Toymods » Tech & Conversions » Oil in intake pipe & filter ?!?
SXer
Oil in intake pipe & filter ?!? Tue, 18 November 2003 21:26 Go to next message
I opened up the sir-filter box on my ae82 tiwn-cam last night to discover that the filter had a fair bit of oil on it. If I look up the intake pipe (towards the throttle) I can see that some oil has run down the bottom of the pipe. My question is - where did this oil come from ? Could it be the PCV system? Does this mean that I have lots of blow-by or something? confused Confused Confused Confused Confused Confused Confused
gold28
Madrid - Spain
Re: Oil in intake pipe & filter ?!? Tue, 18 November 2003 23:28 Go to previous message
The crank case vent which is on your cam/rocker cover should be plumbed into your intake. If you start revving it hard, particularly if the engine is getting old, the crank case will pressurise and force the air through this breather into your intake. This air will contain oil fumes which condensate in your intake.
The reason why it is plumbed into your intake is because it is illegal to have it venting to the atmosphere (don't want to get oil on the road).
The oil will hamper the performance a small amount, but not much.
If you want it to stop, change your driving habbits or install a filter.
Previous Topic:hks GT2510 on 3tgte
Next Topic:engineering a standard engine?
Current Time: Wed Oct 21 10:54:33 UTC 2026
Total time taken to generate the page: 0.0078179836273193 seconds
