Toymods » Tech & Conversions » Clutch Bleeding Problem
Skip
Clutch Bleeding Problem Thu, 20 November 2003 23:39 Go to next message
While doing my engine conversion ive had to put a new clutch setup in including a new slave cylinder. Obviously all this needs to be bled up. When I bleed it i get full pedal, everything works fine, but by the next day the pedal is gone again. This has happened 3 times now, i.e. ive bled it 3 times on 3 different days. Is this unusual?
When i look over my lines I cant see any leaking fluid anywhere, my master was working fine before i did the conversion.
[Updated on: Thu, 20 November 2003 23:40]
Re: Clutch Bleeding Problem Thu, 20 November 2003 23:45 Go to previous messageGo to next message
The most obvious answer is your master cylinder is stuffed. Rebuilding it is cheap and easy though. Smile
JDM hachi
was adelaide now newcastle
Re: Clutch Bleeding Problem Fri, 21 November 2003 01:25 Go to previous messageGo to next message
is the fluid disappearing from the resivoir?, if so like norbie says sounds like the master cylinder, when this was leaky on my sprinter, it leaked into the car, leaving a nice pool of clutch fluid on the floor of the drivers seat, i had issues for weeks before i realised it was leaking into the car.
matty.
Skip
Re: Clutch Bleeding Problem Fri, 21 November 2003 01:41 Go to previous messageGo to next message
I wouldnt think it was the master, the car has only done 100,000kms, plus it was working fine with the old setup, before I did the conversion. And im not loosing any fluid either. Maybe it just has a serious amount of air, being a new slave and all?
FWDCelica
sydney,nsw.oz.
Re: Clutch Bleeding Problem Fri, 21 November 2003 01:51 Go to previous message
Skip,
As the boys above said. Sounds like your Master Cylinder is stuffed as well.
I say buy a new one, less messy ! And they aren't that expensive if you buy non-genuine.
T.
Previous Topic:2TG overheating??
Next Topic:A few Celica questions
Current Time: Wed Nov 18 14:51:01 UTC 2026
Total time taken to generate the page: 0.0065169334411621 seconds
