Toymods » Tech & Conversions » Changing KE20 Stud pattern
closer
Changing KE20 Stud pattern Wed, 19 November 2003 05:04 Go to next message
Hey guys im new to toymods so any help would be appreicated.
I did a search but couldnt find exactly what im looking for.
I have a set of wheels lined up (ive been looking for these for ages, finally found them but they are 114.3 x 4 and my ke20 is 4 x 110. Is there a hub, or strut i can bolt in to get this stud pattern ??
thanks guys
shannon
Re: Changing KE20 Stud pattern Wed, 19 November 2003 06:26 Go to previous messageGo to next message
KE30/55 hubs with KE20 bearings.
for the rear? heard rumours you can chave down the end of the KE30 axles and put them in... check clearances carefully tho..
blown 5k
new zealand
Re: Changing KE20 Stud pattern Tue, 25 November 2003 08:38 Go to previous message
With my KE20 i adapted ke70 hubs/rotors(bigger9"from memory) and calipers fitted a c20 vanette master cylinder 3/4"bore diameter/remote reservoirs vertual bolt in(apart from being a tandem m/cylinder) and for the rear went to ke30 6" diff head in ke20 housing with ke30 axles and larger wheel cylinders this changed the stud pattern to 114.3x4 and stops it a hell of a lot better. Very Happy
[Updated on: Tue, 25 November 2003 08:39]
Previous Topic:1JZ Water Pump Again
Next Topic:MR2 chock problem, TO HIGH
Current Time: Sat Nov 21 03:11:51 UTC 2026
Total time taken to generate the page: 0.0042870044708252 seconds
