Toymods » Tech & Conversions » new motor wearing in ????
ta2272
new motor wearing in ???? Wed, 19 November 2003 10:32 Go to next message
i have just put my 2tg in my car i have got new rings and bottom end bearings in it, how hard should i go on it, a few people say after a few 100k's its alright to hammer it if its just rings and bearings.
any over opinouins????
thanks jason
Steve M
Re: new motor wearing in ???? Thu, 20 November 2003 07:17 Go to previous messageGo to next message
Even if that is the case, I would feel a lot more comfortable treating it nicely for 1000km, and did with the 18RG.
Don't let it idle too long after first start up, take it for a drive asap.
First drive: full throttle but not above 3000RPM to seat the bearings. Try to do a long drive the first time, if it needs extra tuning (assuming carby version), do it along the way. 100ks is a good first drive.
For the first 100km try to keep the revs between 2000 and 3000 but not at the same revs for very long.(keep changing up and down gears if cruising)
occasionally giving it full throttle from 60kph - 100kph in fourth.
For the next three hundred, drive it normally but don't rev it above 3500.
After that drive it normally but not above 4500 until you've done 1000km.
Don't have it at the same rev range for too long, if you drive at 60kph a lot in this time, then alternate between third and fourth gear every few minutes.
Once you've done 1000kms I would be pretty sure that everythings is run in enough to give it a boot every now and then.
If you want to not totally thrash it for the next 400ks or so, that might be a good idea too, but that's up to you.
This is roughly the process I would do with any "new" engine that I put in, mainly because if anything goes wrong, you might get an indication while working in the engine, which is better thatn taking it straight to 7500rpm and having it shit its self.
Steve M
Re: new motor wearing in ???? Thu, 20 November 2003 07:19 Go to previous messageGo to next message
I probably should mention that I was running in a full recon though, not just a bottom end, although I would do the same for both.
Better to be safe than poor. This way you get to know the engine a little better too. Foreplay goes a long way.
Re: new motor wearing in ???? Thu, 20 November 2003 11:36 Go to previous messageGo to next message
Hmmm, my view is to go a bit harder a bit sooner... IE, no idling for times, below 4000rpm for first 20km, then under 6000 for about another 5km, then start to open it up a bit, after 200 or so km, change the oil and wring it's neck Evil or Very Mad
4DaDrift
Re: new motor wearing in ???? Thu, 20 November 2003 11:41 Go to previous message
bah drive it as if its a top fuel car
flat out
will then be set up 4 maximum performance and fi theres a prob it will let go eventually so might as wel do it while rebuilding everythings fresh in ya head than 6-12 months later
Previous Topic:Brisbane Engineers (auto -> manual engineering)
Next Topic:urgent: recommendations wanted for exhaust on 2TGEU
Current Time: Wed Nov 18 13:13:47 UTC 2026
Total time taken to generate the page: 0.0067799091339111 seconds
