Toymods » Tech & Conversions » ST162 A/C button flashes.. ?
Jaxe
icon5.gif  ST162 A/C button flashes.. ? Sun, 23 November 2003 23:46 Go to next message
Hey guys,
This isn't super urgent, but I was just browsing and thought I'd ask the question while it was in my head..
My ST162 ('89 Celica SX) has 2 buttons to turn the A/C on -> A/C and Econ.
Whenever I turn either one on it goes for a few seconds then the light starts flashing. Also, the air doesn't go cold.
I'm not sure what this means? Can anyone help?
Chris
[Updated on: Sun, 23 November 2003 23:47]
RobST162
Re: ST162 A/C button flashes.. ? Sun, 23 November 2003 23:48 Go to previous messageGo to next message
hey my mates rolla started doing this when they system was low on gas. It would turn on for a bit (few seconds) and then start flashing, but my 162 has no gas, and the light turns on fine... Confused
wiso
Re: ST162 A/C button flashes.. ? Mon, 24 November 2003 00:55 Go to previous messageGo to next message
Yeah the one on mine used to do that, it's just cause the system is low on gas.
But I now have the same thing as rob, I haven't regased the system after the engine swap but the light turns on anyway... weird.
FWDCelica
sydney,nsw.oz.
Re: ST162 A/C button flashes.. ? Mon, 24 November 2003 00:58 Go to previous messageGo to next message
dude,
There is an electrical connector on the Compressor which is faulty.
I think that is the Problem. My old SV21 Camry used to do the same thing when it was only a few years old.
Trying reading the owners manual, if you have one. I t may give you a clue.
T.
Jaxe
Re: ST162 A/C button flashes.. ? Mon, 24 November 2003 01:28 Go to previous messageGo to next message
Thanks for the replies guys.
I do have a workshop manual (thanks to Rob) and I'll consult that when I get home from work.
Sounds like it could be the gas.. I have no idea when it was last re-gassed.
Cheers!
tooch
Bulleen, Melbourne
Re: ST162 A/C button flashes.. ? Mon, 24 November 2003 01:29 Go to previous messageGo to next message
I'm pretty sure it indicates a problem with the actual magnetic clutch (or the circuit) on the compressor.
toyoda
Re: ST162 A/C button flashes.. ? Mon, 24 November 2003 05:51 Go to previous messageGo to next message
A/c Light Flashing is a Speed Sensor signal fault.
There is a speed sensor built into the Compressor.
If you turn the A/C on and have someone look at the Magnetic Clutch - it should try to engage . If the Belt Squeels and slips the compressor is seized.
On SV21 it was a common problem for the Connectors to be loose/corodded and stopping the signal getting through.
So best bet is to check the connections first.
Flashing light is not caused by too little gas as this will trip the low pressure switch and the A/C will not work at all ( No Lights anywhere)
Good luck
Toyoda
wiso
Re: ST162 A/C button flashes.. ? Mon, 24 November 2003 14:36 Go to previous messageGo to next message
toyoda wrote on Mon, 24 November 2003 16:51
Thats weird man cause I did an engine swap recently so i had to disconnect the a/c system, I haven't bothered to get it regassed yet, but the light turns on the controls.
The reason I thought it was low gas, was cause mine has flashed for a little while now and when I pulled the lines off, not much gas came out of the system.
gt20v
Re: ST162 A/C button flashes.. ? Mon, 24 November 2003 17:08 Go to previous message
if your a/c turns on for few seconds, and flash, AND if there's no squeaking and your engine doesn't die, it's low gas
it will probably be the same results if the clutch of the compressor is not connected...
if it sqeaks in that time and/or your engine dies, it's a seized compressor, as the belt slips and your engine can't turn the seized compressor, there's too much load and the engine can't take the load... Very Happy
when your system is low gas, check the valve, if there's a little gas coming out, that means you're lucky, if there's no gas, you've probably got a leak... Razz
Previous Topic:4AC flywheel on 4age?
Next Topic:4AGE Blowing Smoke? Why?
Current Time: Sat Nov 21 09:10:54 UTC 2026
Total time taken to generate the page: 0.007857084274292 seconds
