Toymods » General Car Talk » Wheel alignment products - where would you buy from?
Wheel alignment products - where would you buy from? Tue, 18 November 2003 01:24 Go to next message
Hello, has anyone ever seen those turntable style plates that wheel alignment shops use. They sit under the front wheels and show in degrees the toe.
I want to purchase a set but not sure where to find them. Doesn't help when I don't even know what they are called Razz
Joel
Lambolica
Northwestern Sydney
Re: Wheel alignment products - where would you buy from? Tue, 18 November 2003 02:00 Go to previous messageGo to next message
Possibly Snap-on they have everthing else, I can't help with the name.
Found this on a quick search
http://www.safetsteer.com.au
Download the PDF cat. Pages 29-34
go for the laser alingment set Evil or Very Mad
[Updated on: Tue, 18 November 2003 02:08]
gold28
Madrid - Spain
Re: Wheel alignment products - where would you buy from? Wed, 19 November 2003 02:27 Go to previous messageGo to next message
Or you could do it on the cheap and use a couple of straight edges and greased plates.
Lambolica
Northwestern Sydney
Re: Wheel alignment products - where would you buy from? Wed, 19 November 2003 02:34 Go to previous messageGo to next message
or go alittle more advanced than that and strap some of those cheap laser pointers to the plate!
and when you're finished you can use them as washer wiper lights Rolling Eyes
Re: Wheel alignment products - where would you buy from? Thu, 20 November 2003 01:08 Go to previous messageGo to next message
Yeah I think DIY is the way to go.. $500 each plate from repco!
Cressida Supra
Re: Wheel alignment products - where would you buy from? Thu, 20 November 2003 03:19 Go to previous messageGo to next message
i'm guessing you change the camber/caster/toe a lot on your car?
its only $33 to get it done professionally
gold28
Madrid - Spain
Re: Wheel alignment products - where would you buy from? Thu, 20 November 2003 03:22 Go to previous messageGo to next message
$1000 makes for a lot of wheel alignments
Re: Wheel alignment products - where would you buy from? Thu, 20 November 2003 03:23 Go to previous messageGo to next message
Not that a i change it a lot, but at the moment setting up rack n pinion steering which is being designed from scratch. So during this process of setting it up i'd like to regulary adjust/check the toe. As eliminating bump steer will require changes to rack position etc and everytime I move it around toe needs to be checked again.
Dont want to have to drive it back and forth to wheel alignment shop 10 times or something before I get it right.
Cressida Supra
Re: Wheel alignment products - where would you buy from? Thu, 20 November 2003 03:28 Go to previous messageGo to next message
just set it up best you can, and then take it in, i'm sure after 3 or 4 visits they'll do it for free
just go in to a tyre/suspension shop and talk to them aobut it
they will prolly make you a deal
gold28
Madrid - Spain
Re: Wheel alignment products - where would you buy from? Thu, 20 November 2003 03:32 Go to previous message
THe greased plates and straight edges work really well and cost bugger all. Not quite as user friendly as the fancy smancy ones that an alignment shop uses but it will get you close to the money.
Previous Topic:Att: Anyone up for a Toyota Cruise in Sydney????
Next Topic:Finaly its time...
Current Time: Fri Nov 20 06:50:19 UTC 2026
Total time taken to generate the page: 0.016699075698853 seconds
