Toymods » Tech & Conversions » 7MGTE - Temperature go up, temperature go down.
ViNcEnXo
7MGTE - Temperature go up, temperature go down. Tue, 18 November 2003 08:26 Go to next message
Hey guys,
Picked up the new car today and the temperature guage is all over the shop, sometimes it just sits on full cold, then it'll jump to normal, then jump all the way to hot, and anywhere inbetween. Car was running fine, not missing, nothing, it wasn't overheating, just that the temp guage is all over the place.
Could it be a temp sensor?
Where is the temp sensor?
Anything at all?
Paul
Re: 7MGTE - Temperature go up, temperature go down. Tue, 18 November 2003 09:29 Go to previous messageGo to next message
Air in the cooling system. You need to "burp" it as per the factory manual.
4AGESprinter
Re: 7MGTE - Temperature go up, temperature go down. Tue, 18 November 2003 11:01 Go to previous messageGo to next message
would someone be able to post up the procedure? as i'm sure ViNcEnXo doesn't have a factory manual Confused
ma61_turbo
Re: 7MGTE - Temperature go up, temperature go down. Tue, 18 November 2003 11:33 Go to previous messageGo to next message
4AGESprinter wrote on Tue, 18 November 2003 21:31
Park it with the nose pointing uphill, take the rad cap off and let it idle. All the air pockets should make their way to the radiator. I guess you can stop when the bubbles stop?
Perhaps someone can add to this?
ZZT231
melbourne.vic.au
Re: 7MGTE - Temperature go up, temperature go down. Tue, 18 November 2003 11:36 Go to previous messageGo to next message
Oh... And you may want to add some water to the radiator as it burps away...
Cheers.
BlackSupra
Re: 7MGTE - Temperature go up, temperature go down. Tue, 18 November 2003 12:09 Go to previous messageGo to next message
How about you take the time to flush the system
ViNcEnXo
Re: 7MGTE - Temperature go up, temperature go down. Tue, 18 November 2003 13:17 Go to previous messageGo to next message
Thanks for the help guys!
I'll get on that first thing in the morning!
The connector for the temp sensor is broken, but jiggling that isn't making any difference.
V8_MA61
Re: 7MGTE - Temperature go up, temperature go down. Tue, 18 November 2003 13:20 Go to previous messageGo to next message
easiest way is:
1 Start car
2 Remove radiator cap
3 watch the coolant raising bubbles in the neck where u can see the water
4 Let the car run with the cap off until all the bubbles stop..it should take a few minutes.
5 Put the cap back on
6 Hopefully that has fixed your problem!
wilbo666
Re: 7MGTE - Temperature go up, temperature go down. Tue, 18 November 2003 13:56 Go to previous messageGo to next message
http://www.supras.com/sogidb/index.php?jumpto=tech center&tech_jumpto=display_techtip&id=21
enjoy
ViNcEnXo
Re: 7MGTE - Temperature go up, temperature go down. Tue, 18 November 2003 14:03 Go to previous messageGo to next message
Great...
I'll get this done asap.
Is it worth using the Toyota Red coolant?
Paul
Danners
Central Coast, NSW
Re: 7MGTE - Temperature go up, temperature go down. Tue, 18 November 2003 21:58 Go to previous messageGo to next message
YES use the Toyota red coolant.... you're silly if you run anything else. Completely flush your whole system clean and then fill it with the red goods.
Just to let you know I had EXACTLY the same problem with my car... i think the digital gauge died because i flushed the system at least three times trying to fix it to no avail. I simply just bought an aftermarket water temp gauge and mounted it under my dash! now i know exactly how hot it is at all times
by the way, what would an optimal operating temperature for a 7M be? mine always seems to run between 80-90 degrees celsius
Dan
Re: 7MGTE - Temperature go up, temperature go down. Tue, 18 November 2003 22:59 Go to previous messageGo to next message
Toyota red coolant is pretty much the best stuff out there. I won't use anything else in my cars.
ViNcEnXo
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 00:25 Go to previous messageGo to next message
Do I need to take it anywhere to do a flush? Or can I do it myself? And I'm guessing Toyota is the place to get the red coolant?
Paul
ViNcEnXo
And 80-90 degrees is pretty normal for most cars, 90 is starting to get a little on the warm side but nothing to be concerned about.
Chris Davey
sunny coast, qld
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 01:50 Go to previous messageGo to next message
my corolla runs at 72% most of the time. Smile no turbo though.
i have never heard of this red coolant. anyone know approximate price? suitable for all cars?
ViNcEnXo
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 03:04 Go to previous messageGo to next message
From what I've heard the red coolant is the best you can get.
I just went and bought 4 Litres.... Cost me $34. Small price to pay for a vital part of you car.
dingaling
tas
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 05:20 Go to previous messageGo to next message
My temp gage has been wacko since i got the car, one minute it's cold, next minute it's up the top, back down, back up, back down etc.
So after reading this thread i whent and burped my cooling system. Drove the supra up on ramps, start the engine with the radiator cap off and let it warm up. Then i turned my heater on full bore. Finally 4 bubbles pop out (smallish ones) so i guess that wasn't much of a problem, and my heater never even got hot, i don't think it's ever worked. Also noted my AC doesn't come out very cold, just normal air comes thru. bugger!
lumpy
Adelaide, SA
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 05:30 Go to previous messageGo to next message
Dingaling,
From the desription of your problem I'd suggest you climate control box is faulty. Mine was the same, we checked the heater valve, checked the air-con, etc etc, even checked the climate control box with a multi meter and looked OK. Swapped it over for a different one, suddenly everythings working again. I've heard this happen to a few other people as well
ViNcEnXo
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 05:34 Go to previous messageGo to next message
My climate control is working fine except when I turn the temperature up. Then nothing at all happens, no air, no heat, nothing.
I thought that was odd.
ViNcEnXo
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 06:28 Go to previous messageGo to next message
Where on the standard digital guage do the cars normally sit?
Paul
BlackSupra
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 07:41 Go to previous messageGo to next message
Smack bang in the middle one would hope.
thug_immortal
Camden, NSW
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 09:00 Go to previous messageGo to next message
i flushed my system today, runs fine now, temp guage stays the same at the normal position Very Happy my guess is steam was playing tricks with the sensor Confused
Neway ive put some of that anti rust stuff in the system and will flush the system again on fri to see what happens but it seems that my problem is fixed Very Happy
Cheers for the help guys, i knew i could count on you Very Happy
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 10:22 Go to previous messageGo to next message
By "anti rust stuff" I hope you mean Toyota red coolant?
dingaling
tas
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 13:02 Go to previous messageGo to next message
thanx for the tip lumpy, i hope a climate box isn;t expensive, how do you get to it? behind the dash?
Norbie, my supra has green crap in it for coolant, it's been that way for 4 months since i got the car. I hope the previous owner knew what he was doing and buaght a compatible coolant?
i'll get the toyota red stuff tommorow! (by the way how do I get distilled water to mix with the coolant? or just use normal tap water?)
STR8 2.8
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 13:05 Go to previous messageGo to next message
no use distilled water not tap water...
u can buy it from hardware stores, or even BIG W probably
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 13:06 Go to previous messageGo to next message
Tap water isn't so bad if you're using it to dilute coolant, but distilled water is definitely better.
BlackSupra
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 13:08 Go to previous messageGo to next message
The can't be assed factor heavily influences my decision when opting to use the conveniently close by tap water.
I cant beleive you use distilled water for a 5me! Very Happy
dingaling
tas
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 13:16 Go to previous messageGo to next message
thanx for the heads up, i'll get the distilled stuff, i hear you can make it yourself if you boil water and catch the evaporated steam, but hell that would take a looong time.
this is offtopic, but anyway... i just whent for a ride in a 2002 Mercedes Kompressor (e-class i think it was), dam sweet car! smooth german goodness, anyway the driver just had to show it off, and so he floored it, not bad gets up and goes quite effortlessly. But i really offended him when i said "my supra feels twice as fast as that". Altho it's impressive for a 4 cylinder. Those cars sure pick up some attention from the public, i felt like a rich snobby bastard bieng in that car.
thug_immortal
Camden, NSW
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 21:19 Go to previous messageGo to next message
na the anti rust stuff gets rid of the rust in the radiator, it dilutes it or something n it just drains out? The toyota red coolant goes in tomorrow when i re-flush the system so its really nice and clean Very Happy
Whats so good about the toyota red stuff? is it that much diff to joe bloggs brand green stuff? (i take it it is)
rob_RA40
c'town, NSW
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 21:28 Go to previous messageGo to next message
toyota have specifically made the red stuff to suit the type metal they use in the block and head.
lumpy
Adelaide, SA
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 22:08 Go to previous messageGo to next message
The climate control box I'm talking about is the one with all the buttons and temperature slider on it in the dash. For some reason they fail and no matter where you put the slider it doesn't change temperature (ie turn air-con or heater valve on). I got one when I did my conversion (from my jza-70 front cut). Not sure where else you'd find one - perhaps the guy wrecking an ma70 in the parts for sale section?
ViNcEnXo
Re: 7MGTE - Temperature go up, temperature go down. Wed, 19 November 2003 22:43 Go to previous messageGo to next message
My Soarer doesn't have a slider, I have a LED read out of the temperature. And I change the temp on the steering wheel.
[Updated on: Wed, 19 November 2003 22:44]
STR8 2.8
Re: 7MGTE - Temperature go up, temperature go down. Thu, 20 November 2003 01:02 Go to previous messageGo to next message
glen--->
haha no i was lazy and used premix crap, i wouldnt really care about tap water for the 5m tho
ViNcEnXo
Re: 7MGTE - Temperature go up, temperature go down. Thu, 20 November 2003 11:22 Go to previous messageGo to next message
Oh well.
Turns out it was a Blown headgasket.
I could cry.
lumpy
Adelaide, SA
Re: 7MGTE - Temperature go up, temperature go down. Thu, 20 November 2003 21:50 Go to previous messageGo to next message
This is a good of example of Ockam's Razor - the simplest explanation is the most probable one.
In the case of the 7m, overheating and temperature fluctuations = blown headgasket!
Sorry to hear that, I hope it's still under some form of warranty. Crying or Very Sad
Allan
Re: 7MGTE - Temperature go up, temperature go down. Fri, 21 November 2003 01:02 Go to previous messageGo to next message
ViNcEnXo wrote on Thu, 20 November 2003 22:22
Oh well.
I could cry.
ARP studs, surface head and clean the block as good as possable and put a new toyota gasket in
Smile again!
Allan
rvrolla
Central Coast
Re: 7MGTE - Temperature go up, temperature go down. Fri, 21 November 2003 02:14 Go to previous messageGo to next message
Oh well.
I could cry.
I was going to say this is what mine did before I fixed my BHG Sad
Exhaust/air in the cooling system, temp probe couldn't get a proper reading from the air/gases.
Sorry to hear dude, but, I hate to say it, it is expected if it hasn't been done before.
bbaacchhyy
Re: 7MGTE - Temperature go up, temperature go down. Fri, 21 November 2003 02:17 Go to previous messageGo to next message
Allan,
Are you saying that unless you fully rebuild the block and intend to use mega boost, that a well prepped block and heads with the appropriate torque on ARP studs with the composite gasket will suffice for 14 - 15psi boost ? Laughing Very Happy
What would be a realistic max boost level for a composite gasket ? Confused
Michael B
Allan
Re: 7MGTE - Temperature go up, temperature go down. Fri, 21 November 2003 12:46 Go to previous messageGo to next message
bbaacchhyy wrote on Fri, 21 November 2003 13:17
Allan,
Michael B
With Correct tune and prep it should! (so far 10,000km+ HARD at the razors edge of fuel cut with an in-car block clean, geting a SMOOTH surface on the head, the correct torque figures on the ARP studs and puting it together with care not to damage any surfaces) but if it is detonating goodbye gasket but then I would rather a dead gasket then pistons!
A gasket only blows if theres a problem, be that a monkey on the 7m production line that can't use a torque wrench (unfortunately the case) or poor tune of the engine causing extreme cyl pressures.
Donate a set of 550cc injectors and a 1UZ-FE afm and ill test above 11psi Smile
Allan
bbaacchhyy
Re: 7MGTE - Temperature go up, temperature go down. Sun, 23 November 2003 22:29 Go to previous message
Thanks for that Allan,
As for donataing a set...... ummmm ...... NFW Very Happy
I guess I will find out one way or another. To start with, I plan to stick to a well tuned setup with the stock/composite gasket and the ARP studs and then see what happens from there.
I'm thinking that 14psi will be heaps of fun. *psi is at the moment, so another 6 will be magic Evil or Very Mad
Michael B
Previous Topic:Another one bites the dust
Next Topic:Motec calibration file for 4AGE?
Current Time: Thu Oct 29 21:04:48 UTC 2026
Total time taken to generate the page: 0.12056708335876 seconds
