Toymods » Tech & Conversions » Haltech - 1JZ Oxygen Sensor
Skip
Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 00:57 Go to next message
I need to hook up my O2 sensor to my Haltech. Being 3 wire, the haltech requires the O2 signal, ground and +13.8 VDC. Now the 3 wires on the O2 sensor are blue, and 2 black. I think it would be safe to say the blue is the signal, identifying the others, i dont know how. Can anyone who has wired one up before steer me in the right direction?
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 01:41 Go to previous messageGo to next message
yup, easy as...
the heater will have a resistance of about 4-6ohms usually. there is open circuit from heater to the signal wire.
the two heater wires are usually the same colour as there is polarity to it, it's just a resistance heater.
so, find the two wires with about 5 ohms resistance between them and they are the heater, and the other one is signal. make sure that you have a very good ground from the exhaust to the ECU ground point, as the signals ground is the body of the O2 sensor. if you have a shitty ground, the readings will be incorrect.
fyi, the 4 wire ones i have (both NTK and Bosch) have two white wires for the heater, a grey wire for signal ground, and a black wire for O2 signal.
Danish
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 04:52 Go to previous messageGo to next message
The heater?
Skip
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 04:57 Go to previous messageGo to next message
Very detailed info oldcorollas, thanks. So the heater and ground will have about 5 ohms resistance each, and it doesnt matter if these wires are connected to the Haltech Ground and +13.8 VDC, any order?
Danish
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 05:27 Go to previous messageGo to next message
What does the heater have to do with connected the Oxygen Sensor to the ECU? I'm trying to do this at the moment with my MicroTech.
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 07:10 Go to previous messageGo to next message
the heater (inside the sensor) keeps the sensor at a near-constant temp so it reads correctly - turbo engines have wildy fluctuating exhaust gas temps.
also, heater gets the sensor warmed up quickly so the ECU can hop into closed-loop mode once the engine is at normal operating temps.
charles.
Skip
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 07:13 Go to previous messageGo to next message
I thought MicroTech had no closed loop mode?
Danish
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 07:33 Go to previous messageGo to next message
Thanks for explaining that! So my 1JZ oxy sensor has a heater built into it? I think your right skip, but I want so I can see if im running lean or rich on my handset. Same reason why I got rid of my Autometer boost gauge, so I could use the Handset.
[Updated on: Tue, 18 November 2003 07:34]
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 07:34 Go to previous messageGo to next message
Skip wrote on Tue, 18 November 2003 15:57
no, doesn't matter. the heater is just a resistance heater, so there is no polarity, which is why the wires are same colour Wink
just confirm the two same coloured wires have the right resistance.
what sensor is it? (like brand or car or whatever) can you pm me what the resistance is?
thanks Chuck, saves me typing Very Happy
skip, think you're right, thats what Dale was saying in another thread. don't know whay it wouldn't have closed loop tho, seems to easy to have not put it in the code.
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 07:38 Go to previous messageGo to next message
Danish, how many wires does it have? 3 or 4 is heated. keep in mind that the narrow band sensors will only tell if you are rich or lean of the "stoichiometric" AFR, ie 14.7ish. if it goes lean on the gauge under power, thats bad, but you can still do damage even if it's richer than the switching point of the sensor, but leaner than the motor wants....
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 07:44 Go to previous messageGo to next message
would be a bit pointless having an O2 sensor but no closed loop mode? tho very handy as a tuning guide for tuning for cruise.
their website <www.microtechefi.com> doesn't have much in the way of product brochures (tho lots of wiring diagrams) ... but the Haltech, Link, EMS, Motec, etc systems all have closed loop modes.
anyway, looks like you have to find a source of 12V to power the heater (if you're using a 3 or 4 wire sensor) as the LT12 only has one wire (input) for the O2 sensor - the LT8 and LTX8 the same?
charles.
Skip
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 08:15 Go to previous messageGo to next message
oldcorollas: It's the standard 1JZGTE sensor, the motor came out of a Soarer. I will check the resistance tonight and post it up.
sideshow
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 09:16 Go to previous messageGo to next message
just my opinion for anyone connecting O2 sensors up on aftermarket ecus
i never ever connect the original oxy sensors to aftermarket ecus and will never ever trust them for an accurate reading
std O2 sensors dont work unless its at idle or just off
the reason u fit aftermarket ecus is to get more power so
no way will i trust a std O2 sensor
when tuning a car with aftermarket ecu the air/fuel mixture meter is worth about 2000 for an autronic type
and 400 for a cheapish O2 sensor or 1200 for a uego seonsor
these sensors get slower the more you use them
now that means to properly tune an aftermarket ecu you need about 2500 dollars worth of equipment
there is no way i would trust any other way
i hate those wanky air/fuel gauges cause all they do is go rich lean rich lean and are a waste of fukin money
if your aftermarket ecu is tuned properly and correctly by a specialist then leave it alone
[Updated on: Tue, 18 November 2003 09:17]
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 09:22 Go to previous messageGo to next message
true, narrow band are only for stoich, which you will only ever want when cruising with buggerall throttle.
i thought that most motors like it a bit rich at idle (or is that just lumpier cams??)
the NTK UEGO's were around $400-500, but the Techedge V2 DIYWB uses the Bosch LSU4 at $150 (from them) even so the controller, display and sensor are around 500-660 and you still have to build the kit...
agreed, the best tuning is done with dyno and 4 gas analyser, but a narrow band O2 is ok for closed loop, no throttle cruising.. well, good enough for most manufacturers..
heh heh, the blinky meters Smile like a knight-rider scanner Very Happy Very Happy
Skip
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 13:02 Go to previous messageGo to next message
My haltech manual says the UEGO sensors dont last very long, correct?
The resistance across the two black wires (heater) was 6.7 ohms, as you would expect connecting across blue to black shows nothing. Problem solved thanks heaps.
sideshow
Re: Haltech - 1JZ Oxygen Sensor Tue, 18 November 2003 20:55 Go to previous message
most oxy sensors used for tuning get replaced every yr or few yrs if used regularly
Previous Topic:Attn: 1JZ owners - faulty PCV valve?
Next Topic:4a dizzy question
Current Time: Thu Oct 22 19:51:29 UTC 2026
Total time taken to generate the page: 0.0053191184997559 seconds
