Toymods » Tech & Conversions » Sera (Paseo?) Automatic to Manual Transmission Conversion
gt20v
Sera (Paseo?) Automatic to Manual Transmission Conversion Fri, 21 November 2003 03:10 Go to next message
anyone have any info? Is it do-able?
Cressida Supra
Re: Sera (Paseo?) Automatic to Manual Transmission Conversion Fri, 21 November 2003 03:32 Go to previous messageGo to next message
What model is the car?
What motor/gbox combo does it have?
This way people can tell you whether you can use the gbox and pedals from a similar Toyota.
gt20v
Re: Sera (Paseo?) Automatic to Manual Transmission Conversion Fri, 21 November 2003 03:41 Go to previous messageGo to next message
Sera is the gullwing car I'm sure those that knows should know, and it probably uses the same drivetrain as EP82/92? And same drivetrain as the Paseo, but I can't any info on the net, I'm sure someone here should know
Cressida Supra
Re: Sera (Paseo?) Automatic to Manual Transmission Conversion Fri, 21 November 2003 03:48 Go to previous messageGo to next message
Next time can get to the car, pop the bonnet and write down what is written on the Identification Plate
Mainly, body code, engine code, transaxel/diff codes
But it sounds like you run a 4E-FE or 5E-FE motor
I *think* this is the same as a Starlet, so you should be able to use a manual transmission from one of those. Pedals however, could be a different question
gt20v
Re: Sera (Paseo?) Automatic to Manual Transmission Conversion Fri, 21 November 2003 05:55 Go to previous message
basically what is needed is the gearbox, master + slave clutch cylinder, pedal box, bolt to the firewall etc, same for any car, the engine is 5e-fhe, in my mind, I'm thinking a front cut of a turbo starlet including the gearbox, straight in, but I want to know if anyone's done it, I have an idea what needs to be done, but again, I want to know if anyone's done it, so I know how much it can cost...
Previous Topic:Bosch or Magnecor Ignition Leads?
Next Topic:fuel- carb problem
Current Time: Wed Nov 18 17:13:01 UTC 2026
Total time taken to generate the page: 0.0090169906616211 seconds
