Toymods » Tech & Conversions » O-ringed Blocked Assembly (7MGTE)
celicaboy_2000
Lismore, NSW
O-ringed Blocked Assembly (7MGTE) Fri, 21 November 2003 08:07 Go to next message
Hey Guys I will be bolting up my head tomorrow but im having a hassle keeping the wire in the oringed groove's in the block? What can I do to make sure the wire wont move when placing the head gasket on the block. Ill be torquing the ARP headstud kit up to 75lbs is that ok? Cheers.
ed_ma61
Lost in the K hole
Re: O-ringed Blocked Assembly (7MGTE) Fri, 21 November 2003 11:59 Go to previous messageGo to next message
use 'hylomar' spray (and only the spray) from acl.
use it on the wire before seting them in the grooves, then do both sides of the gasket evenly (and not thick!) on both sides...
celicaboy_2000
Lismore, NSW
Re: O-ringed Blocked Assembly (7MGTE) Sat, 22 November 2003 03:42 Go to previous messageGo to next message
ed, why only the spray? I brought the ACL brush on stuff already, would that be ok if I brush a lite coat on the O-rings before I put them into the block?
Allan
Re: O-ringed Blocked Assembly (7MGTE) Sat, 22 November 2003 04:45 Go to previous messageGo to next message
put it in a spray gun and use it!
Brush stuff gos on shitfull and too thick
Allan
ed_ma61
Lost in the K hole
Re: O-ringed Blocked Assembly (7MGTE) Sat, 22 November 2003 07:09 Go to previous messageGo to next message
Allan wrote on Sat, 22 November 2003 15:45
what he said Laughing
but seeing as youve already got the little bottle, you could get away with brushing it on the orings...
but i would definitely only use the spray for the hg itself
ed
celicaboy_2000
Lismore, NSW
Re: O-ringed Blocked Assembly (7MGTE) Sun, 23 November 2003 08:56 Go to previous messageGo to next message
Thanks guys, I also brought a deep 14mm socket so I can do the nuts up but dam the head is still in the way so ill be machining the socket down a little to fit (thats my plan anyway). I might just take the brush on stuff back and buy the spray. Once again cheers. Very Happy
bbaacchhyy
Re: O-ringed Blocked Assembly (7MGTE) Sun, 23 November 2003 21:00 Go to previous messageGo to next message
From the ARP stud kit I got on Friday, it quoted 80 ftlbs for when you use their special lube, or 130ftlbs when you use 30 wt motor oil.
Michael B
Allan
Re: O-ringed Blocked Assembly (7MGTE) Mon, 24 November 2003 03:39 Go to previous messageGo to next message
bbaacchhyy wrote on Mon, 24 November 2003 08:00
Michael B
ed_ma61 wrote on Thu, 30 October 2003 23:33 in threed Re: ARP Headbolts/Studs - experiences/prices ?
Allan wrote on Thu, 30 October 2003 23:12
engine oil as lube so 120ft/lbs
Allan, wtf are you doing??!!??
Stenno wrote on Fri, 31 October 2003 21:08 in threed Re: ARP Headbolts/Studs - experiences/prices ?
120ft/lbs! crazy
Ahem??? do I hear a "Sorry I WAS WRONG" ???? Very Happy Laughing
[Updated on: Mon, 24 November 2003 03:40]
Allan
Re: O-ringed Blocked Assembly (7MGTE) Mon, 24 November 2003 03:43 Go to previous messageGo to next message
celicaboy_2000 wrote on Sun, 23 November 2003 19:56
get the kingchrome 3/8 drive tube socket it fits perfectly
Allan
bbaacchhyy
Re: O-ringed Blocked Assembly (7MGTE) Mon, 24 November 2003 03:45 Go to previous messageGo to next message
Hey Allan,
Nice feeling , eh ? Laughing
When do I get my $50 for that Very Happy
Michael B
Edited to make the message clearer Wink
[Updated on: Mon, 24 November 2003 04:45]
ed_ma61
Lost in the K hole
Re: O-ringed Blocked Assembly (7MGTE) Mon, 24 November 2003 04:10 Go to previous messageGo to next message
hmmm....
ed_ma61
Lost in the K hole
Re: O-ringed Blocked Assembly (7MGTE) Mon, 24 November 2003 04:20 Go to previous messageGo to next message
reading this:
http://www.arp-bolts.com/media/pdf_files/arp_cat03 .pdf
id be tempted to say that 130ft/lbs with engine oil (assuming 80ft/lbs with ARP lube) is incorrect. you say its in the ARP sheet you got, but thats in conflict with the tech data on that pdf.
id be suggesting if it were 80ft/lbs with ARP lube, youd be looking at a max of say 100-105ft/lbs with 30wt engine oil
edit: my suggested ~20% increse over arp lube torque is in line with all other specifications ive ever read for arp products. the 60-65% increase for engine oil use (that you quote, and allan used) seems incredibly high, and inconsistent.
my 2c
[Updated on: Mon, 24 November 2003 04:24]
bbaacchhyy
Re: O-ringed Blocked Assembly (7MGTE) Mon, 24 November 2003 04:47 Go to previous messageGo to next message
Hi Ed,
I'm just quoting the piece of paper that was included with the studs. Very Happy
I'll be using the lube and 80ftlbs, but I guess the other option is when you either run out or lose it ? Confused
Michael B
ed_ma61
Lost in the K hole
Re: O-ringed Blocked Assembly (7MGTE) Mon, 24 November 2003 04:55 Go to previous messageGo to next message
bbaacchhyy wrote on Mon, 24 November 2003 15:47
just use any moly/graphite assembly lube Nod
Allan
Re: O-ringed Blocked Assembly (7MGTE) Mon, 24 November 2003 04:57 Go to previous messageGo to next message
Cool *points to bbaacchhyy* argue with him he said 130ft/lbs Laughing
celicaboy_2000
Lismore, NSW
Re: O-ringed Blocked Assembly (7MGTE) Wed, 10 December 2003 10:18 Go to previous messageGo to next message
I used the hylomar spray on the rings but wasn't happy with the way they sat in the block so I ended up placing 4 small spots of superglue in the groove and placing the oring ontop and holding them in till the superglued dried... Worked like a dream it was simple. I ended up torquing my studs upto 75lbs I think that'll be enough. Thanks for the help anyway guys much appreciated. Very Happy
Allan
Re: O-ringed Blocked Assembly (7MGTE) Wed, 10 December 2003 11:58 Go to previous messageGo to next message
75ft/lbs hmmm dont blame the 7m-gte if the gasket dies
Allan
celicaboy_2000
Lismore, NSW
Re: O-ringed Blocked Assembly (7MGTE) Thu, 11 December 2003 09:50 Go to previous messageGo to next message
Allan, so you would suggest a bit tighter then 75lbs how bout 85lbs? Got the cams in but it's only a 10min job to remove and replace them. Let us know what u think.
Allan
Re: O-ringed Blocked Assembly (7MGTE) Thu, 11 December 2003 11:57 Go to previous message
DEFINTLY the torque specifiyed by ARP
Previous Topic:Can Head Bolts Be Reused?
Next Topic:oil pressure gauge
Current Time: Mon Oct 26 04:56:46 UTC 2026
Total time taken to generate the page: 0.0054888725280762 seconds
