Toymods » Tech & Conversions » URGENT !!!!! Spray painting ~~ HELP !
86racer
URGENT !!!!! Spray painting ~~ HELP ! Sat, 22 November 2003 04:41 Go to next message
Hi ! I'm having some problem with spray-painting my car.
Paint splatters as it comes out of spray gun.. I thought the paint was too thick, so I put some more thinners but still splatters it. Someone told something might have been blocked in the spray gun, so I pulled it apart and cleaned the nozzel.
BUT still does it.. I don't know What I'm doing wrong ...
It worked fine a couple of days ago...
Can anyone provide me some solution to this problem ?
by the way, I was painting in rainy day..(but I was painting in garage, so would this be a problem ?)
HELP !!! HELP !! HELP !!!!
twincam_ke20
Castlemaine Vic
Re: URGENT !!!!! Spray painting ~~ HELP ! Sat, 22 November 2003 05:36 Go to previous messageGo to next message
what pressure you running it at? try turning that up a tad.
also have you got a water separator on the air line somewhere? maybe theres water condentation in the compressor tank
86racer
Re: URGENT !!!!! Spray painting ~~ HELP ! Sat, 22 November 2003 05:43 Go to previous messageGo to next message
I'm running at 40 psi, and I've also got water separator near regulator, but what do i do if there is water in the tank (How do I drain the water out of the tank ?)
ChaserJZX100
melbourne
      wtf is a jabber handle
Re: URGENT !!!!! Spray painting ~~ HELP ! Sat, 22 November 2003 05:54 Go to previous messageGo to next message
well i dunno if this really helps but at work our air compressor tank has a valve on the end and also the very end is able to come off with alot of effort, or get a heavy duty vaccum drill two holes in the tank and suck the water out then patch the holes up , thats just an idea Very Happy
Grega
melbourne.victoria.austra...
Re: URGENT !!!!! Spray painting ~~ HELP ! Sat, 22 November 2003 06:43 Go to previous messageGo to next message
drain compressor for sure.
there should be a valve on the bottom/drain cock to empty the tank
i'd fill your gun with thinners, and, run it for a while just spraying thinner - i normally do this b4 i spray.
make sure you strain the paint b4 you put it in the pot too - very important!
painting on a rainy day, hmmm, can't say as i'd recommend it, depends too how humid it is also.
86racer
Re: URGENT !!!!! Spray painting ~~ HELP ! Sat, 22 November 2003 21:08 Go to previous messageGo to next message
Thanks guys !!
I have drained the tank..hopefully this will fix it ..
Grega
How do you strain the paint b4 you put into the pot ?
Re: URGENT !!!!! Spray painting ~~ HELP ! Sat, 22 November 2003 21:59 Go to previous messageGo to next message
ditto hat grega said - ideally you want a nice warm summer day with about 0% humidity
twincam_ke20
Castlemaine Vic
Re: URGENT !!!!! Spray painting ~~ HELP ! Sat, 22 November 2003 22:11 Go to previous messageGo to next message
use one of ya mums stockings to strain the paint, or go buy some paper cone filters, there like 50c each, can either get fine, medium and i think theres others too..
but like the others say, usually when it rains (down here in vic anyway Razz) its cold, so if it feels like below 12-10dec dont paint.
also when you have finished with the gun for the day, clean it out as you would, then leave some thinners in it, like not full just a bit in the bottom till next time you are ready to use it.
also, when u say it splatters, is it like little bits of shit that comes out or is it actually just paint spots?
86racer
Re: URGENT !!!!! Spray painting ~~ HELP ! Sat, 22 November 2003 22:43 Go to previous messageGo to next message
Thanks guys !!!
twincam_ke20
it comes out as actually just paint spots
Grega
Re: URGENT !!!!! Spray painting ~~ HELP ! Sun, 23 November 2003 00:48 Go to previous messageGo to next message
yup - panty hose. worx great.
it sounds like your gun is blocked - time for a pull down and clean.
what sort of thinner are you using out of interest? i use motospray and its fine - i had a tin of other stuff and that was fucking hopeless - and caused the paint to clump and turn to shit!
86racer
Re: URGENT !!!!! Spray painting ~~ HELP ! Sun, 23 November 2003 01:25 Go to previous messageGo to next message
I'm using the PPG thinners...not sure if it is a genuine PPG thinners as I bought from the paint shop.. I will try it with motospray thinners.
It was heartbreaking after days of preparation, so I will try anything to solve this problem
twincam_ke20
Castlemaine Vic
Re: URGENT !!!!! Spray painting ~~ HELP ! Sun, 23 November 2003 11:23 Go to previous messageGo to next message
yeh it sounds like you have a bloke if its paint splatters, in the air cavaties in the cap you screw off, with the hole (sometimes 2) on each side, check them!
[Updated on: Sun, 23 November 2003 11:24]
86racer
Re: URGENT !!!!! Spray painting ~~ HELP ! Sun, 23 November 2003 23:37 Go to previous messageGo to next message
Thanks Guys !!!
I have done every thing that you guys have mentioned in replys, so I'll let you know how it went
jaydik
Re: URGENT !!!!! Spray painting ~~ HELP ! Mon, 24 November 2003 02:08 Go to previous messageGo to next message
have you tried to strain the paint eith a stocking?
ChuckLandwehr
Re: URGENT !!!!! Spray painting ~~ HELP ! Mon, 24 November 2003 11:48 Go to previous messageGo to next message
If you are using PPG paint use the PPG thinners. Motorspray thinners is great with Motorspray paint, but CR#p with most high quality paints. DON"T mix brands, that will lead to all kinds of grief. Strain the paint as it goes into the pot. If you have a gravity feed gun, you can install a filter into the gun. If she is a suction feed gun, the biggest problem, is the air vent arrangement at the top of the pot, that has to be totally clean. Some painters use a long length of vacuum hose straight off the nipple on the top of the pot. Strip clean your gun after each layer of paint ie. after primer, after colour and after clearcoat. After cleaning put 50cc of thinners in the pot, and while spraying, hold a cloth over the various holes in the spray cap. You will know its clean when you get a really nice even pattern of spray, this is also a good time to adjust the fan pattern, saves wasting good paint later on.
And don't spray on humid days, you will end up with a blotchy paint job, with areas of dull and glossy paint!
regards Chuck.
gt20v
Re: URGENT !!!!! Spray painting ~~ HELP ! Mon, 24 November 2003 16:43 Go to previous messageGo to next message
re: chuck: you can't adjust the spray pattern with thinner in the bottle.. Razz it's too thin compared to the paint Razz
I think 86racer should tell us, what is the spray pattern of the gun when he's spraying thinner, is it a nice uniformed
shape? or more like a
_
shape?
that will tell if there's junk in the bottle, or if the holes are blocked.
but if it was working a few days before, either you broke something while pulling it apart (or you left something out?), or you didn't clean your gun right after you use and something is blocking it.. but pull it apart, use thinner to wipe the needle, and as someone said, put thinner in there and spray until whatever comes out is clear coloured, good luck
ChuckLandwehr
Re: URGENT !!!!! Spray painting ~~ HELP ! Tue, 25 November 2003 10:55 Go to previous messageGo to next message
gt20v ,please re read my reply, I said "adjust fan pattern". I suppose it really depends on what sort of gun you have!
86racer
Re: URGENT !!!!! Spray painting ~~ HELP ! Wed, 26 November 2003 09:54 Go to previous messageGo to next message
Problem fixed !!!
Thanks guys for your advice !!
got one more question, if the paint looks dull and rough, can cut and polishing fix it up or Do I have to rub it back re-apply the top-coat ???
gt20v
Re: URGENT !!!!! Spray painting ~~ HELP ! Wed, 26 November 2003 11:30 Go to previous messageGo to next message
so what was the problem?
well, if it's just a small part, make sure you have enough coats and cut it back (if it's solid colour), otherwise smooth sand it and apply another good coat...
86racer
Re: URGENT !!!!! Spray painting ~~ HELP ! Thu, 27 November 2003 09:07 Go to previous messageGo to next message
I didn't clean the gun properly Laughing that was my problem
I thought it was clean but especially the nozzle was dirty, had bit of paint build up as well
Any first time spray painters out there like me
CLEAN YOUR GUNS !!!
ChuckLandwehr
Re: URGENT !!!!! Spray painting ~~ HELP ! Thu, 27 November 2003 11:43 Go to previous messageGo to next message
Acrylic paint will not give a brilliant gloss "off the gun". You can help to promote gloss by adding 2 Pack reducer to the clear coat, instead of normal thinner. Thinners vary in grade "slow,medium, and fast". Most suppliers will supply the novice with meduim thinners, it flashes off faily quickly, and is not as prone to runs as the slow thinners. Flashing off refers to the thinners evaporating from the paint. If you have a nice uniform coat of colour on the car and it looks a little dull, thats just the way it works. Like I said 2 Pack reducer in the topcoat clear will bring up a fairly nice level of gloss. You will still need to compound and buff the car to get a really nice gloss.
regards Chuck.
Grega
Re: URGENT !!!!! Spray painting ~~ HELP ! Thu, 27 November 2003 19:46 Go to previous messageGo to next message
chuck is spot on here. acrylic does come outta the gun pretty dull, (especially flat colors - metallics come out with a bit more body, but still not an intense gloss like 2pack)
it seems that using the same brand of thinner with the same brand of paint is a good idea.
i use super cheap thinner to clean my equipment with, and, motospray (which is supposedly shit but i've had good success with so far, even for a beginner) thinner with the motospray paint i had color matched. like i say so far so good.
chuck i've also heard of spraying thinner (lightly) onto wet clear to also help promote a higher gloss. havent' tried it.
ps: never heard of 2 pack reducer in the clear though. will give it a try instead of normal thinner.
RA23GT
icon5.gif  Re: URGENT !!!!! Spray painting ~~ HELP ! Fri, 28 November 2003 03:03 Go to previous messageGo to next message
I'm a novice spraypainter(by novice I mean will buy a compressor in the next few weeks)myself and have been trying to find some web links on spraypainting but have had no luck. Any ideas??
Ta
Kev
86racer
Re: URGENT !!!!! Spray painting ~~ HELP ! Fri, 28 November 2003 05:49 Go to previous message
Kev
I've found this article very useful !!!
http://www.lrcars.fsnet.co.uk/downloads/carsprays. pdf
Previous Topic:1G Injector firing sequence
Next Topic:Ignition Probs?
Current Time: Sat Oct 17 13:34:15 UTC 2026
Total time taken to generate the page: 0.0062649250030518 seconds
