Classifieds » Miscellaneous » Peugoet 604 discs
GEEZE23
Western Sydney
Peugoet 604 discs Thu, 25 July 2002 14:02 Go to next message
Peugeot 604 dics to fit on early celica etc. DBA, Vented 273mm diameter, drilled to fit on a celica hub, also 4 piston toyota calipers
discs have 1000kms and are very close to new. FS for $175. Just one is $160 ea.
Calipers $150 pr
Dave
dlmw@optushome.com.au
saspeed
Re: Peugoet 604 discs Thu, 25 July 2002 14:21 Go to previous messageGo to next message
can you please advise if these discs and calipers will fit inside a 15 inch rim ??
Thanx
Levino
Re: Peugoet 604 discs Thu, 25 July 2002 16:47 Go to previous messageGo to next message
How about AE86 Sprinter? can it be fit in AE86 with 14" mags?
Re: Peugoet 604 discs Fri, 26 July 2002 01:59 Go to previous messageGo to next message
Consider them sold if not already!
dorikin
NE Melbourne
Re: Peugoet 604 discs Fri, 26 July 2002 06:53 Go to previous messageGo to next message
this upgrade hilux/pug disc brake conversion will fit inside 15 inch wheels (look left at my avatar, it's difficult to see but they're there under my 15 inch superlites) not so sure about 14's, but i suspect that at a squeese they will fit!!!
RA28
Re: Peugoet 604 discs Fri, 26 July 2002 11:29 Go to previous messageGo to next message
Hey, if no one else takes them then I will!
This would have to be the quickest sale in history!
Tim
GEEZE23
Western Sydney
Re: Peugoet 604 discs Sat, 27 July 2002 04:53 Go to previous messageGo to next message
Are you guys keen? Quickest sale only if sold!
If Joel doesn't take them next week they're up for sale still.
I had them on my 23 and they fit fine inside 14in alloy CSA wheels.
Dave
Midz
Re: Peugoet 604 discs Thu, 01 August 2002 02:46 Go to previous messageGo to next message
How much differance would it make to braking in 23 ?
Did u notice any ?
dorikin
NE Melbourne
Re: Peugoet 604 discs Thu, 01 August 2002 09:06 Go to previous messageGo to next message
consider this:
9in x 10mm solid disc, single piston caliper
vs
10.5in x 20mm vented disc, 4 piston caliper
the difference is so amazing it's almost impossible to describe. i admit that one stop from 60kmh, the difference is not that massive, but demand that the car do it over and over from higher speeds and the difference becomes worlds apart. the increase in cooling is the major benefit in this situation. the large caliper absorbs a lot of heat away from the fluid, preventing it to boil and reducing the brake fade associated. the vented disc also dissapates heat quicker. the other advantage is a larger pad area and a bigger disc, increasing the leverage available to slow it down.
GEEZE23
Western Sydney
Re: Peugoet 604 discs Fri, 02 August 2002 08:49 Go to previous message
No more, SOLD. Only twin piston calipers left -$50pr
[Updated on: Fri, 02 August 2002 08:50]
Previous Topic:GT4 go fast bits
Next Topic:7mge?
Current Time: Sat Nov 21 12:02:31 UTC 2026
Total time taken to generate the page: 0.0074610710144043 seconds
