Toymods » Tech & Conversions » sticky ae86 throttle
shindeokure
melbourne
sticky ae86 throttle Sat, 22 November 2003 09:01 Go to next message
i've been problems with my ke30 throttle cable on my ae86. sometimes it keeps accelerating when i let go of the pedal, and it revs out to 7-8000rpm for 2-3sec if i shift it to neutral to stop it moving. the cable or throttle itself doesn't seem to have much friction and slides freely.
does anyone know what the problem could be?
ae86trueno
Re: sticky ae86 throttle Sat, 22 November 2003 10:59 Go to previous messageGo to next message
Just check that both of the throttle springs are auctually in place.
Ben
AE86 Trueno 4AGE
IRA11Y
Club Member
Re: sticky ae86 throttle Sat, 22 November 2003 21:31 Go to previous messageGo to next message
also take the cable out of the car and make it nice and straight, run the wire inside back and forth to make sure its not catching on any kinks in the shield, throw some moly grese on the wire and that will help if its not sliding smoothly and there are no kinks.
FKN16V
NSW, East Coast
Re: sticky ae86 throttle Sun, 23 November 2003 05:02 Go to previous messageGo to next message
I believe removing the throttle cable and pouring kerosene down the cable is also a good idea, kerosene has a small amount of oil in it wich will help if it's sticking. Use to work great on my bmx brake cables when i was a young chap.
But first id clean the throttle bodie inside and out with carby cleaner to remove any yucky stuff that might be hidden in there.
Just my 2c worth
Hope it all works out for you.
shindeokure
melbourne
Re: sticky ae86 throttle Sun, 23 November 2003 09:28 Go to previous message
thanks, the throttle spring was not on as the mounting position has snapped off. are there any shorter cables that will fit the ae86?
[Updated on: Sun, 23 November 2003 09:28]
Previous Topic:headlights suitable for lowrise conversion
Next Topic:20V into KE30
Current Time: Sun Sep 20 18:16:32 UTC 2026
Total time taken to generate the page: 0.039128065109253 seconds
