Toymods » Tech & Conversions » Corona Won't Start
jackel
Corona Won't Start Mon, 17 November 2003 12:06 Go to next message
Sad went to start my corona after like three weeks cause i lost my keys Rolling Eyes
n it wouldn't start...
I thought it could be the battery cause i turn the key n nothing happened.
So i got a friend to jump start it but it wouldn't turn over just kept clicking... so i'm wondering what it could be...
any suggestions??? Smile
wilbo666
Re: Corona Won't Start Mon, 17 November 2003 12:23 Go to previous messageGo to next message
solenoid in the starter? Try tapping it with a hammer...(my bet is on this one)
Starter relay?
Fusible link blown...check with multimeter for continuity
Re: Corona Won't Start Mon, 17 November 2003 12:58 Go to previous messageGo to next message
i'd put money on wilbo's solenoid ...
or you probably don't have a great connections between the two batteries when trying to jump 'em.
if its clicking you got power down at the solenoid - but not enough...
make sure the clamps are on tight and mash them around a bit to give a clean (e.g. corrosion & crap free) connection over a wide area.
then, once you've started it, you gotta work out why the battery went flat... Very Happy
charles.
jackel
Re: Corona Won't Start Mon, 17 November 2003 13:48 Go to previous messageGo to next message
yeah i've already tried wacking it doesn't make no difference
but yeah it just keeps clicking and every so often sounds like it's gonna turn over but doesn't.
Every time i've started my car before, it starts in one second
so it's gotta got something to do with it sitting there so long i think
crostek
Oyster bay NSW
Re: Corona Won't Start Mon, 17 November 2003 15:12 Go to previous messageGo to next message
batterys dead flat leave it on charge for a while or hooked up to your mates car for 10 mins before tring to start it.
If it still won't start check the battery water level and battery connections havn't Corroded.
Byatch
Re: Corona Won't Start Mon, 17 November 2003 23:17 Go to previous messageGo to next message
blast the horn when trying to start it
it sounds stupid, but apparently, the sharp spike in power drained from the battery can cause them to, i don't know what you want to call it, burst back into life.
seroiusly, i has worked for me in the past, and what have you got to lose?
people100
Rocklea qld
Re: Corona Won't Start Tue, 18 November 2003 10:04 Go to previous messageGo to next message
try hooking up 2 sets of jumper leads if u have them. Sometimes it gives a bit extra power to start If that dont work put it in 1st or park whether auto or manual and try pushing it just to make everything turn. sometimes the starters get stuck out if they havent been used for a while the first time u turn them over. short of that take it to a mechanic or get a new battery
Mr DOHC
Re: Corona Won't Start Tue, 18 November 2003 10:11 Go to previous messageGo to next message
i had a similar problem with my common whore
u need 2 ppl for this, one to turn the key to start and one wo wiggle the wires going to the starter
jackel
Re: Corona Won't Start Tue, 18 November 2003 13:26 Go to previous messageGo to next message
thanks dudes i'll try them ideas in the morning otherwise if
they don't work i'll get another battery Smile
Grega
melbourne.victoria.austra...
Re: Corona Won't Start Tue, 18 November 2003 20:13 Go to previous message
also try running a cable between the + on the battery and the starter. and ground to the engine NOT the battery.
failing that start the car manually - ie: jumper a wire between the ignition point on the starter and the positive and see if it kicks? (watch for the sparks tho)
i know old corollas' sometimes suffer from voltage loss in the STA line to the starter - can be helped with a relay tho.
Previous Topic:4a dizzy question
Next Topic:whats the difference between the blue top and red top 4age
Current Time: Fri Oct 23 10:27:53 UTC 2026
Total time taken to generate the page: 0.0054399967193604 seconds
