Toymods » Tech & Conversions » 3sge cam specs needed
gemtoy
melb
3sge cam specs needed Mon, 17 November 2003 19:23 Go to next message
Does anyone have the cam specs from a Bathurst spec Aussie MR2.Also are they different to the other gen 3 engines?
I did a quick measure with the vernier and got about 10mm lift on the inlet and about 8.5mm on the exhaust does this sound right ?
Thanks.
._T_.
Re: 3sge cam specs needed Mon, 17 November 2003 21:52 Go to previous messageGo to next message
i've got the workshop manual on this engine. from memory the inlet cam seems about right, but the exhaust sounds a bit small.
believe all gen3 are the same "bathurst" was just a term to make people buy the stripped out mr2 (admittedly it did come with a factroy fitted lsd)
T
3sglevin
Re: 3sge cam specs needed Tue, 18 November 2003 05:48 Go to previous messageGo to next message
I know the lift is important but what about the duration I think you will find this to be more important!! to check them properly you should see if you can get them on a cam doctor, that way you know thew lift and duration and a cam man would probly have access to the right dimentions!
CelicaRA45
nth ringwood, Victoria
Re: 3sge cam specs needed Tue, 18 November 2003 06:07 Go to previous messageGo to next message
gen 3 9.8 lift inlet 8.2 exhaust opens 7 closes 57 opens 57 closes at 7
gemtoy
melb
Re: 3sge cam specs needed Tue, 18 November 2003 19:38 Go to previous messageGo to next message
Thanks guys. I know the duration is important but I was just doing a quick check to see if the cams were stock going on lift. I am intending on getting a bigger set soon.
Hey "T" how did you go with my conrod assembly ? I am going out to Dandenong tommorrow and might drop by if you are done with the rod.
Paul
._T_.
Re: 3sge cam specs needed Wed, 19 November 2003 21:35 Go to previous message
paul,
i just need the time to measure the rings.
you can drop by today if you want.
rod is stuffed though!!
T
Previous Topic:Extremly high pressure in the 18R-C
Next Topic:Beams 3sge tuning info.
Current Time: Sat Oct 17 16:36:11 UTC 2026
Total time taken to generate the page: 0.0049159526824951 seconds
