Toymods » Tech & Conversions » TA22 in-tank fuel pump???
freakincage_com
north brisbane
TA22 in-tank fuel pump??? Sat, 22 November 2003 06:42 Go to next message
hey does anyone know if the TA 22'z come with a fuel pump in the fuel tank??? because mine only has one just befor the twin carbs......???and can u put a intank fuel pump??? because my car is slugish wen i put my foot flat and apparently itz because i aint gettin enough fuel...?
Re: TA22 in-tank fuel pump??? Sat, 22 November 2003 07:37 Go to previous message
you would have to adapt an EFI in-tank pump if that's what you want - and there was no TA22 with EFI
... but any EFI pump will be way too high pressure for your carbs.
if you want an electric pump, get a high volume, low pressure pump - they usually mounts (relative to the tank but not inside it) below, or near, the bottom of the tank.
something like the electric unit at bottom of my 'for sale' page:
<http://members.optushome.com.au/mkhala/red_celica/ stuff_for_sale.html>
is what you're after - there's also carter and holley pumps that do the same thing.
but i think your sluggish behaviour will be from something like:
float levels wrong
dirt in carb
accel pumps stuffed
ignition timing/dwell not right
fuel pump stuffed
fuel line to pump from tank crushed
fuel return line (from pump to tank) blocked
charles.
Previous Topic:Does 4AG means 4AGE ?
Next Topic:Where to find a 7MGTE head gasket
Current Time: Sat Nov 21 09:11:00 UTC 2026
Total time taken to generate the page: 0.008875846862793 seconds
