Toymods » Tech & Conversions » Hi-tension wire "wire"
V8_MA61
Hi-tension wire "wire" Sun, 23 November 2003 13:09 Go to next message
Does anyone know the best hi-tension wire you can buy? You can buy it in lengths to make your own leads. Im looking for 9mm+ diameter. Any idea on price/brand and where i can buy it? Because my engine is unique, i cant use stock length aftermarket or ford leads to my knowledge.
Thanks - blake!
[Updated on: Sun, 23 November 2003 13:10]
ed_ma61
Lost in the K hole
Re: Hi-tension wire "wire" Sun, 23 November 2003 13:38 Go to previous messageGo to next message
call the guys at rocket industries (they do msd - should be able to buy it off the roll)
youre after 8.5mm 'super conductor' wires
www.rocketindustries.com.au
Re: Hi-tension wire "wire" Sun, 23 November 2003 14:00 Go to previous messageGo to next message
There is a place here locally that can do you custom leads and or will just supply the cable to do it your self.
I have the details here somewhere but I cant be bothered looking from them at the moment Yawn
CLG
Perth, Western Australia
Re: Hi-tension wire "wire" Sun, 23 November 2003 15:07 Go to previous messageGo to next message
Custom length leads are not hard to make, simply order a kit in through your local parts store - if they looK at you blankly after you explain the need for such a kit, go elsewhere (cos at the end of the day, your money is paying their wage!).
Having said that, I'd propose a Cleveland set of leads will suffice as the dizzy is in the same position, and the Boss manifold size is not that dissimilar to the Cleveland.
I've put those leads aside we spoke about last week, was going to suggest posting them with the grinder? Let me know if you still want them?
Re: Hi-tension wire "wire" Sun, 23 November 2003 22:34 Go to previous messageGo to next message
I would have thought you'd be able to grab a set off the shelf to suit, but just head along to any performance ignition style place (I know of several in melbourne, your part of the world should be no different) and they can piece them together while you watch. May as well go the 10mm wire, with the fibreglass matting on the outside, big arse metal caps over the plugs etc. - even if it does squat all for the engine, it still looks big, meaty and tough Evil or Very Mad
Re: Hi-tension wire "wire" Mon, 24 November 2003 08:30 Go to previous messageGo to next message
Queensland Ignition Leads
Manufacturers of Quality High Performance Ignition Leads
1560 Anzac Avenue
Kallangur QLD 4503
PH 07 38865700
V8_MA61
Re: Hi-tension wire "wire" Mon, 24 November 2003 09:26 Go to previous messageGo to next message
thanks for the quick replies guys. Yep mrshin i think ill go for 10mm, a fellow at my work has a 351 with 9mm he made for himself, so i though i may as well go one bigger Smile
V8supra
cobden /vicoria
Re: Hi-tension wire "wire" Mon, 24 November 2003 10:00 Go to previous messageGo to next message
You can buy what you need off the shelf!.....too easy
V8_MA61
Re: Hi-tension wire "wire" Mon, 24 November 2003 10:02 Go to previous messageGo to next message
what v8 do you have in your supra oiut of curiousity?
Re: Hi-tension wire "wire" Mon, 24 November 2003 11:14 Go to previous messageGo to next message
The 10mm is a bit like using a furnace to cook lunch, but hell, it looks good - now you can claim that not only does your supra have the biggest engine, but the fattest leads too... (never mind that JZ powered supra's don't actually HAVE leads!)
V8_MA61
Re: Hi-tension wire "wire" Mon, 24 November 2003 11:23 Go to previous message
mines only 4.9L man!
Previous Topic:where to find 1971 ta22 fuel cap
Next Topic:1JZ igntion module connectors
Current Time: Sat Nov 21 08:47:34 UTC 2026
Total time taken to generate the page: 0.013015985488892 seconds
