Toymods » Tech & Conversions » Beams 3sge tuning info.
no_tofu_speed
Jab what?!!?!
Beams 3sge tuning info. Wed, 19 November 2003 03:59 Go to next message
Um how much would a Beams 3sge be worth, and is the engine designed in a way so that it is easy enough to run turbine on at a later stage? And what the hell does the Beams mean. I know it is in the Altezza.
How much is a 3rd gen 3sgte worth and butting it to the right box would it fit in an ae86 as it is a 4wd setup initially.
Re: Beams 3sge tuning info. Wed, 19 November 2003 04:31 Go to previous messageGo to next message
The 11:1+ compression and light internals mean its probably not the best engine for foreced induction without a lot of reworking.
no_tofu_speed
Jab what?!!?!
Re: Beams 3sge tuning info. Wed, 19 November 2003 05:13 Go to previous messageGo to next message
11:1.. i see.
Obviously it is meant to run optimum N/A.
Thanks for that!
ra23celica
Re: Beams 3sge tuning info. Wed, 19 November 2003 05:54 Go to previous messageGo to next message
Beams stands for Breakthrough Engine with Advanced Mechanism System, or for us mere mortals....Bought Engine Another Mortgage.
And yes, the lightweight reciprocating internals, 11.1 comp. ratio and VVTLi do not lend themselves to turbocharging.
If you want this motor so you can mount it inline in a RWD car, its good, but needs high revs to work and is $$$. Better off cost wise to go a 3S-GTE from an MR2 Turbo. And if you really want to impress this list and spend $$$, buy a 3S GE Beams block and add the GTE head and turbo. Now that would be a project.
Mitch.
Re: Beams 3sge tuning info. Wed, 19 November 2003 05:58 Go to previous messageGo to next message
If it were me, I'd be leaving the head as it is, but getting new pistons made up to lower the compression. A lot of Honda's in the States, like them or not are making big power with their VTEC + turbo setups.
Re: Beams 3sge tuning info. Wed, 19 November 2003 06:24 Go to previous messageGo to next message
hmm, google is your friend.
google for "altezza RS200" and you wil find engine specs.
google for "BEAMS 3SGE" and you will out more about things like valve materials etc etc....
and if you google for "altezza half cut" on google 'Aus'
you will find prices for them.
c'mon, it aint that hard Wink Razz
btw, the answers are 210Nm@6400, 210ps@7500, titanium, $6000-8000
no_tofu_speed
Jab what?!!?!
Re: Beams 3sge tuning info. Wed, 19 November 2003 08:50 Go to previous messageGo to next message
Kool thanks Mista Google!
Yep I am leaving the Beams alone! I agree with the second description!
Re: Beams 3sge tuning info. Wed, 19 November 2003 12:55 Go to previous messageGo to next message
Very Happy thanks, i try Wink
the BEAMS 3SGE is to the 3SGE, what the 4AG 20 valve is to the 4AG 16valve.
it's basically a tuned, optimised NA motor with a cam, but ith the advantage of a smaller cam profile for low revs. it's an awesoem piece of work, but is a lot of cash. then again, it's about the most you could get out of an NA 3SGE without stupid amounts of work, so, in a way, you are paying for a modded motor... and it comes with a 6 speed Very Happy
._T_.
Re: Beams 3sge tuning info. Wed, 19 November 2003 21:32 Go to previous message
c-one in japan actually do a supercharger kit for the altessa. someone else does a turbo kit. only 320hp though.
T
Previous Topic:3sge cam specs needed
Next Topic:dumb ass question <-----
Current Time: Sun Oct 18 05:21:18 UTC 2026
Total time taken to generate the page: 0.037101030349731 seconds
