Toymods » Tech & Conversions » fuel- carb problem
ta2272
fuel- carb problem Wed, 19 November 2003 06:52 Go to next message
hey have just put a new 2tg in my car it sometimes runs well but somtimes it goes like cra when i put my foot to the floor it strugles and gurgle until i back off. i got it tuned and the changed 3 fuel pumps and the mechanic recons its because i have crap in my tank getting into the carb jets and temporilary blcoking it, and yes i havea a new fuel filter.
any help would be great
Jason
Skip
Re: fuel- carb problem Wed, 19 November 2003 08:09 Go to previous messageGo to next message
When you say you got it tuned, what do you mean, what was "tuned" exactly? Have you looked at the Carby? Could be an accelerator pump problem. Checked the float level? Temporary jet blocking sounds like BS to me.
ta2272
Re: fuel- carb problem Wed, 19 November 2003 10:22 Go to previous messageGo to next message
yes timming and carbs were tunned the carbs work fine when not under pressure, but sometimes when driving they struggle.
i dont know what it could be,
jason
Skip
Re: fuel- carb problem Thu, 20 November 2003 00:05 Go to previous messageGo to next message
Maybe the float level is so low when you floor it there is not enough fuel, it surges away from the jets. Take your aircleaner off, look down the carby and squirt the throttle with your hand to see if the accelerator pump is working properly.
ta2272
Re: fuel- carb problem Thu, 20 November 2003 00:16 Go to previous messageGo to next message
yeh i will check this but when i fill my tank up the problem is hardly there,
Skip
Re: fuel- carb problem Thu, 20 November 2003 01:43 Go to previous messageGo to next message
At what point of tank level does the problem start?
ta2272
Re: fuel- carb problem Thu, 20 November 2003 02:01 Go to previous messageGo to next message
last 1/4 of the tank
jason
Scorpion
Menai area of Sydney
Re: fuel- carb problem Thu, 20 November 2003 06:53 Go to previous messageGo to next message
Could be fuel moving around in the tank and away from the fuel pickup. i.e. baffles not doing their job or if fuel pickup has been changed at some time it may be bent and be not low enough in the tank. Does the problem occur on level ground, cornering left, cornering right, going uphill, going downhill, accelerating or a combination of the above ?
Skip
Re: fuel- carb problem Thu, 20 November 2003 23:33 Go to previous messageGo to next message
Could be some sort of surge problem?
I had a VK Calais with a warm 308, if i didnt have at least half a tank in it, it would surge. If i mashed my foot i would take off then a few seconds later come to a spluttering halt.
freakincage_com
north brisbane
Re: fuel- carb problem Fri, 21 November 2003 02:10 Go to previous messageGo to next message
my 2TG does the exact same thing!!!!! everyone i spoke to recons it needs a hardcore tune(dyno tune?) but my car does it wether i have a 1/4 tank or a full tank???
whatever
Re: fuel- carb problem Fri, 21 November 2003 02:52 Go to previous message
I have also just put in a 2TG and do not experience these problems with low fuel. It is consistent right down to the last 5 litres.
I assume you have twin solex carb setup?
Mine is shit from idle due to the angle that the accelerator cable attached to the throttle arm. The first 2-3 cm of movement of the accelerator causes a bigger motion of the throttle arm than the rest of the travel so moving the car from idle to 2-2.5k rpm is tricky. Probably not the same problem as yours though.
Previous Topic:Sera (Paseo?) Automatic to Manual Transmission Conversion
Next Topic:2TG overheating??
Current Time: Wed Nov 18 16:44:38 UTC 2026
Total time taken to generate the page: 0.0053431987762451 seconds
