026
Total time taken to generate the page: 0.090947866439819 seconds
