Toymods » Tech & Conversions » Which Brake Master KE55 4AGZE?
MrGenius
icon5.gif  Which Brake Master KE55 4AGZE? Thu, 20 November 2003 04:13 Go to next message
Searched the site and couldnt find an answer, can someone tell me which brake master cylinder can be used in a KE55 sedan to clear a 4AGZE engine? Will a TA22 one fit? T18? Tercel?
Thanks in advance Smile
Re: Which Brake Master KE55 4AGZE? Thu, 20 November 2003 12:24 Go to previous messageGo to next message
Well, I dont know specifically, but the PBR KE55 one would be in the road a bit... a TA22 one would likely be a good bet with the reservior mounted up out of the way
Steve-AE86
Ademelaide, SA
Re: Which Brake Master KE55 4AGZE? Thu, 20 November 2003 15:05 Go to previous messageGo to next message
a KE30 one is a straight fit, has the same bore size, and clears.
it has a remote reservoir for the rears, and a small reservoir for the fronts....or it could be the other way around... Rolling Eyes Rolling Eyes Rolling Eyes
but it works.
Re: Which Brake Master KE55 4AGZE? Fri, 21 November 2003 00:33 Go to previous messageGo to next message
which KE30 one? the PBR or the jap import one?
Steve-AE86
Ademelaide, SA
Re: Which Brake Master KE55 4AGZE? Fri, 21 November 2003 00:38 Go to previous messageGo to next message
hmmm....can't remember. it's the one with 2 reservoirs. from memory, that's the only difference between the local and jap ones??
demuire
Ipswich
Re: Which Brake Master KE55 4AGZE? Fri, 21 November 2003 01:00 Go to previous messageGo to next message
You will one the jap import inline style one. It has 2 reservoirs. The PBR one (which is the square looking parallel one) won't fit, it's too wide. Both are same bore etc, you might need to reshape or get new brake lines to match. You will also need to get the brake booster from the same KE30, as the ones that came with the PBR is different. The KE30 came with 2 different styles of brake booster, the later ones are larger than the earlier ones. The whole assembly (booster + mc) will bolt on otherwise.
If you want to go a bigger bore (if you have bigger brakes etc) there are several options as well.
*edit* Looks a little like this (except 2 reservoirs):
http://images3.fotki.com/v30/photos/1/12090/261160/07100011-vi.jpg
[Updated on: Fri, 21 November 2003 01:03]
rollawagon
sunshine coast
Re: Which Brake Master KE55 4AGZE? Sat, 22 November 2003 12:02 Go to previous messageGo to next message
pretty sure it was this site the other nite i saw good advice
users.bigpond.net.au/lachlan/cars/ke25/ke25.html-1 2k
hope its right
JAZE
IRA11Y
Club Member
Re: Which Brake Master KE55 4AGZE? Sat, 22 November 2003 21:24 Go to previous messageGo to next message
hey demuire I thought it was illegal to use banjo fittings on a brake line??? did a shop do that for you?
But yes you are right the skyline unit is the way to go, I got one for my brake upgrade for less than $100 from SSS, theres no such thing as pedal loss anymore Smile
Ill put up a pic of the master later
[Updated on: Sat, 22 November 2003 21:25]
demuire
Ipswich
Re: Which Brake Master KE55 4AGZE? Sat, 22 November 2003 21:36 Go to previous messageGo to next message
IRA11Y: No idea about that. The Pajero (which is where my mc is from) uses a banjo as well, but I had to get a different one because the Pajero banjo has two outlets. Anyway got the banjo free Smile The mc doesn't have an olive on that line (hence needing a banjo or something else to seat the brake line to), only on the other line has an olive.
MrGenius
Re: Which Brake Master KE55 4AGZE? Sun, 23 November 2003 01:03 Go to previous messageGo to next message
Cheers fellas, some more pics would be good too Smile
demuire
Ipswich
Re: Which Brake Master KE55 4AGZE? Sun, 23 November 2003 09:24 Go to previous messageGo to next message
MrGenuius: more pics:
http://fookseung.fotki.com/automotive-1/bodgy-1/co rona_front_brake/
Grega
melbourne.victoria.austra...
Re: Which Brake Master KE55 4AGZE? Sun, 23 November 2003 19:32 Go to previous messageGo to next message
fook, what model pajero did that master come off (ie: if i ordered one)
your booster looks almost identical to my TA22 one - methinks that it would fit it pretty well.
how do you find the XT130 calipers too?
demuire
Ipswich
Re: Which Brake Master KE55 4AGZE? Sun, 23 November 2003 20:50 Go to previous messageGo to next message
Grega: part number JB1762. Not sure what model it came off, I've seen it in several models though. Some random brake master cylinder information:
http://demuire.freeshell.org/cgi-bin/mods/apage/ap age.cgi?f=randomauto.html&apdir=automotive
XT130 calipers are great, they pull up the car very well and never fade. Mind you I'm running RaceBrakes RB74 pads and I only have 32hp... I'll be running the Pug/Hilux combo on my KE35 which is getting the 4AGE.
Re: Which Brake Master KE55 4AGZE? Sun, 23 November 2003 22:55 Go to previous messageGo to next message
That cylinder is from an NG pajero - got any idea on the size? (I'll look it up later I spose!)
demuire
Ipswich
Re: Which Brake Master KE55 4AGZE? Sun, 23 November 2003 23:48 Go to previous messageGo to next message
As on my webpage: 15/16"
Grega
Re: Which Brake Master KE55 4AGZE? Mon, 24 November 2003 01:24 Go to previous messageGo to next message
shinny reckon that would be goodness for the ta22
thanks fook!
Re: Which Brake Master KE55 4AGZE? Mon, 24 November 2003 11:21 Go to previous messageGo to next message
Now's the time to do the rest of the ta22 brakes while you're at it Greg Evil or Very Mad
Grega
Re: Which Brake Master KE55 4AGZE? Mon, 24 November 2003 23:43 Go to previous message
yes indeedy shinny it is. problem is timing is right but funds aint
Previous Topic:Installing Koni Yellows
Next Topic:4AC flywheel on 4age?
Current Time: Fri Oct 23 19:24:00 UTC 2026
Total time taken to generate the page: 0.0072100162506104 seconds
