Toymods » Tech & Conversions » water bottle for sprinter... what should i use??
barbel
water bottle for sprinter... what should i use?? Thu, 25 July 2002 22:29 Go to next message
now that i have a 4age in my sprinter was just wondering what i could do with the water bottle situation. i only have the old standard one, and know that with front cuts they had 2 seperate bottle which bolted up towards the struts.
reason being i would like to move the air filter further towards the rear of the headlight and box it up, instead of it hangin off close to the throttle body.
has any one used any other car's water bottle's or just got custom one's as i am thinking.
Pumpkin
Toymods Board Member
Re: water bottle for sprinter... what should i use?? Fri, 26 July 2002 02:30 Go to previous messageGo to next message
Waterbottle or overflow bottle ?? Question If is just your water bottle you can use the bag style ones and tuck it away in one of the guards... Smiley =
barbel
Re: water bottle for sprinter... what should i use?? Fri, 26 July 2002 02:46 Go to previous messageGo to next message
well both i guess, in a sprinter they are physically joined together at the front.
but that is a thought, thanks
Sam
Sydney, Australia
Re: water bottle for sprinter... what should i use?? Fri, 26 July 2002 04:04 Go to previous messageGo to next message
arent they seperate but bolted together? I havent yet bothered to look..
barbel
Re: water bottle for sprinter... what should i use?? Fri, 26 July 2002 04:07 Go to previous messageGo to next message
yeah, i think they are like rivetted together, not so mucha bold but prob can pull them apart,
i might have to look for some smaller items from other cars...
jazae86
Re: water bottle for sprinter... what should i use?? Fri, 26 July 2002 15:04 Go to previous messageGo to next message
I have the same problem: I have a factory 4AG AE86 air box, and it bolts in now worries but sits exactly where the 4AC washer/overflow bottle combo is.
I hear, but havn't searched, that the overflow botle off a Cappela bolts and looks like the factory 4ag AE86 one. (ie to driver strut housing). For the water bottle: I'm not sure what to do. 1 is to mount one low down under/near the battery as heigh is not an issue (there are to pumps: one on bottle, one near outlet to bonnet). Other option is to use an AE82 type overflow that mounts next to the battery.
If you work it out: post it or I will. All I know is that when mine is cheaked for road worthy-ness, I am borrowing a friend factory bottles Smile
The thing to be carefull of is that the overflow cannot be lower than the radiator outlet, or it may siphon(sic) off the radiator fluid.
Jaz
fergo308
Eastern Sydney
Re: water bottle for sprinter... what should i use?? Sat, 27 July 2002 01:04 Go to previous messageGo to next message
I plan to remove the Oz-spec bottles when my 20V goes in,to give me a bit more room for my trumpets,and some ducting from behind the pop-up headlight.
I'm going to be using a ke70 washer bottle,mounted down on the chassis rail,and either a prius,or AE101 overflow bottle,bolted between the battery and the radiator.
you CAN separate the std bottle pair,you just need to break the rivets that join them. you may need to make up a custom bracket or two to keep the bottle you leave in in place securely though.
Justin...
DanielJ
Re: water bottle for sprinter... what should i use?? Sat, 27 July 2002 02:24 Go to previous message
Yep have the same problem with the 20V conversion. Ended up getting a ke3# washer bottle and bolting to the L/H/S side of the engine bay (around the strut tower) and got an overflow bottle from a Paseo and jammed it between the battery and radiator support panel. The motor on the washer bottle is only *just* powerful enough to pump water through, so I have to somehow adapt the original washer motor to fit.....one day Smile
Previous Topic:roll cages
Next Topic:need 7M-GE info
Current Time: Thu Nov 19 09:36:00 UTC 2026
Total time taken to generate the page: 0.089027881622314 seconds
