Toymods » Tech & Conversions » 1J into RA28 - anaylisis
Lambolica
Northwestern Sydney
1J into RA28 - anaylisis Fri, 21 November 2003 02:25 Go to next message
Before you all jump down my throat I know the problems involved with putting one in and the weight problems over the front wheels.
What I want to do is find out if it would be possible to put one in and still retain a good weight balance.
To this end I need to find out the weights of various engines, the total mass of the car and the weight distribution of the car in standard form. This I haven't found any where.
Weight - 18R-C - 140kg
Weight - 18R-GEU - 130kg
Weight - 1G-GTE (gen 3) - 175kg
Weight - 1J-GTE - 217kg
Weight - Stock RA28 - 1100 kg
Weight Distribution - 620kg(F)-580kg(R)(1G-GTE)
Please note this is to confirm what people think on this forum and really is to satisfy myself, and is totally theoretical.
The end result is to find out how much heavyier the front end would be for various engines and their effects on weight distribution. I intend to post the results for future refrence.
[Updated on: Thu, 04 December 2003 03:00]
Corvid
Re: 1J into RA28 - anaylisis Fri, 21 November 2003 02:33 Go to previous messageGo to next message
Hey dude..
I allways thought that this setup would hammer as well..
The only but i can see is the lenth of the 1jz would put it over the front a bit..
BUT!!.. after messuring.. it aint all that much longer than a 1GGTE.. soo hmmmmmm...
Lambolica
Northwestern Sydney
Re: 1J into RA28 - anaylisis Fri, 21 November 2003 02:50 Go to previous messageGo to next message
Not much longer but it Is heavier.
One on my Aims is to see if it is realistic to pull the difference in weight out of the engine bay and get rid of or relocate it, And see how much front end is left.
Skip
Re: 1J into RA28 - anaylisis Fri, 21 November 2003 05:28 Go to previous messageGo to next message
Lextreme quotes the complete 1JZGTE weight as 217kg. Hope this helps.
Lambolica
Northwestern Sydney
Re: 1J into RA28 - anaylisis Fri, 21 November 2003 05:43 Go to previous messageGo to next message
Thanks Skip, I'll assume that isn't including gear box.
Anyone else?
Re: 1J into RA28 - anaylisis Fri, 21 November 2003 06:23 Go to previous messageGo to next message
Skip wrote on Fri, 21 November 2003 16:28
LOL, thats a third of the weight of my car!!!
as for stock front/rear wieght bias, best thing would be to take a stock car to a weigh bridge, put front wheels on, then put back wheels on...
Cyber-punk
Brisbane, QLD
Re: 1J into RA28 - anaylisis Fri, 21 November 2003 09:24 Go to previous messageGo to next message
i thought weight bridges could tell you the weight distrobution\load over each tyre etc?
Re: 1J into RA28 - anaylisis Fri, 21 November 2003 11:57 Go to previous messageGo to next message
well as for stock RA28 with 18R-GU weight goes.. i was just down at the Seven Hills waste disposal centre last week... and the celica weighed in at 1240kgs. That was with me and a mate wieghing 140kg together.
Have a look at how much further the 1JZ comes from the engine mounts compared to a 1G, that might give you and idea of distribution.
Lambolica
Northwestern Sydney
Re: 1J into RA28 - anaylisis Fri, 21 November 2003 13:00 Go to previous messageGo to next message
That's pretty much what I'm looking at doing.
I might try to get to a weighbridge tomorrow
Andy_H
Westleigh, Sydney
Re: 1J into RA28 - anaylisis Sat, 22 November 2003 00:11 Go to previous messageGo to next message
an 18rg weighs about 140kgs, so ive been told.
ChuckLandwehr
Re: 1J into RA28 - anaylisis Sat, 22 November 2003 10:39 Go to previous messageGo to next message
For what its worth, when I had my previous RA28 Celica engineered, the total weight of the 28 with a 1G-GTE and auto was 1200kg, distribution was 620kg front, and 580kg over the rear wheels. The 28 would have a higher rear end weight than a 23, by how much, not quite sure.
regards Chuck
Steve M
Re: 1J into RA28 - anaylisis Sat, 22 November 2003 14:46 Go to previous messageGo to next message
Our 18rc weighed 140kg with aircon pump.
Our 18rgu weighed 130kg without aircon pump.
From memory, the alloy head did reduce the weight from the 18rc to the 18rg, but only slightly.
Lambolica
Northwestern Sydney
Re: 1J into RA28 - anaylisis Sun, 23 November 2003 21:28 Go to previous messageGo to next message
ChuckLandwehr wrote on Sat, 22 November 2003 21:39
regards Chuck
Chuck
Was the car otherwise standard ie battery in the front standard interior appointments etc. What brakes did you have on the front?
(hilux,Pug conv?)
I just need the weight of the 1G-GTE. Smile
ChuckLandwehr
Re: 1J into RA28 - anaylisis Mon, 24 November 2003 11:57 Go to previous messageGo to next message
Lambolica, the brakes were the RA60 disc/MX63 Cressida combination. Battery was in the engine bay. Aircon was also fitted. The surge tank and HP fuel pump were also in the engine bay.(can't really have them in the back of a hatch) And some big ass rubber on 7 X 14 heavy as shit chrome steel rims, 215/225 60's from memory. The interior was daed stock factory original.
regards Chuck.
micooke
Re: 1J into RA28 - anaylisis Mon, 24 November 2003 14:50 Go to previous messageGo to next message
Lambolica wrote on Fri, 21 November 2003 23:30
Heres a list of celica weights (All in Kg) From a document i found on the web.
<1600 ST/LT> Gross weight Weight
B-TA35-LK 1,210 990
B-TA35-LM 1,210 990
<2000 ST/LT>
C-RA35-LK 1,255 1,035
C-RA35-LM 1,260 1,040
C-RA35-LH 1,260 1,040
<2000 DOHC/GT>
A-RA28-MQGU 1,305 1,085
<2000 DOHC/GTV>
A-RA28-MXGU 1,310 1,090
From factory specs, the 1JZ weighs 217Kg (Including turb's, no gearbox). Im not sure about the weight of the JZ gearbox though. If it helps i remember the RA28 gearbox weighs 40Kg, so the 20R engine weight is about 180Kg.
To better balance the celica, try lightening the load at the front by moving the battery to the boot, and by using aluminium brackets where/if possible. Either that or go the other way, and increase the load at the rear by e.g. installing a surge tank. This should allow the engine to drink a bit deeper as well as putting a higher load on the rear end.
Most 1JZ/RA28 conversions ive seen use a 94' hilux rear disk and LSD conversion. There is a paper on it somewhere on this site too.
A good site to look at is:
http://www.speedtoys.com/~marcel/
Hope this helps!
Regards, Cookie
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: 1J into RA28 - anaylisis Tue, 25 November 2003 07:07 Go to previous messageGo to next message
From figures that I got from one source:
1G-GTE: 175kg
1JZ-GTE: 200-205kg
Prolly weighed without accessories.
ChuckLandwehr
Re: 1J into RA28 - anaylisis Tue, 16 December 2003 10:25 Go to previous messageGo to next message
Hi guys, just to add some more figures to the thread, I just put my RA23 powered by 1JZ-GTE VVTi over the weighbridge, here are the numbers:
Front axle: 640kg
Rear axle: 500kg
Total Weight 1140kg
No weight redistribution has been carried out prior to this initial weigh.
60 kilos lighter than the RA28, and SH**# loads more power! Twisted Evil
Regards Chuck.
Classique71
Colac, Victoria
Re: 1J into RA28 - anaylisis Tue, 16 December 2003 11:12 Go to previous messageGo to next message
how do you find the front end handling chuck - pretty balanced out - or lead tipped arrow ?
this has been a question in the back of my mind for a while Smile
( still planning on getting a retro oldschooler happening after the gt4 is done - 1uz ra28/1ggte ra23/3sgte ta22 would be fun )
ChuckLandwehr
Re: 1J into RA28 - anaylisis Tue, 16 December 2003 11:31 Go to previous messageGo to next message
Hiya Stuart, yeah I thought it would be heavy in the front, but it is not too bad. She's no circuit racer ATM, but is Very respectable on the highway and around towm. Sensible settings for caster, camber, and toe, have all been worthwhile.
Lead tipped arrow, no way, it is more like a cruise missile on wheeels.
I got the car engineered today, and the only criticism was 100 decibels instead of the required 96. This was after doing brake endurance testing, and collision avoidence testing.
In the near future, I will be playing with spring rates, roll centre adjusters, and rebound and dampening settings.
regards Chuck.
Re: 1J into RA28 - anaylisis Tue, 16 December 2003 14:39 Go to previous messageGo to next message
ChuckLandwehr wrote on Tue, 16 December 2003 20:25
Total Weight 1140kg
Who told you an RA28 weighs 1200kg??
Lambolica
Northwestern Sydney
Re: 1J into RA28 - anaylisis Wed, 17 December 2003 03:15 Go to previous messageGo to next message
ChuckLandwehr wrote on Tue, 16 December 2003 21:25
Front axle: 640kg
Rear axle: 500kg
Total Weight 1140kg
Regards Chuck.
Have you doe any work to the firewall or is the engine proud of the wall? If in the firewall by how far?
alwaysRA23
Re: 1J into RA28 - anaylisis Wed, 17 December 2003 23:44 Go to previous messageGo to next message
having seen this car in the building stages, and now seeing it finnished,
the engine bay is pretty full as you can imagine. but i dont believe that any firewall "improvements" were made.
just new crossmember mounts,
not 100percent but yeah.
this one is definatly going to be a head turner at the Toyota Nationals if it makes an apearance. Very Happy
which i dare say it will.
Lambolica
Northwestern Sydney
Re: 1J into RA28 - anaylisis Thu, 18 December 2003 00:03 Go to previous messageGo to next message
I'd like to see photos of the install for intrest sake. Smile
Jason
Re: 1J into RA28 - anaylisis Thu, 18 December 2003 00:42 Go to previous messageGo to next message
I agree with always23 it is a very nice install and gets the thumbs up Cool
ChuckLandwehr
Re: 1J into RA28 - anaylisis Fri, 19 December 2003 05:52 Go to previous message
Norbie: "60 Kilos lighter than the 28" 1200kg with 1G-GTE Auto. Maybe that should have read MY 28
Lambolica: No mods to firewall, actually had room to move the radiator "back" 10mm.
I will upload all the pics. when I can find somwhere to host them.
Jason and Phil, ta.
regards Chuck
Previous Topic:good price????
Next Topic:18R-G Fuel Injection Please
Current Time: Thu Nov 19 07:31:14 UTC 2026
Total time taken to generate the page: 0.010667085647583 seconds
