Classifieds » Miscellaneous » FS:Hilux/Celica diff
Switch to threaded view of this topic Create a new topic
GEEZE23
Western Sydney
FS:Hilux/Celica diff Mon, 17 November 2003 11:11 Go to next message
Hilux diff housing with brackets on to bolt into a RA/TA22/23/28.
Has watts link attached also. width around 1370 between whell mounting faces , same as std early celica width.
*Hilux Housing and 30spline axles restudded to 4x114.3 PCD (comes with watts link bits, 4 link w/ nolathane bushes, brake lines) $800
*Skyline disc brake conversion with all brackets and new cables to mate up to std lever (bolts to hilux housing) $350
*Hilux 8in 3.7:1 Genuine Toyota CW+P set 2,000kms(RRP $1100)$450
*Hilux 8in 4.3:1 Genuine Toyota CW+P set 150kms!!! " "$300
*hilux 4pinion 4wd LSD hemisphere w/ side bearings 2,000kms (RRP lots) $300
*hilux open hemisphere 750kms!! $100
*Celica RA23 2-piece taishaft suit hilux diff (late, big uni) to w58 g'box $120
*k-mac rear RA23 celica swaybar (clamps under lower arms) $80
SMS 0403 161 943
.oO Dave Oo.
[Updated on: Mon, 17 November 2003 11:18]
QIK 3SGTE
Re: FS:Hilux/Celica diff Mon, 17 November 2003 11:52 Go to previous messageGo to next message
would you be interested in a swap at all? I have a hilux diff in my TA22. New LSD centre and gears, has Sprinter brakes attached instead of the drums, I believe it is about 1390mm wide and need the 1370mm item you have to fit the 8"/ 245 rubber that I need to run to get traction. My setup is a bit wide at the moment.
otherwise how much for your complet hilux rear with discs and lsd centre ready to bolt in??
rob_RA40
c'town, NSW
Re: FS:Hilux/Celica diff Mon, 17 November 2003 21:37 Go to previous messageGo to next message
jack if u make an offer on daves hilux rear end id be interested in making an offer on your 1390mm hilux rear end.
crowy
Re: FS:Hilux/Celica diff Tue, 18 November 2003 02:30 Go to previous messageGo to next message
jesus, your selling half my car. Smile
blackRA28
adelaide
Re: FS:Hilux/Celica diff Tue, 18 November 2003 08:05 Go to previous messageGo to next message
Know the diameter of the kmac rear ra23 swaybar offhand??
badboybubby
On Probation
Re: FS:Hilux/Celica diff Mon, 24 January 2005 23:38 Go to previous messageGo to next message
PM Sent
badboybubby
On Probation
Re: FS:Hilux/Celica diff Mon, 24 January 2005 23:57 Go to previous message
opps
[Updated on: Mon, 24 January 2005 23:58]
Previous Topic:GEAR BOX FOR SALE?
Next Topic:Collectable Gundam model
Current Time: Tue Oct 20 00:06:51 UTC 2026
Total time taken to generate the page: 0.0058901309967041 seconds
