Toymods » Tech & Conversions » 22RE
Corona RT142
Campbelltown
22RE Fri, 21 November 2003 10:01 Go to next message
Approximately how much would it cost to get sports springs and shocks for a 85 Corona. Also how much would it cost to recondition a 22re.
I was also looking at getting new front discs and moving the standard front discs to the back to replace the drums is there any cheap way to do this. The car has an LSD and is a CSI.
Re: 22RE Sun, 23 November 2003 03:56 Go to previous messageGo to next message
I just bought KYB shocks and Kings springs for my 84 Supra, and they cost $400 and $360 respectively. I expect it would be similar for a Corona.
As for reconditioning the 22R, it will cost way more than it's worth. You're better off sourcing a good secondhand engine if yours is stuffed.
A brake upgrade on the front is piss-easy; the ventilated rotors and larger calipers from an RA60/65 Celica will bolt right on. I doubt there's an easy way to put discs on the back, but it's not worth the bother anyway - just worry about the fronts as they do most of the work.
Re: 22RE Sun, 23 November 2003 03:58 Go to previous messageGo to next message
auto-one at north parra will set you up with the springs and shocks cheaply
sa65
Surrey Hills, Melbourne
Re: 22RE Sun, 23 November 2003 08:18 Go to previous messageGo to next message
Interesting things coronas,
So many different bloody variations. I just bought a RT142 Corona, which has discs on the front and drums on the back. It also has a solid rear axle. It too is a CSi. Interestingly enough, from what I have seen, Corona Avante's typically have discs on the back, and engines vary between the 2S-C and the bigger 22RE. Most of the Avantes have the solid axle Borg Warner diff, but there is a rarer IRS version of the Avante (much later models I think, it too had LSD I think). You sure yours has an LSD?
If you wanted discs on the back, you could go to the wreckers and take out the whole rear end of an Avante. It would probably be solid axle but the difference between it and IRS depends on what kind of driving your doing, it should be fine. It can also be cheaply had...for example, I scored a shitload of bits for $350:
Bonnet - no dings or scratches or rust
Entire Rear end complete from Avante
22RE minus head, though the block and pistons have been weather exposed, I'm after the crankshaft in particular...
5 celica style mags...
Fuel tank & Muffler
W57 Gearbox
Entire Velour interior for Corona Avante (yup, I stripped it bare)
2x Tilt steering columns
Not sure if my wrecker are nice or just plain dumb...the gearbox can be sold if needed...
Getting back to the post, brakes are easily upgraded...celica discs should fit the front as said above, haven't tried it but I can't imagine why not...
And as for the engine, unless you can rebuild it yourself profficiently, as the guys have already said, you may be much better off getting a S/H engine...make sure you get it checked out by someone who knows though...
I dont know of cost for springs and shockers but when I changed the springs and shockers on my celica (Kings and Monroe GT's), I was roughly up for the same sort of money Norbie quoted. If celica and supra are pretty close, the corona shouldn't be any more expensive than that...
Sorry bout the huge post...I get carried away Very Happy ...
Ben
sa65
Re: 22RE Sun, 23 November 2003 08:19 Go to previous messageGo to next message
Sheet, there's my $5.00 worth Shocked
Asher
Northgate, QLD
Re: 22RE Mon, 24 November 2003 00:38 Go to previous messageGo to next message
bloody coronas,
yer I've got a RT142 22R-E 12/'85 CSi (Not Avante) with IRS and discs all round.
I had to replace my diff with one from a RA65 celica, corona one gave way after I changed into 2nd, wasn't going hard at all. Geez that celica one can take a beating, gotten the rear wheels to step out in 2nd gear 3 times now (75% tread). ok enough chit chat.
Hmm might have to look into upgrading front brakes with RA65 discs.
Still considering a engine conversion to a SR20 (NON TURBO), yes i'm not going for performance, just something a bit more newer.
Hey does anyone know what the new 2.4l Rav4 has in it? (new model 22r-e? Razz )
[Updated on: Mon, 24 November 2003 00:42]
Astroboy007
Re: 22RE Mon, 24 November 2003 01:35 Go to previous messageGo to next message
no the new 2.4litres have variably valve timing cant remember the code but they arnt 22re !..i wish
Asher
Northgate, QLD
Re: 22RE Mon, 24 November 2003 02:04 Go to previous messageGo to next message
Ok managed to find the model number for the 2.4l Rav4,
2AZ-FE, 2AZ-FSE
16v, twin-cam, VVTi
not sure what the S is.
About 160hp.
[Updated on: Mon, 24 November 2003 02:06]
Re: 22RE Mon, 24 November 2003 02:57 Go to previous messageGo to next message
I think the S is for direct injection, but don't quote me on that.
And yes, the new RAV4 engine doesn't resemble the 22R-E in any way. The R series engines date back to the 60's, so their day has decidedly come and gone. Smile
Allan
Re: 22RE Mon, 24 November 2003 03:27 Go to previous messageGo to next message
2RZ from hi-ace's would probably be a good swap tuff engine 127,000 rental km in hi-aces and still going strong!
Allan
Astroboy007
Re: 22RE Mon, 24 November 2003 05:56 Go to previous messageGo to next message
3rz-fe is even better out of the hilux 2.7litre comes out with w56 box's
Corona RT142
Campbelltown
Re: 22RE Tue, 25 November 2003 04:58 Go to previous messageGo to next message
How much would it cost to get an engine that puts out around 120kw. I am on a small budget as I only work casually. The reason I want discs on the rear is because the drums are stuffed and the handbrake doesn't work too well.
The car seems fine in the way of power and the engine is in decent condition, but it blows smoke when taken above 3 thousand rpm sometimes.
The lowdown torque is great for annoying unassuming drivers like the Pulsar SSS the other night. I caned him off at the lights and he wasn't too happy. I slowed back down and he went flying past too embarrassed to be beaten by an 18 Corona. Is there any power difference between 22re built before 1985 and after. As it requests 98 ron fuel yet was then able to take 91 with unleaded. Does this mean that my engine would be more powerful?
Asher
Northgate, QLD
Re: 22RE Tue, 25 November 2003 09:54 Go to previous messageGo to next message
Put me down for one of those engine conversions aswell.
From what I've picked up, you wont get any performance gain from using PULP, and if you do use it you'll have to get your car retuned to use it. so might as well just use ULP.
chubbylover53
icon5.gif  Re: 22RE Sun, 29 February 2004 09:01 Go to previous messageGo to next message
I was also wondering about the 2.7L hilux engine. would it just bolt into an 1986 corona, i am really having a hard time trying to find an engine that is not turbo for my corona, the torque put out by the 3RZFE would be wicked + LC engineering make some great stuff for it.... any thoughts
[Updated on: Tue, 02 March 2004 07:58]
wil8115
Seattle area, USA
Re: 22RE Fri, 05 March 2004 12:38 Go to previous message
900+ hp from a 3RZ enough to grab ya?
well guys are getting that here states side.
600+ from 2RZ's.
look for "Christian Rado" i think he drives one.
http://www.nhraimport.com/2003/drivers/C_Rado.html
was running very low 8's in the 1/4 mile last i heard
yup found this.
The NORAD Celica will use the same Toyota 3RZ 2.7-liter engine used in Rado's current race car but Norwood is making several changes to squeeze more useable power out of the unit.
"I have re-worked the cylinder heads to optimize the flow capabilities," explained Norwood. "The intake and exhaust ports have been raised and we have spent a lot of time on the flow bench getting the heads where we want them. We are currently working on cam profiles and so far we have managed to make improvements that should yield a lot of useable power.
"We have also re-worked the crankshaft and block to take us as close to the three-liter limit as we can go, I'm an old timer and a believer in the old saying "There ain't no substitute for cubic inches".
"Christian's current engine combination makes well over 900 horsepower to the wheels. I am on target to make at least 250 more with a much wider power-band."
Much R&D time has also been dedicated to the chassis design of the new Celica. The design features the same 'Four-link' style front suspension as the current car but a completely different approach has been pioneered by Norwood's team. The front of the chassis is much narrower and the steering centers are placed on the centerline of the tires.
[Updated on: Fri, 05 March 2004 12:41]
Previous Topic:T50 Gearbox Q.
Next Topic:Help me understand optimum stroke location
Current Time: Sun Oct 25 00:20:20 UTC 2026
Total time taken to generate the page: 0.060328006744385 seconds
