Toymods » Tech & Conversions » How to remove diff centre from aus ae86?
ae95
How to remove diff centre from aus ae86? Tue, 18 November 2003 05:40 Go to next message
I have decided to weld my diff as my disc to disc isnt arriving till february. So how do i go about taking the centre out?
thanks Very Happy
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: How to remove diff centre from aus ae86? Tue, 18 November 2003 05:51 Go to previous messageGo to next message
jack the car up and place on stands
with handbrake on and in gear, undo the tailshaft bolts on the diff center and the wheel studs on the wheel.. then release handbrake and take outta gear.
take drum off, undo the 4 X 14mm bolts using a socket and extension bar by tuning the axles and placing socket and bar through the hols.
undo these and pull axles out.. if they are tight as then bolt on a spare wheel backwards and hit the rim with a hammer, this will never fail to get it out.
once youve unslotted axles on both sides (bearings need to come right out, whole axle can rest there but splines need to be out of center)
then, Undo the drainplug and drian the oil.
then undo the 12mm bolts on the centre, and thats it.. pull the center out and your done.
Re: How to remove diff centre from aus ae86? Tue, 18 November 2003 07:40 Go to previous messageGo to next message
a 1UZ will take it out pretty quick Evil or Very Mad Evil or Very Mad Evil or Very Mad
ahh, it's one of those days Sad
Simon, after reading that i reckon i could do it with my eyes closed never having seen the diff Very Happy
Simon-AE86
Banned user
Re: How to remove diff centre from aus ae86? Tue, 18 November 2003 07:57 Go to previous messageGo to next message
Stewart: god knows ive done it a few times!!! hahaha
sometimes i think i spend more time UNDER my cars then IN them Wink
nomuken
Randwick Sydney
Re: How to remove diff centre from aus ae86? Tue, 18 November 2003 08:13 Go to previous messageGo to next message
damn simon u sound like u done that a few times ;
U sure its a good idea to lock ure diff Evil or Very Mad
Re: How to remove diff centre from aus ae86? Tue, 18 November 2003 08:53 Go to previous messageGo to next message
Simon-MrRx7 wrote on Tue, 18 November 2003 18:57
how many times since the LSD went in? or was that the cure??
do you break boxes?? i tend to break gearboxes, but have only had 1 unexpected diff failure.
Simon-AE86
Banned user
Re: How to remove diff centre from aus ae86? Tue, 18 November 2003 10:27 Go to previous messageGo to next message
nope never broken an LSD, but all those open diffs and lockers certainly have broken Wink
also never broken a T50.. i baby them Wink
ae95
Re: How to remove diff centre from aus ae86? Wed, 19 November 2003 05:16 Go to previous messageGo to next message
thanks simon!
tanman
Re: How to remove diff centre from aus ae86? Wed, 19 November 2003 05:51 Go to previous messageGo to next message
Dont forget if the yoke slides out of the gearbox oil will leak out.
Simon-AE86
Banned user
Re: How to remove diff centre from aus ae86? Wed, 19 November 2003 05:54 Go to previous messageGo to next message
Its a two piece shaft with a center support
dont need to worry about that at all!!
too easy
IRA11Y
Club Member
Re: How to remove diff centre from aus ae86? Wed, 19 November 2003 08:36 Go to previous messageGo to next message
But .. if you dont jack the diff up as opposed to the chasis you wont be able drop the tailshaft off the centre without undoing the 2 centre bolts, so put the jack under the diff housing.
ae95
Re: How to remove diff centre from aus ae86? Wed, 19 November 2003 11:09 Go to previous message
cheers guys, i managed to get the diff centre out !!!
Previous Topic:How do i remove valves, springs etc (2J)
Next Topic:Structural Optimisation of an Automotive Wheel
Current Time: Sat Oct 17 12:00:40 UTC 2026
Total time taken to generate the page: 0.64855289459229 seconds
